where to get the missing kernel?
cuu
I just installed Armbian_5.65_Orangepione_Ubuntu_bionic_next_4.14.78.img on my orange pi one
but there is no linux-source of 4.14.78 via apt
so where to get the missing kernel ? or armbian's kernel is just the kernel from kernel.org?
thanks
If things are not in a repository (exactly this kernel is not), you need to use build engine and build it on your own.
Armbian kernel is "just" up to one year ahead from kernel.org and some features might never be there. You need to apply those patches: https://github.com/armbian/build/tree/master/patch/kernel/sunxi-next to the kernel.org 4.14.y + this config https://github.com/armbian/build/blob/master/config/kernel/linux-sunxi-next.config
wow,  thanks thanks @Igor   ,but unfortunately I could not download it because the GFW in china blocked google so badly
mega.nz is good here with vpn,still
armbian is great
I am starting to use armbian's build system ,too
Use all night to get all build stuff into vmware  now
the current linux-source-sunxi-next is 4.14.79 which is i think probably good for the orange pi one ,too, I am gonna test it
BTW:
I tested the linux-image-next-sunxi (4.14.70-sunxi) and linux-image-dev-sunxi(4.18.8-sunxi)  ,last night
Two of them both failed to start on orange pi one, Not sure if you guys ware of that
I plugged with HDMI ,Dell U2417h
the screen is like tear-drop, a lot of colorful lines everywhere
Though Orange PI One is an old board
You need to change u-boot as well when changing from old to new kernel.
where is the docs about this part?
right now it can boot ,but after tear-drop screen, it reboots..
ok
I did it with armbian's build system, use userspace kernel config
right now , kind of knowing armbian's build system
btw
How to add board into armbian system?
I would like see gameshell board in armbian ,armbian is the best linux I've ever seen in linux world
it would be great to see gameshell board in armbian
