guidol Posted October 27, 2018 Posted October 27, 2018 https://github.com/MockbaTheBorg/RunCPM there is a nice little CP/M emulator which do compile fine under armbian. (There is also a version for the Arduino DUE with SD-Hat or a ESP32/Teensy) With that you can run many CP/M-Software like Wordstar, dBase II and so on Special on this emulation is that it do use directorys as drives The directory A (or A/0/) would be Drive A> Maybe you also want do something retro this weekend? Here is how I did compile/install it on my OPi One: compile RunCPM: =============== install ncurses-dev and lua: ============================ apt install libncurses5-dev liblua5.3-dev git make cd /home/guido/ git clone https://github.com/MockbaTheBorg/RunCPM RunCPM_git cd RunCPM_git/RunCPM make posix clean make posix build mkdir /home/guido/RunCPM mkdir /home/guido/RunCPM/A mkdir /home/guido/RunCPM/A/0 cp RunCPM /home/guido/RunCPM cp /home/guido/RunCPM_git/CCP/* /home/guido/RunCPM cp /home/guido/RunCPM_git/DISK/A.ZIP /home/guido/RunCPM/A/0 cd /home/guido/RunCPM/A/0 unzip A.ZIP cd /home/guido/RunCPM To start the Emulation: ======================= ./RunCPM To exit the emulation: ====================== a> exit 3
