Top-Left USB port on Le Potato board crashes USB driver on 4.14
Using kernel 4.14.65, I get a usb-driver crash when accessing the top left port (topmost, nearest the ethernet port) of the Le potato.  Plugging any device into this port results in the following kernel message and prevents the use of usb until reboot.   There is no kernel stacktrace.  As long as I don't plug anything into that port,  the other 3 ports on the board work fine.
[  292.242434] usb 1-2: new full-speed USB device number 7 using xhci-hcd
[  302.562341] xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command.
[  302.583217] xhci-hcd xhci-hcd.0.auto: Host halt failed, -110
[  302.583231] xhci-hcd xhci-hcd.0.auto: xHCI host controller not responding, assume dead
[  302.583287] xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
[  302.583527] usb usb1-port2: couldn't allocate usb_device
[  302.583578] usb 1-1: USB disconnect, device number 2
Is this a known issue?  I looked areound and didn't see any other reports like it.
I switched to a 4.18.5 nightly, and all 4 ports work fine there.  Interestingly the 'bad' port enumerates as '1-2', where the others enumerate as 1-1.1 - 1-1.3 (I was expectng either '1-1.0' or '1-1.4'), and  the current port '1-1' appears to be:
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
So I it looks like the top-left USB port is not hooked up to the usb hub on the le-potato?
Yep, this should be the 'fast' port where you connect a disk to for example since not having to share bandwidth with the other ports. But it's still USB2/Hi-Speed so no idea where xhci messages originate from.
See https://github.com/libre-computer-project/libretech-linux/commit/9b6b181a0700b329876b7998eb75283ce0b338cc
The previous USB patches that were posted to the libre-computer-project 4.14 branch were not the final ones.
All of the out-of-tree patches for 4.14 can be found here: https://github.com/libre-computer-project/libretech-linux/commits/linux-4.14/libretech-cc-master
