DeterminedOpier Posted November 7, 2018 Share Posted November 7, 2018 Hi Igor. I think I found another inadvertenttant bug in the build since the desktop was unseparated out. The new build is calling chromium instead of chromium-browser, and it's breaking. It brings up a brief pink screen. When you call it from a window it calls this image below. Otherwise it is installing desktop on the H3 just fine. Link to comment Share on other sites More sharing options...
Igor Posted November 7, 2018 Share Posted November 7, 2018 What about apt-update and upgrade and trying again? Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 7, 2018 Author Share Posted November 7, 2018 It was after I did that. I can do it again later. There was no chromium-browser in the repositories btw. Link to comment Share on other sites More sharing options...
Igor Posted November 7, 2018 Share Posted November 7, 2018 11 minutes ago, DeterminedOpier said: It was after I did that. I can do it again later. There was no chromium-browser in the repositories btw. First provide armbianmonitor -u since I have absolutely no idea which system, image and board (apparently orangepipc) you use. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 7, 2018 Author Share Posted November 7, 2018 Ok I'll send later. It's an opipc. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 7, 2018 Author Share Posted November 7, 2018 http://ix.io/1rgm Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 9, 2018 Author Share Posted November 9, 2018 Did you see I put this up Igor? Link to comment Share on other sites More sharing options...
Igor Posted November 9, 2018 Share Posted November 9, 2018 Yes. I have many other problems and very little time. It can take a week or two. Link to comment Share on other sites More sharing options...
Igor Posted November 9, 2018 Share Posted November 9, 2018 I will not look into this at all. It's broken upstream package. We don't support that. This one will probably work: https://apt.armbian.com/pool/main/c/chromium-browser/chromium_69.0.3497.93-1~deb9u1_armhf.deb Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 9, 2018 Author Share Posted November 9, 2018 Oh cool. thanks. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 9, 2018 Author Share Posted November 9, 2018 It worked Igor thanks. I'm not actually using the instance of the os beyond some basic testing of an idea and posted this for others having problems. If it is upstream hopefully it will fix itself. Link to comment Share on other sites More sharing options...
DeterminedOpier Posted November 9, 2018 Author Share Posted November 9, 2018 If someone wants to use this deb, you do: sudo apt-remove --purge chromium wget https://apt.armbian.com/pool/main/c/chromium-browser/chromium_69.0.3497.93-1~deb9u1_armhf.deb sudo dpkg -i chromium_69.0.3497.93-1~deb9u1_armhf.deb 1 Link to comment Share on other sites More sharing options...
