JonatasPrust Posted October 2, 2018 Posted October 2, 2018 My equipment is an OrangePi PC Plus with ARMBIAN 5.6, packages and system updated. I have seen that the /var/ log directory mounted as zram is reaching its space limit in a few days. To resolve, I edited the /etc/logrotate.d/rsyslog file and put the following: /var/log.hdd/syslog { rotate 1 10M size missingok notifempty delaycompress compress postrotate invoke-rc.d rsyslog rotate> / dev / null endscript } /var/log.hdd/mail.info /var/log.hdd/mail.warn /var/log.hdd/mail.err /var/log.hdd/mail.log /var/log.hdd/daemon.log /var/log.hdd/kern.log /var/log.hdd/auth.log /var/log.hdd/user.log /var/log.hdd/lpr.log /var/log.hdd/cron.log /var/log.hdd/debug /var/log.hdd/messages { rotate 1 size 1M missingok notifempty compress delaycompress sharedscripts postrotate invoke-rc.d rsyslog rotate> / dev / null endscript } First, i manually executed logrotate to test, and nothing happened in /var/log. I tried editing the logrotate file to change the /var/log.hdd directory to /var/log but when the system is restarted, it returns to log.hdd. I want to know how to solve this.
JonatasPrust Posted October 4, 2018 Author Posted October 4, 2018 I would like to disable zram and mount /var/log as tmpfs. In fstab I did not find an entry for /var/log, so I created one with the tmpfs format. Still while giving the command "df" I realized that / var / log is still mounted as zram. What is the way to change or disable zram?
sfx2000 Posted October 10, 2018 Posted October 10, 2018 Reason why /var/log is filling up is because if you review df -h, you'll find that /var/log is mapped to zram... Logrotate might not hit the time limits in the fs time as each time with current zram-config in armbian, it's mapped to an ephemeral state over in zram - ask @tkaiser why this is what it is - his script that does this... my guess his intend with /var/log is to reduce read/write on flash there, and that's fair enough... Things in /tmp are ok to be free and mapped to tmpfs - things in /var, even /var/tmp are expected to remain constant across boots, but that's just my opinion. My opinion and two bucks will buy you a cup of coffee at the local *bucks... zram is a good thing actually - and tmpfs plays into that, as tmpfs is ram...
sfx2000 Posted October 10, 2018 Posted October 10, 2018 Anyways - if one is writing to /var/log, and still running into problems with space - even on a small mem footprint - need to explore why so much logging... Case in point... this is my jumpbox into my lan - and we're writing /var/tmp to flash, and it's not that big of a deal at first glance... $ sudo du -h /var/log 4.0K /var/log/samba 4.0K /var/log/sysstat 32K /var/log/lightdm 180K /var/log/apt 2.8M /var/log This is 6-months worth of use on that box... the 2.8M is a bit misleading, as it's active all the time, and writes to flash have a cost there there, as each write to flash is also an erase cycle, and on poor quality cards, this can lead to early failure - and small cards are more at risk than larger cards... I'll defend the decision to some degree - @tkaiser's script has to assume many things - size of the flash, quality of the flash...
sfx2000 Posted October 11, 2018 Posted October 11, 2018 On 10/3/2018 at 5:42 PM, JonatasPrust said: I would like to disable zram and mount /var/log as tmpfs. In fstab I did not find an entry for /var/log, so I created one with the tmpfs format. Still while giving the command "df" I realized that / var / log is still mounted as zram. What is the way to change or disable zram? Hint - it's a feature mention within the armbian-zram-config script set - it calls armbian-ramlog Look at /etc/default/armbian-ramlog - you can change "enabled" to false, and then things start follow expected rules... and you can mount /var/log where ever you want... remember you need to be root or sudo to do this, and reboot after the change. 1
