Lucas0602 Posted November 7, 2018 Posted November 7, 2018 Hello. I bought a Rock64 and I have a lot of errors. Im using a eMMC 32GB Storage with Armbian 5.65 stretch 4.4.162 Desktop, Ethernet connection with TP-Link switch, a Wireless Keyboard with touch pad and the original 5V 3A Power Supply. HDMI is connect to a HDMI Splitter/Switch. The Rock64 is placed in the Aluminum casing. Full-Log: http://ix.io/1rce The system is reboot very often before i see the Desktop. Sometimes only after several resets. Can someone help me?
Igor Posted November 7, 2018 Posted November 7, 2018 On 11/7/2018 at 2:49 AM, Lucas0602 said: I bought a Rock64 and I have a lot of errors. Im using a eMMC 32GB Storage Expand Did you try to use SD card? It can be eMMC failure or bad eMMC support ... for this particular model. I can't reproduce this problem with my (16Gb) eMMC: http://ix.io/1rde
Lucas0602 Posted November 7, 2018 Author Posted November 7, 2018 On 11/7/2018 at 11:02 AM, Igor said: Did you try to use SD card? It can be eMMC failure or bad eMMC support ... for this particular model. I can't reproduce this problem with my (16Gb) eMMC: http://ix.io/1rde Expand Now i try with 32GB SD Card. The errors come again and he is stuck. I tried now only with HDMI and power. It works, no Errors and successfully boot but after a restart i have a black screen. I see no errors while reboot...
Lucas0602 Posted November 8, 2018 Author Posted November 8, 2018 Hey @Igor. I try a other OS to exclude a corrupted Hardware. eMMC doesn't work too but SD Card work (i used to test ayufan's stretch minimal). But i want use Armbian Stretch. What else can I try to make Armbian work with SD Card?
