It's not that hard to build ffmpeg on Armbian, directly from official source. I will show all steps i am using and all codecs i install, if some is not needed, skip and remove it from ffmpeg ./config. First i create some temporary folder, it's named "t" in this example. Then we can get dependencies with "apt-get build-dep". As ffmpeg is present in Ubuntu repositories, we can get directly:
sudo apt-get update
sudo apt-get build-dep ffmpeg
But in Debian ffmpeg is not present, so we can get deps for libav:
sudo apt-get update
sudo apt-get build-dep libav
It's also a good idea to have ffmpeg support samba, so we can install it too:
sudo apt-get install samba samba-common attr samba-vfs-modules smbclient
Get some more dependencies:
sudo apt-get install autoconf automake build-essential libass-dev libfreetype6-dev libsdl1.2-dev libtheora-dev libtool libva-dev libvdpau-dev libvorbis-dev libxcb1-dev libxcb-shm0-dev libxcb-xfixes0-dev pkg-config texinfo zlib1g-dev
We will probably need this packages too:
cd t
wget http://www.tortall.net/projects/yasm/releases/yasm-1.3.0.tar.gz
tar xzvf yasm-1.3.0.tar.gz
cd yasm-1.3.0
./configure --prefix=/usr
make -j2
sudo make install
cd ..
tar -xjvf fribidi-0.19.7.tar.bz2
cd fribidi-0.19.7
./configure
make
sudo make install
cd ..
http://savannah.nongnu.org/download/freetype/
wget http://download.savannah.gnu.org/releases/freetype/freetype-2.6.3.tar.bz2
tar xjvf freetype-2.6.3.tar.bz2
cd freetype-2.6.3
sh autogen.sh
make setup ansi
make -j2
cd ..
Let's install some codecs, avoid what you don't need:
sudo curl https://yt-dl.org/downloads/2016.02.27/youtube-dl -o /usr/local/bin/youtube-dl
sudo chmod a+rx /usr/local/bin/youtube-dl
https://sourceforge.net/projects/lame/files/lame/
tar -xzvf lame-3.99.5.tar.gz
cd lame-3.99.5
./configure
make -j2
sudo make install
cd ..
git clone http://git.videolan.org/git/x262.git
cd x262
./configure --prefix=/usr --enable-static --enable-shared
make -j2
sudo make install
sudo ldconfig
cd ..
git clone git://git.videolan.org/x264.git
cd x264
./configure --enable-static --enable-shared
make -j2
sudo make install
sudo ldconfig
cd ..
video4linux/libv4l2
git clone git://linuxtv.org/v4l-utils.git
cd v4l-utils
./bootstrap.sh
./configure
make -j2
sudo make install
cd ..
http://downloads.sourceforge.net/opencore-amr/fdk-aac-0.1.4.tar.gz
tar xzvf fdk-aac-0.1.4.tar.gz
cd fdk-aac-0.1.4
./configure --prefix=/usr --disable-static
make -j2
sudo make install
cd ..
wget http://downloads.xiph.org/releases/opus/opus-1.1.tar.gz
tar xzvf opus-1.1.tar.gz
cd opus-1.1
./configure
make -j2
sudo make install
cd ..
wget http://storage.googleapis.com/downloads.webmproject.org/releases/webm/libvpx-1.5.0.tar.bz2
tar xjvf libvpx-1.5.0.tar.bz2
cd libvpx-1.5.0
./configure --prefix=/usr --disable-examples --disable-unit-tests
make -j2
sudo make install
cd ..
sudo apt-get install flac
git clone https://github.com/libass/libass.git
cd libass
./autogen.sh
make -j2
sudo make install
cd ..
https://www.xiph.org/downloads/
wget http://downloads.xiph.org/releases/ogg/libogg-1.3.2.tar.xz
tar xJvf libogg-1.3.2.tar.xz
cd libogg-1.3.2
./configure
make -j2
sudo make install
cd ..
wget http://downloads.xiph.org/releases/vorbis/libvorbis-1.3.5.tar.xz
tar xJvf libvorbis-1.3.5.tar.xz
cd libvorbis-1.3.5
./configure
make -j2
sudo make install
cd ..
If you need x265 (as H3 support HEVC/H265) this is a tricky one and took me some time to deal with, because of a bug, so it need special attention. We need shared libraries but we will get error during make. So first some dependencies:
sudo apt-get install mercurial cmake cmake-curses-gui build-essential
hg clone https://bitbucket.org/multicoreware/x265
We have to modify one file, so shared version can be build. Open the following file:
nano /t/x265/source/common/primitives.cpp
and locate this lines:
- #if ENABLE_ASSEMBLY && X265_ARCH_ARM == 0
  void PFX(cpu_neon_test)(void) {}
  int PFX(cpu_fast_neon_mrc_test)(void) { return 0; }
- #endif
  #endif
Remove the two lines with "-" in front and save (ctrl+o, ctrl+x). Now we can build what we need:
cd x265/build/linux
./make-Makefiles.bash #> c > g
make -j2
sudo make install
sudo ldconfig
cd ~/t
As we have all packages and codecs we need, we can build ffmpeg:
wget http://ffmpeg.org/releases/ffmpeg-snapshot.tar.bz2
tar xjvf ffmpeg-snapshot.tar.bz2
cd ffmpeg
./configure --prefix=/usr --enable-nonfree --enable-gpl --enable-version3 --enable-vdpau --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libpulse --enable-libv4l2 --enable-libx264 --enable-libx265
make -j2
sudo make install
This will take a while, but i think it worth.
RagnerBG's procedure is beyond amature.
i only  do the followings on armbian of orange pi PC .
it takes long time (over 60 minites )
aptitude install  git  yasm  pkg-config
cd Downloads
git clone git://source.ffmpeg.org/ffmpeg.git ffmpeg
cd ffmpeg
./configure
make
sudo make install
this procedure may lack something compared with RagnerBG's  because of too simplicity .
ffmpeg -formats says
ffmpeg version N-79121-gfe3de6b Copyright © 2000-2016 the FFmpeg developers
  built with gcc 4.9.2 (Debian 4.9.2-10)
  configuration:
  libavutil      55. 19.100 / 55. 19.100
  libavcodec     57. 30.100 / 57. 30.100
  libavformat    57. 29.100 / 57. 29.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 39.102 /  6. 39.102
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
File formats:
 D. = Demuxing supported
 .E = Muxing supported
 D  3dostr          3DO STR
  E 3g2             3GP2 (3GPP2 file format)
  E 3gp             3GP (3GPP file format)
 D  4xm             4X Technologies
  E a64             a64 - video for Commodore 64
 D  aa              Audible AA format files
 D  aac             raw ADTS AAC (Advanced Audio Coding)
 DE ac3             raw AC-3
 D  acm             Interplay ACM
 D  act             ACT Voice file format
 D  adf             Artworx Data Format
 D  adp             ADP
 D  ads             Sony PS2 ADS
  E adts            ADTS AAC (Advanced Audio Coding)
 DE adx             CRI ADX
 D  aea             MD STUDIO audio
 D  afc             AFC
 DE aiff            Audio IFF
 DE alaw            PCM A-law
 D  alias_pix       Alias/Wavefront PIX image
 DE amr             3GPP AMR
 D  anm             Deluxe Paint Animation
 D  apc             CRYO APC
 D  ape             Monkey's Audio
 DE apng            Animated Portable Network Graphics
 D  aqtitle         AQTitle subtitles
 DE asf             ASF (Advanced / Active Streaming Format)
 D  asf_o           ASF (Advanced / Active Streaming Format)
  E asf_stream      ASF (Advanced / Active Streaming Format)
 DE ass             SSA (SubStation Alpha) subtitle
 DE ast             AST (Audio Stream)
 DE au              Sun AU
 DE avi             AVI (Audio Video Interleaved)
  E avm2            SWF (ShockWave Flash) (AVM2)
 D  avr             AVR (Audio Visual Research)
 D  avs             AVS
 D  bethsoftvid     Bethesda Softworks VID
 D  bfi             Brute Force & Ignorance
 D  bfstm           BFSTM (Binary Cafe Stream)
 D  bin             Binary text
 D  bink            Bink
 DE bit             G.729 BIT file format
 D  bmp_pipe        piped bmp sequence
 D  bmv             Discworld II BMV
 D  boa             Black Ops Audio
 D  brender_pix     BRender PIX image
 D  brstm           BRSTM (Binary Revolution Stream)
 D  c93             Interplay C93
 DE caf             Apple CAF (Core Audio Format)
 DE cavsvideo       raw Chinese AVS (Audio Video Standard) video
 D  cdg             CD Graphics
 D  cdxl            Commodore CDXL video
 D  cine            Phantom Cine
 D  concat          Virtual concatenation script
  E crc             CRC testing
  E dash            DASH Muxer
 DE data            raw data
 DE daud            D-Cinema audio
 D  dcstr           Sega DC STR
 D  dds_pipe        piped dds sequence
 D  dfa             Chronomaster DFA
 DE dirac           raw Dirac
 DE dnxhd           raw DNxHD (SMPTE VC-3)
 D  dpx_pipe        piped dpx sequence
 D  dsf             DSD Stream File (DSF)
 D  dsicin          Delphine Software International CIN
 D  dss             Digital Speech Standard (DSS)
 DE dts             raw DTS
 D  dtshd           raw DTS-HD
 DE dv              DV (Digital Video)
 D  dv1394          DV1394 A/V grab
 D  dvbsub          raw dvbsub
 D  dvbtxt          dvbtxt
  E dvd             MPEG-2 PS (DVD VOB)
 D  dxa             DXA
 D  ea              Electronic Arts Multimedia
 D  ea_cdata        Electronic Arts cdata
 DE eac3            raw E-AC-3
 D  epaf            Ensoniq Paris Audio File
 D  exr_pipe        piped exr sequence
 DE f32be           PCM 32-bit floating-point big-endian
 DE f32le           PCM 32-bit floating-point little-endian
  E f4v             F4V Adobe Flash Video
 DE f64be           PCM 64-bit floating-point big-endian
 DE f64le           PCM 64-bit floating-point little-endian
 DE fbdev           Linux framebuffer
 DE ffm             FFM (FFserver live feed)
 DE ffmetadata      FFmpeg metadata in text
 D  film_cpk        Sega FILM / CPK
 DE filmstrip       Adobe Filmstrip
 DE flac            raw FLAC
 D  flic            FLI/FLC/FLX animation
 DE flv             FLV (Flash Video)
  E framecrc        framecrc testing
  E framemd5        Per-frame MD5 testing
 D  frm             Megalux Frame
 D  fsb             FMOD Sample Bank
 DE g722            raw G.722
 DE g723_1          raw G.723.1
 D  g729            G.729 raw format demuxer
 D  genh            GENeric Header
 DE gif             GIF Animation
 D  gsm             raw GSM
 DE gxf             GXF (General eXchange Format)
 DE h261            raw H.261
 DE h263            raw H.263
 DE h264            raw H.264 video
  E hds             HDS Muxer
 DE hevc            raw HEVC video
  E hls             Apple HTTP Live Streaming
 D  hls,applehttp   Apple HTTP Live Streaming
 D  hnm             Cryo HNM v4
 DE ico             Microsoft Windows ICO
 D  idcin           id Cinematic
 D  idf             iCE Draw File
 D  iff             IFF (Interchange File Format)
 DE ilbc            iLBC storage
 DE image2          image2 sequence
 DE image2pipe      piped image2 sequence
 D  ingenient       raw Ingenient MJPEG
 D  ipmovie         Interplay MVE
  E ipod            iPod H.264 MP4 (MPEG-4 Part 14)
 DE ircam           Berkeley/IRCAM/CARL Sound Format
  E ismv            ISMV/ISMA (Smooth Streaming)
 D  iss             Funcom ISS
 D  iv8             IndigoVision 8000 video
 DE ivf             On2 IVF
 D  ivr             IVR (Internet Video Recording)
 D  j2k_pipe        piped j2k sequence
 DE jacosub         JACOsub subtitle format
 D  jpeg_pipe       piped jpeg sequence
 D  jpegls_pipe     piped jpegls sequence
 D  jv              Bitmap Brothers JV
  E latm            LOAS/LATM
 D  lavfi           Libavfilter virtual input device
 D  live_flv        live RTMP FLV (Flash Video)
 D  lmlm4           raw lmlm4
 D  loas            LOAS AudioSyncStream
 DE lrc             LRC lyrics
 D  lvf             LVF
 D  lxf             VR native stream (LXF)
 DE m4v             raw MPEG-4 video
  E matroska        Matroska
 D  matroska,webm   Matroska / WebM
  E md5             MD5 testing
 D  mgsts           Metal Gear Solid: The Twin Snakes
 DE microdvd        MicroDVD subtitle format
 DE mjpeg           raw MJPEG video
  E mkvtimestamp_v2 extract pts as timecode v2 format, as defined by mkvtoolnix
 DE mlp             raw MLP
 D  mlv             Magic Lantern Video (MLV)
 D  mm              American Laser Games MM
 DE mmf             Yamaha SMAF
  E mov             QuickTime / MOV
 D  mov,mp4,m4a,3gp,3g2,mj2 QuickTime / MOV
  E mp2             MP2 (MPEG audio layer 2)
 DE mp3             MP3 (MPEG audio layer 3)
  E mp4             MP4 (MPEG-4 Part 14)
 D  mpc             Musepack
 D  mpc8            Musepack SV8
 DE mpeg            MPEG-1 Systems / MPEG program stream
  E mpeg1video      raw MPEG-1 video
  E mpeg2video      raw MPEG-2 video
 DE mpegts          MPEG-TS (MPEG-2 Transport Stream)
 D  mpegtsraw       raw MPEG-TS (MPEG-2 Transport Stream)
 D  mpegvideo       raw MPEG video
 DE mpjpeg          MIME multipart JPEG
 D  mpl2            MPL2 subtitles
 D  mpsub           MPlayer subtitles
 D  msf             Sony PS3 MSF
 D  msnwctcp        MSN TCP Webcam stream
 D  mtv             MTV
 DE mulaw           PCM mu-law
 D  mv              Silicon Graphics Movie
 D  mvi             Motion Pixels MVI
 DE mxf             MXF (Material eXchange Format)
  E mxf_d10         MXF (Material eXchange Format) D-10 Mapping
  E mxf_opatom      MXF (Material eXchange Format) Operational Pattern Atom
 D  mxg             MxPEG clip
 D  nc              NC camera feed
 D  nistsphere      NIST SPeech HEader REsources
 D  nsv             Nullsoft Streaming Video
  E null            raw null video
 DE nut             NUT
 D  nuv             NuppelVideo
  E oga             Ogg Audio
 DE ogg             Ogg
 DE oma             Sony OpenMG audio
  E opus            Ogg Opus
 DE oss             OSS (Open Sound System) playback
 D  paf             Amazing Studio Packed Animation File
 D  pcx_pipe        piped pcx sequence
 D  pictor_pipe     piped pictor sequence
 D  pjs             PJS (Phoenix Japanimation Society) subtitles
 D  pmp             Playstation Portable PMP
 D  png_pipe        piped png sequence
  E psp             PSP MP4 (MPEG-4 Part 14)
 D  psxstr          Sony Playstation STR
 D  pva             TechnoTrend PVA
 D  pvf             PVF (Portable Voice Format)
 D  qcp             QCP
 D  qdraw_pipe      piped qdraw sequence
 D  r3d             REDCODE R3D
 DE rawvideo        raw video
 D  realtext        RealText subtitle format
 D  redspark        RedSpark
 D  rl2             RL2
 DE rm              RealMedia
 DE roq             raw id RoQ
 D  rpl             RPL / ARMovie
 D  rsd             GameCube RSD
 DE rso             Lego Mindstorms RSO
 DE rtp             RTP output
  E rtp_mpegts      RTP/mpegts output format
 DE rtsp            RTSP output
 DE s16be           PCM signed 16-bit big-endian
 DE s16le           PCM signed 16-bit little-endian
 DE s24be           PCM signed 24-bit big-endian
 DE s24le           PCM signed 24-bit little-endian
 DE s32be           PCM signed 32-bit big-endian
 DE s32le           PCM signed 32-bit little-endian
 DE s8              PCM signed 8-bit
 D  sami            SAMI subtitle format
 DE sap             SAP output
 D  sbg             SBaGen binaural beats script
 D  sdp             SDP
 D  sdr2            SDR2
  E segment         segment
 D  sgi_pipe        piped sgi sequence
 D  shn             raw Shorten
 D  siff            Beam Software SIFF
  E singlejpeg      JPEG single image
 D  sln             Asterisk raw pcm
 DE smjpeg          Loki SDL MJPEG
 D  smk             Smacker
  E smoothstreaming Smooth Streaming Muxer
 D  smush           LucasArts Smush
 D  sol             Sierra SOL
 DE sox             SoX native
 DE spdif           IEC 61937 (used on S/PDIF - IEC958)
  E spx             Ogg Speex
 DE srt             SubRip subtitle
 D  stl             Spruce subtitle format
  E stream_segment,ssegment streaming segment muxer
 D  subviewer       SubViewer subtitle format
 D  subviewer1      SubViewer v1 subtitle format
 D  sunrast_pipe    piped sunrast sequence
 D  sup             raw HDMV Presentation Graphic Stream subtitles
 D  svag            Konami PS2 SVAG
  E svcd            MPEG-2 PS (SVCD)
 DE swf             SWF (ShockWave Flash)
 D  tak             raw TAK
 D  tedcaptions     TED Talks captions
  E tee             Multiple muxer tee
 D  thp             THP
 D  tiertexseq      Tiertex Limited SEQ
 D  tiff_pipe       piped tiff sequence
 D  tmv             8088flex TMV
 DE truehd          raw TrueHD
 D  tta             TTA (True Audio)
 D  tty             Tele-typewriter
 D  txd             Renderware TeXture Dictionary
 DE u16be           PCM unsigned 16-bit big-endian
 DE u16le           PCM unsigned 16-bit little-endian
 DE u24be           PCM unsigned 24-bit big-endian
 DE u24le           PCM unsigned 24-bit little-endian
 DE u32be           PCM unsigned 32-bit big-endian
 DE u32le           PCM unsigned 32-bit little-endian
 DE u8              PCM unsigned 8-bit
  E uncodedframecrc uncoded framecrc testing
 D  v210            Uncompressed 4:2:2 10-bit
 D  v210x           Uncompressed 4:2:2 10-bit
  E v4l2            Video4Linux2 output device
 D  vag             Sony PS2 VAG
 DE vc1             raw VC-1 video
 DE vc1test         VC-1 test bitstream
  E vcd             MPEG-1 Systems / MPEG program stream (VCD)
 D  video4linux2,v4l2 Video4Linux2 device grab
 D  vivo            Vivo
 D  vmd             Sierra VMD
  E vob             MPEG-2 PS (VOB)
 D  vobsub          VobSub subtitle format
 DE voc             Creative Voice
 D  vpk             Sony PS2 VPK
 D  vplayer         VPlayer subtitles
 D  vqf             Nippon Telegraph and Telephone Corporation (NTT) TwinVQ
 DE w64             Sony Wave64
 DE wav             WAV / WAVE (Waveform Audio)
 D  wc3movie        Wing Commander III movie
  E webm            WebM
  E webm_chunk      WebM Chunk Muxer
 DE webm_dash_manifest WebM DASH Manifest
  E webp            WebP
 D  webp_pipe       piped webp sequence
 DE webvtt          WebVTT subtitle
 D  wsaud           Westwood Studios audio
 D  wsvqa           Westwood Studios VQA
 DE wtv             Windows Television (WTV)
 DE wv              raw WavPack
 D  wve             Psion 3 audio
 D  x11grab         X11 screen capture, using XCB
 D  xa              Maxis XA
 D  xbin            eXtended BINary text (XBIN)
 D  xmv             Microsoft XMV
  E xv              XV (XVideo) output device
 D  xvag            Sony PS3 XVAG
 D  xwma            Microsoft xWMA
 D  yop             Psygnosis YOP
 DE yuv4mpegpipe    YUV4MPEG pipe
Well, as I see ffmpeg is needed to use hardware acceleration with the Orange PI, and both procedures are significantly different. The first one, with RagnerBG procedure you install everything you want manually, appart from ffmpeg, the second procedure is about installing the pure ffmpeg from the git, as a sole packet I guess.
I would stick with both of them and see which one works in a better complete way. I just really think that vdpau is the most important thing, isn't it? because without it (at least for me) I have no video acceleration at all (I'm talking about SMPlayer, for example).
Thank you for your help!
Has anyone been able to successfully compile ffmpeg with x265 support for the Orange Pi on Armbian?
The instructions are excellent, but I can't get past buil-dep libav, mostly because I can't get libopencv-dev, libavcodec* and libavformat* to install because of missing and un-installable dependencies.
If anyone has managed it, could you please post the .deb file?
I'm just following the instructions, and have installed libav successfully. You have to make sure you have added the sources in your sources.list file, like so:
nano /etc/apt/sources.list
Uncomment all lines in this file, then save and try again installing...
Unfortunately I'm not having luck compiling it with the new OPI Zero... I'm gonna try on my side to find a solution and post a new thread specific to the OPI Zeron install... :)
