ark74 Posted October 2, 2018 Posted October 2, 2018 (edited) Hi Armbian Users I'm french, so excuse my poor english I'm having hard times installing Ubiquiti Unifi Controller on Armbian (running on a XU4) Armbian version : Armbian_5.59_Odroidxu4_Debian_stretch_next_4.14.66 I followed different tutorial, but no luck with those no brain tutorial. I must be retarded MongoDB is giving me a hard time, broken dependencies and so on. I understood that some managed to do it with Armbian based on Ubuntu. No luck eitheir for me. I did add the mongodb repository for 3.6 version, which support arm64 architecture. Apt never gave me the ability to install the mongodb-org package and dependencies for this package. A few links : https://github.com/aryonp/unifi/blob/master/install_unifi_odroid_xu4.sh https://docs.mongodb.com/manual/tutorial/install-mongodb-on-ubuntu/ (followed the ubuntu 16.04 tutorial) https://forum.odroid.com/viewtopic.php?t=22850 https://help.ubnt.com/hc/en-us/articles/220066768-UniFi-How-to-Install-Update-via-APT-on-Debian-or-Ubuntu I could have left that here, but no.. My armbian.list : deb http://apt.armbian.com stretch main stretch-utils stretch-desktop # deb http://repo.mongodb.org/apt/debian stretch/mongodb-org/4.0 main deb [arch=amd64,arm64] http://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 multiverse # deb [arch=amd64,arm64] https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 multiverse deb http://mirrordirector.raspbian.org/raspbian stretch main contrib non-free rpi The few commands that goes with it : apt-add-repository ppa:webupd8team/java apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886 wget http://mirrordirector.raspbian.org/raspbian.public.key apt-key add raspbian.public.key sudo wget -O /etc/apt/trusted.gpg.d/unifi-repo.gpg https://dl.ubnt.com/unifi/unifi-repo.gpg apt update apt install unifi apt install oracle-java8-installer oracle-java8-set-default oracle-java8-unlimited-jce-policy systemctl enable unifi systemctl disable mongodb systemctl stop mongodb /etc/init.d/unifi start I end up with a Unifi Controller 5.8.30 working on Armbian (Debian), but... MongoDB is in version 2.4 and comes from raspbian repository ? Any thought on this ? Should I go an other way ? Thank you Edited October 2, 2018 by ark74 missing info
chrisf Posted October 2, 2018 Posted October 2, 2018 XU4 is 32bit, not 64bit. You need armhf, not arm64
ark74 Posted October 3, 2018 Author Posted October 3, 2018 Hi, I see your point, rookie mistake Thanks. As far as I know, there is no official package or ripository on MongoDB side for armhf. Sooo, if I want mongoDB up to date, I have to either : - Compile MongoDB myself on the XU4. Will Unifi be able to find it during installation with Apt (I see broken dependencies from a mile away) ? - Switch to Arch Linux, to which I understand nothing for now... Or, I'm just going to production with this old thingy.. I'm right ?
chrisf Posted October 4, 2018 Posted October 4, 2018 (edited) I have unifi running on an hc1 and I dont recall any issues. When I get home I'll see if I have time to post how I did it. This is the apt source I used # cat 100-ubnt-unifi.list deb http://www.ubnt.com/downloads/unifi/debian stable ubiquiti The only other sources I have is armbian Edit: my mongodb-server package is from debian # apt-cache showpkg mongodb-server Package: mongodb-server Versions: 1:2.4.10-5+deb8u1 (/var/lib/apt/lists/httpredir.debian.org_debian_dists_jessie_main_binary-armhf_Packages) Edited October 4, 2018 by chrisf
ark74 Posted October 4, 2018 Author Posted October 4, 2018 Hi Chris, Thanks for your time and research. I've checked the packages list for armhf on jessie and stretch repository (debian repos, not armbian). The mongodb-server package is only listed on the jessie repository. It should explain why with a brand new install of armbian stretch, I have missing dependencies. Your HC1 is running armbian stretch or jessie ? Would you go into production with this old package ? Thanks
JMCC Posted October 8, 2018 Posted October 8, 2018 Compiling Debian packages is a breeze, and since it only takes a couple minutes to create a fresh Armbian installation, you can just create one for compiling purposes. And, since Ubuntu Bionic already has an up-to-date package for mongo DB, I think the best option is to compile it for Stretch from the Bionic source package. Here is what I would do: Flash an Armbian Stretch image on a spare SD card, and boot my XU4 from it. Add the following line to /etc/apt/sources.list deb-src http://us.archive.ubuntu.com/ubuntu/ bionic universe Then, enter the following commands sudo apt-get update sudo apt install fakeroot sudo apt-get build-dep mongodb apt-get source mongodb cd mongodb* dpkg-buildpackage -us -uc -rfakeroot -j8 If I didn't make any typo, and Stretch has the right dependencies in its repos, the commands above should compile for you a set of Stretch-armhf mongodb packages. Just copy them to an USB drive, and then install them in your production Armbian Stretch system.
chrisf Posted October 9, 2018 Posted October 9, 2018 On 10/5/2018 at 12:57 AM, ark74 said: Your HC1 is running armbian stretch or jessie ? Would you go into production with this old package ? It's still on jessie. I've had no reason to change anything. Jessie is still a supported version. In terms of "go into production", it's an SBC in my garage...
Guest Posted May 25, 2019 Posted May 25, 2019 https://launchpad.net/~webupd8team/+archive/ubuntu/java Now what? I crumped my odroid xu4 server, and went to reinstall my unifi controller software and this was what I was hit with. Somehow it installed openjava, but it isn't working the same.
