lemonahmas Posted September 29, 2018 Posted September 29, 2018 (edited) Hi everyone viewing this post, here is the situation. I think I have configured my hostapd correctly, but I cannot find the ssid(I haven't hidden it), and I cannot even join mannualy. there is no fatal error in the log so I don't know what to do. PLEASE HELP. THANK ALL OF YOU VERY MUCH. -----here is the log----- Spoiler random: Trying to read entropy from /dev/random Configuration file: /etc/hostapd.conf ctrl_interface_group=0 nl80211: Could not add multicast membership for vendor events: -2 (No such file or directory) nl80211: TDLS supported nl80211: Supported cipher 00-0f-ac:1 nl80211: Supported cipher 00-0f-ac:5 nl80211: Supported cipher 00-0f-ac:2 nl80211: Supported cipher 00-0f-ac:4 nl80211: Supported cipher 00-0f-ac:6 nl80211: Using driver-based off-channel TX nl80211: Use separate P2P group interface (driver advertised support) nl80211: Enable multi-channel concurrent (driver advertised support) nl80211: use P2P_DEVICE support nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 4 iftype 3 (AP) nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0 nl80211: Subscribe to mgmt frames with AP handle 0x559538cf80 (device SME) nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=04 nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 04 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=0501 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=0504 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=06 nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 06 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=08 nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 08 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=09 nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 09 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=0a nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 0a nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=11 nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 11 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x559538cf80 match=7f nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 7f nl80211: Failed to subscribe for mgmt frames from SME driver - trying to run without it nl80211: Enable Probe Request reporting nl_preq=0x559538cf80 nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x559538cf80 match= nl80211: Register frame command failed (type=64): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=0): [NULL] nl80211: Failed to enable Probe Request frame reporting in AP mode rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0 nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) nl80211: Add own interface ifindex 4 (ifidx_reason -1) nl80211: if_indices[16]: 4(-1) phy: phy0 BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits) Using existing control interface directory. wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE Previous country code 00, new country code CH Continue interface setup after channel list update ctrl_iface not configured! random: Got 20/20 bytes from /dev/random Channel list update timeout - try to continue anyway nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 40 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm hw vht capab: 0x0, conf vht capab: 0x0 Completing interface initialization Mode: IEEE 802.11g Channel: 9 Frequency: 2452 MHz DFS 0 channels required radar detection nl80211: Set freq 2452 (ht_enabled=1, vht_enabled=0, bandwidth=20 MHz, cf1=2452 MHz, cf2=0 MHz) * freq=2452 * vht_enabled=0 * ht_enabled=1 * sec_channel_offset=0 * channel_type=1 RATE[0] rate=10 flags=0x1 RATE[1] rate=20 flags=0x1 RATE[2] rate=55 flags=0x1 RATE[3] rate=110 flags=0x1 RATE[4] rate=60 flags=0x0 RATE[5] rate=90 flags=0x0 RATE[6] rate=120 flags=0x0 RATE[7] rate=180 flags=0x0 RATE[8] rate=240 flags=0x0 RATE[9] rate=360 flags=0x0 RATE[10] rate=480 flags=0x0 RATE[11] rate=540 flags=0x0 hostapd_setup_bss(hapd=0x559538d7f0 (wlan0), first=1) wlan0: Flushing old station entries nl80211: flush -> DEL_STATION wlan0 (all) wlan0: Deauthenticate all stations nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success) wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 Using interface wlan0 with hwaddr ac:83:f3:1e:d3:ff and ssid "ARMBIAN" Deriving WPA PSK based on passphrase SSID - hexdump_ascii(len=7): 41 52 4d 42 49 41 4e ARMBIAN PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED] PSK (from passphrase) - hexdump(len=32): [REMOVED] Get randomness: len=32 entropy=0 GMK - hexdump(len=32): [REMOVED] Get randomness: len=32 entropy=0 Key Counter - hexdump(len=32): [REMOVED] WPA: Delay group state machine start until Beacon frames have been configured nl80211: Set beacon (beacon_set=0) nl80211: Beacon head - hexdump(len=58): 80 00 00 00 ff ff ff ff ff ff ac 83 f3 1e d3 ff ac 83 f3 1e d3 ff 00 00 00 00 00 00 00 00 00 00 64 00 31 04 00 07 41 52 4d 42 49 41 4e 01 08 82 84 8b 96 0c 12 18 24 03 01 09 nl80211: Beacon tail - hexdump(len=117): 07 06 43 48 20 01 0d 14 2a 01 00 32 04 30 48 60 6c 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 0c 00 1f ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3d 16 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00 nl80211: ifindex=4 nl80211: beacon_int=100 nl80211: dtim_period=2 nl80211: ssid - hexdump_ascii(len=7): 41 52 4d 42 49 41 4e ARMBIAN * beacon_int=100 * dtim_period=2 nl80211: hidden SSID not in use nl80211: privacy=1 nl80211: auth_algs=0x1 nl80211: wpa_version=0x2 nl80211: key_mgmt_suites=0x2 nl80211: pairwise_ciphers=0x10 nl80211: group_cipher=0x10 nl80211: SMPS mode - off WPA: Start group state machine to set initial keys WPA: group state machine entering state GTK_INIT (VLAN-ID 0) Get randomness: len=16 entropy=0 GTK - hexdump(len=16): [REMOVED] WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0) wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=3 addr=0x55953550d8 key_idx=1 set_tx=1 seq_len=0 key_len=16 nl80211: KEY_DATA - hexdump(len=16): [REMOVED] broadcast key nl80211: Set wlan0 operstate 0->1 (UP) netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=6 (IF_OPER_UP) Failed to set TX queue parameters for queue 0. Failed to set TX queue parameters for queue 1. Failed to set TX queue parameters for queue 2. Failed to set TX queue parameters for queue 3. wlan0: interface state COUNTRY_UPDATE->ENABLED wlan0: AP-ENABLED wlan0: Setup of interface done. nl80211: Event message available nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 nl80211: Event message available nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan probed for SSID '' nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 wlan0: Event SCAN_RESULTS (3) received RTM_NEWLINK: ifi_index=4 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) nl80211: Event message available nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 nl80211: Event message available nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan probed for SSID '' nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 wlan0: Event SCAN_RESULTS (3) received RTM_NEWLINK: ifi_index=4 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) nl80211: Event message available nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received Unknown event 47 nl80211: Event message available nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available nl80211: Scan probed for SSID '' nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 wlan0: Event SCAN_RESULTS (3) received RTM_NEWLINK: ifi_index=4 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP]) Signal 2 received - terminating hostapd_interface_deinit_free(0x559538c550) hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1 hostapd_interface_deinit(0x559538c550) wlan0: interface state ENABLED->DISABLED hostapd_bss_deinit: deinit bss wlan0 wlan0: Deauthenticate all stations nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success) wlan0: AP-DISABLED hostapd_cleanup(hapd=0x559538d7f0 (wlan0)) hostapd_free_hapd_data(wlan0) hostapd_interface_deinit_free: driver=0x5595388d38 drv_priv=0x559538e440 -> hapd_deinit nl80211: deinit ifname=wlan0 disabled_11b_rates=0 nl80211: Remove monitor interface: refcount=0 nl80211: Remove beacon (ifindex=4) netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP) hostapd_interface_free(0x559538c550) hostapd_interface_free: free hapd 0x559538d7f0 hostapd_cleanup_iface(0x559538c550) hostapd_cleanup_iface_partial(0x559538c550) hostapd_cleanup_iface: free iface=0x559538c550 -----here is /etc/hostapd.conf----- # # armbian hostapd configuration example # # nl80211 mode # ssid=ARMBIAN interface=wlan0 hw_mode=g channel=9 #bridge=br0 driver=nl80211 ignore_broadcast_ssid=0 # 是否广播,0 广播 logger_syslog=0 logger_syslog_level=0 wmm_enabled=1 wpa=2 preamble=1 wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 noscan=1 ## IEEE 802.11n ieee80211n=1 ht_capab=[DSSS_CK-40][HT20+] country_code=CH ieee80211d=1 ## IEEE 802.11n ### IEEE 802.11a #hw_mode=a ### IEEE 802.11a ### IEEE 802.11ac #ieee80211ac=1 #vht_capab=[MAX-MPDU-11454][SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-A-MPDU-LEN-EXP3] #vht_oper_chwidth=1 #vht_oper_centr_freq_seg0_idx=42 ### IEEE 802.11ac # controlling enabled ctrl_interface=/var/run/hostapd ctrl_interface_group=0 Spoiler THANK YOU! Edited September 29, 2018 by Tido added Spoiler
Tido Posted September 29, 2018 Posted September 29, 2018 Beside using the search function (right hand corner on top), I recommend you to reduce your configuration-file to the bare minimum and then see if it works. If it doesn't work, search your log and use Google. I spent hours if not days to get the BPi-R1 working.
lemonahmas Posted September 29, 2018 Author Posted September 29, 2018 Thank you for ur reply, And I tried this it worked: rmmod bcmdhd modprobe bcmdhd op_mode=2 AP6212 can only work in client mode or AP mode, it needs to be manualy changed. However, after reboot it won't work, so I guess I have to figure out how to keep this state.
