piotrek8614 Posted November 13, 2018 Posted November 13, 2018 Hi guys! This is my first post on Armbian forum so just want to say that I appreciate your work on Armbian. It's great! :) Couple days ago I've downloaded latest release of Armbian - Armbian_5.65_Orangepipc_Debian_stretch_next_4.14.78.7z After successful start on OPi PC board I have installed minimal desktop. I've created Wi-Fi network (using network manager) so my OPi PC board can act like a Access Point, and this works fine. Wi-Fi network is visible on other devices and they can connect to it. The problem is that there is no DHCP server working on OPi. This mean that any of devices which connects to the OPi's network can't obtain it's IP. Before new Armbian release I used legacy Armbian based on 3.something kernel on which it worked flawlessly. Could you give me a hint on this?
Igor Posted November 13, 2018 Posted November 13, 2018 Check what is dnsmasq service telling you service dnsmasq status and what is the content of /etc/dnsmasq.conf I tried to recreate, made few restarts and AP is working fine, clients gets IP.
piotrek8614 Posted November 14, 2018 Author Posted November 14, 2018 Thanks Igor, I'll check it today when I'm at home.
piotrek8614 Posted November 20, 2018 Author Posted November 20, 2018 Ok, I've checked it. It looks like I don't have dnsmasq service installed. Command "root@orangepipc:/home/user# service dnsmasq status Unit dnsmasq.service could not be found. service dnsmasq status" returns
piotrek8614 Posted November 20, 2018 Author Posted November 20, 2018 Ok, right now I have dnsmasq installed but don't have correct config. Should network manager automatically modify dnsmasq.conf ?
Igor Posted November 20, 2018 Posted November 20, 2018 3 hours ago, piotrek8614 said: Should network manager automatically modify dnsmasq.conf ? I overlooked and I though you have used our tool to make AP: For the way you want to make it, I never tried and I think you should look into the manual if exists. It's a generic problem unrelated to Armbian.
piotrek8614 Posted November 21, 2018 Author Posted November 21, 2018 Quote I overlooked and I though you have used our tool to make AP What do you mean by this? Do you mean I have used this tool to make my current hot spot or I should use this tool to make a hot spot?
