Is your ethernet working fine?
"Important: Some devices suffer from a Gbit Ethernet issue related to the GbE PHY leading to a severe amount of packet losses which might render Ethernet unuseable. It’s confirmed as a hardware issue and if you’re affected or not can be simply checked by testing network throughput with iperf3. Against another GbE capable device, you should exceed 900 Mbits/sec with Armbian (only 800 Mbits/sec in RX direction when not using Xenial due to iperf3 being single-threaded in both directions then and bottlenecked by CPU). If you see low throughput and high retransmit counts then a workaround is to switch to Fast Ethernet only by adding ethtool -s eth0 speed 100 duplex full to /etc/rc.local"
It is. With recent kernel which in the development.
So is not a hardware issue, then?
Or maybe a work around was found.
Thanks.
40 minutes ago, margaspeak said:
If it is working fine then why are you selling it?
With stock images it is certainly not working good. Only with latest kernel, 4.19.y, A64 boards get decent support.
