Hi Igor. I think I found another inadvertenttant bug in the build since the desktop was unseparated out.
The new build is calling chromium instead of chromium-browser, and it's breaking.   It brings up a brief pink screen.  When you call it from a window it calls this image below.
Otherwise it is installing desktop on the H3 just fine.
11 minutes ago, DeterminedOpier said:
It was after I did that. I can do it again later.  There was no chromium-browser in the repositories btw.
First provide armbianmonitor -u since I have absolutely no idea which system, image and board (apparently orangepipc) you use.
Yes. I have many other problems and very little time. It can take a week or two.
It worked Igor thanks.  I'm not actually using the instance of the os beyond some basic testing of an idea and posted this for others having problems. If it is upstream hopefully it will fix itself.
