nickeh Posted September 28, 2018 Posted September 28, 2018 Hi, is it possible to run xfce4 on mainline on a Orange Pi Zero? I'm doing it with jessie legacy (I need to have a mumble client running, accessing it with X11vnc) but I wanted to upgrade. I've tried the same setup but without any luck. apt-get install --no-install-recommends xserver-xorg apt-get install --no-install-recommends xinit apt-get install xfce4 xfce4-terminal tango-icon-theme gnome-icon-theme lightdm lightdm fails to start on boot and startx tells me: Fatal server error: (EE) no screens found(EE) Have somebody done it and can it be done easily?
Igor Posted September 28, 2018 Posted September 28, 2018 armbian-config -> system -> install desktop ... do that on a clean image. But its officially untested on Oranepi Zero. Here the problem is probably because HDMI is disabled by default (need to be enabled in boot/script.bin|fex). Probably the same on a mainline kernel. Since it's not there.
nickeh Posted September 28, 2018 Author Posted September 28, 2018 11 minutes ago, Igor said: armbian-config -> system -> install desktop ... do that on a clean image. But its officially untested on Oranepi Zero. Here the problem is probably because HDMI is disabled by default (need to be enabled in boot/script.bin|fex). Probably the same on a mainline kernel. Since it's not there. Thanks I'll try that way, is there a reason why the fex editor is removed from armbian-config under system? Can I find it anywhere else?
Igor Posted September 28, 2018 Posted September 28, 2018 4 minutes ago, nickeh said: Thanks I'll try that way, is there a reason why the fex editor is removed from armbian-config under system? Fex editor is not there if there are no sunxi-tools installed or if you are running a mainline kernel ... or there is a bug, your system is broken somehow. Quote Can I find it anywhere else? If GUI is not operational, there is always a manual way: bin2fex and fex2bin tools. If not, you install them, eventually compile from sources.
