cvxx Posted October 7, 2018 Share Posted October 7, 2018 Hi, I have two OrangePi Lite running side by side. After working fine for about 8 months both started to experience same issue with wireless: Quote [ 20.283685] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 52.018851] ------------[ cut here ]------------ [ 52.019030] WARNING: CPU: 2 PID: 5 at net/wireless/sme.c:752 __cfg80211_connect_result+0x256/0x2c8 [cfg80211] [ 52.019033] Modules linked in: lz4 lz4_compress zram uvcvideo ir_lirc_codec snd_usb_audio snd_hwdep snd_usbmidi_lib videobuf2_vmalloc snd_rawmidi videobuf2_memops snd_seq_device lirc_dev videobuf2_v4l2 videobuf2_core evdev sunxi_cir sun8i_codec_analog sun4i_gpadc_iio snd_soc_hdmi_codec sun4i_i2s snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore w1_therm w1_gpio wire uio_pdrv_genirq uio sch_fq_codel g_serial libcomposite 8189fs cfg80211 rfkill ip_tables x_tables dw_hdmi_cec dw_hdmi_i2s_audio sun8i_dw_hdmi dw_hdmi cec sun4i_tcon sun8i_mixer sun4i_drm [ 52.019146] CPU: 2 PID: 5 Comm: kworker/u8:0 Not tainted 4.14.65-sunxi #12 [ 52.019149] Hardware name: Allwinner sun8i Family [ 52.019210] Workqueue: cfg80211 cfg80211_event_work [cfg80211] [ 52.019237] [<c010dacd>] (unwind_backtrace) from [<c010a0b5>] (show_stack+0x11/0x14) [ 52.019251] [<c010a0b5>] (show_stack) from [<c086b7fd>] (dump_stack+0x69/0x78) [ 52.019264] [<c086b7fd>] (dump_stack) from [<c011a1cf>] (__warn+0xaf/0xc0) [ 52.019273] [<c011a1cf>] (__warn) from [<c011a291>] (warn_slowpath_null+0x19/0x1c) [ 52.019332] [<c011a291>] (warn_slowpath_null) from [<bf89256b>] (__cfg80211_connect_result+0x256/0x2c8 [cfg80211]) [ 52.019442] [<bf89256b>] (__cfg80211_connect_result [cfg80211]) from [<bf8744fd>] (cfg80211_process_wdev_events+0xb4/0xe0 [cfg80211]) [ 52.019544] [<bf8744fd>] (cfg80211_process_wdev_events [cfg80211]) from [<bf87454f>] (cfg80211_process_rdev_events+0x26/0x50 [cfg80211]) [ 52.019645] [<bf87454f>] (cfg80211_process_rdev_events [cfg80211]) from [<bf8701d3>] (cfg80211_event_work+0x16/0x1c [cfg80211]) [ 52.019702] [<bf8701d3>] (cfg80211_event_work [cfg80211]) from [<c012d4d1>] (process_one_work+0x155/0x37c) [ 52.019711] [<c012d4d1>] (process_one_work) from [<c012e073>] (worker_thread+0xff/0x408) [ 52.019721] [<c012e073>] (worker_thread) from [<c0131b3d>] (kthread+0xfd/0x104) [ 52.019733] [<c0131b3d>] (kthread) from [<c01066f9>] (ret_from_fork+0x11/0x38) [ 52.019778] ---[ end trace b84df9c56982a79d ]--- [ 52.242651] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready The board works randomly for few hours or few days and then looses wireless connection. When this happens reboot does not help as then issue occurs immediately after the boot. Unplugging and replugging power source resolves that for a while and then happens again I suspect it may not be related to a hardware issue or wireless hotspot, as I have at least 3 other clients that continue to work fine. Searching for it on the internet brought this issue with Raspberry Pi: https://github.com/raspberrypi/linux/issues/1988. Raspberry uses different wireless chipset either. All that makes me think this may be an issue in the kernel itself Any ideas or thoughts? Workaround also appreciated Thanks Link to comment Share on other sites More sharing options...
WarHawk_AVG Posted October 10, 2018 Share Posted October 10, 2018 Perhaps the radio chip is getting too hot (too much reflected power) With it working then stopping, but an immediate reboot doesn't bring it back, but leave it off for a while (let it cool down) it works again... Are you using stock antenna? Link to comment Share on other sites More sharing options...
cvxx Posted October 22, 2018 Author Share Posted October 22, 2018 Yes, stock antenna Link to comment Share on other sites More sharing options...
cvxx Posted November 2, 2018 Author Share Posted November 2, 2018 One more update I found that reloading the kernel module helps to restore wireless interface: Quote sudo rmmod 8189fs sudo modprobe 8189fs Link to comment Share on other sites More sharing options...
cvxx Posted June 30, 2019 Author Share Posted June 30, 2019 I am successfully using this cron script every 1 minute to detect wifi failure and reload the module: #!/bin/bash status=`/sbin/ifconfig wlan0 | grep "inet 192"` if [ ! -z "$status" ]; then exit 0; fi echo "Detected wifi failure" dmesg | grep __cfg80211_connect_result | mail -s "Wifi failure" root@localhost sudo rmmod 8189fs sudo modprobe 8189fs sleep 3 nmcli connection up id mynetworkname HTH Link to comment Share on other sites More sharing options...
MSchubi Posted September 28, 2019 Share Posted September 28, 2019 Hello, I found a solution. In /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf set the power saving to "0" and reboot. 0 means "default"... best regards, Mike Link to comment Share on other sites More sharing options...
mikaey Posted April 1, 2020 Share Posted April 1, 2020 I'm having this same issue with the Orange Pi Zero Plus. Did anyone ever figure out what the issue was? Link to comment Share on other sites More sharing options...
Igor Posted April 1, 2020 Share Posted April 1, 2020 48 minutes ago, mikaey said: I'm having this same issue with the Orange Pi Zero Plus. Did anyone ever figure out what the issue was? I made some updates to related wireless drivers today. Build from sources and try if there is any better. Link to comment Share on other sites More sharing options...
mikaey Posted April 6, 2020 Share Posted April 6, 2020 Done. Seems to be working so far...thank you! Link to comment Share on other sites More sharing options...
