Bricked my 2g Espressobin, cannot seem to recover via SATA or UART...
Hi -
I ordered a 2gb Espressobin from Globalscale and later flashed flash-image-2g-2cs-1200_750.bin, which caused my Espressobin to hang at:
TIM-1.0
WTMI-devel-18.07.0-6050fd5
WTMI: system early-init
SVC REV: 5, CPU VDD voltage: 0.898V
I am able to boot to SATA using the sata recovery image, but cannot flash back to the working flash-image-2g-2cs-1000_800.bin. Here is what happens when I boot to SATA and attempt to flash the old bin:
Booting Trusted Firmware
BL1: v1.2(release):armada-17.02.0:v0.2-1324-g1cd562c
BL1: Built : 16:29:17, Apr 20 2NOTICE:  BL2: v1.2(release):armada-17.02.0:v0.2-1324-g1cd562c
NOTICE:  BL2: Built : 16:29:17, Apr 20 20NOTICE:  BL31: v1.2(release):armada-17.02.0:v0.2-1324-g1cd562c
NOTICE:  BL31:
U-Boot 2015.01-armada-17.02.0-01546-g184fa4e (Apr 20 2017 - 16:21:34)
I2C:   ready
DRAM:  512 MiB
Board: DB-88F3720-ESPRESSOBin
       CPU    @ 1000 [MHz]
       L2     @ 800 [MHz]
       TClock @ 200 [MHz]
       DDR    @ 800 [MHz]
Comphy-0: PEX0          2.5 Gbps
Comphy-1: USB3          5 Gbps
Comphy-2: SATA0         5 Gbps
Now running in RAM - U-Boot at: 1ff2b000
U-Boot DT blob at : 000000001fa18168
MMC:   XENON-SDHCI: 0
SF: Unsupported flash IDs: manuf c2, jedec 2536, ext_jedec c225
*** Warning - spi_flash_probe() failed, using default environment
PCIE-0: Link down
SCSI:  Target spinup took 0 ms.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
Net:   neta0
Hit any key to stop autoboot:  0
Marvell>> bubt flash-image-2g-1000_800_boot_sd_and_usb.bin spi usb
Burning U-BOOT image "flash-image-2g-1000_800_boot_sd_and_usb.bin" from "usb" to "spi"
USB0:   Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
reading flash-image-2g-1000_800_boot_sd_and_usb.bin
Image checksum...OK!
Failed to probe SPI Flash
I initially attempted a UART flash, but I get a similar error, but with a different SF message:
SF: unrecognized jedec id bytes: c2, 25, 36
I read through a few posts, tried things like flashing via tftp instead of USB, but to no avail. Can anyone help?
This looks like you are using (recovery) images that haven't been patched for supporting the Macronix flash chips.
Did you check this thread?
So just got around to reading through that post and I gave it a go, using @FoodGenius's guide, however I am not able to write to the SPI after booting into the mini OS. I am now getting this error:
/ # ls /mnt/a
/ # ls /mnt
a
/ # mount /dev/sda1 /mnt/a
[  101.293731] EXT4-fs (sda1): recovery complete
[  101.304031] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
/ # cd /mnt/a
/mnt/a # ls
Image                        lost+found
armada-3720-espressobin.dtb  mtd0.img
/mnt/a # dd if=mtd0.img of=/dev/mtd0
dd: can't open '/dev/mtd0': No such device
/mnt/a # ls -l /dev/
total 0
crw--w--w-    1 1000     0           5,   1 Jan  1 00:02 console
crw-r--r--    1 0        0          90,   0 Nov 21  2018 mtd0
crw-r--r--    1 0        0          90,   2 Nov 21  2018 mtd1
mtd0 definitely exists as you can see from the ls output, but I am not able to write to it. I don't know if the guide he followed was specific to his Espressobin and I need to modify the mini OS he built or its something else. I feel so close, its too bad that they don't have a recovery image that supports Macronix flash chips!
@martinayotte - Just gave it a try, again its staying "No such device":
/mnt/a # ls
Image                        lost+found
/mnt/a # flashcp -v ./mtd0.img /dev/mtd0
While trying to open /dev/mtd0 for read/write access: No such device
ls -la shows:
/mnt/a # ls -la /dev/
total 0
drwxr-xr-x    3 1000     0              480 Jan  1 00:00 .
drwxrwxrwt   11 0        0              280 Jan  1 00:00 ..
drwxr-xr-x    2 0        0               40 Jan  1 00:00 .mount
crw--w--w-    1 1000     0           5,   1 Jan  1 00:04 console
crw-r--r--    1 0        0          90,   4 Nov 21  2018 mtd2
crw-r--r--    1 0        0          90,   6 Nov 21  2018 mtd3
crw-r--r--    1 0        0          90,   8 Nov 21  2018 mtd4
crw-r--r--    1 0        0          90,  10 Nov 21  2018 mtd5
brw-r--r--    1 0        0          31,   0 Nov 21  2018 mtdblock0
brw-r--r--    1 0        0          31,   1 Nov 21  2018 mtdblock1
brw-r--r--    1 0        0          31,   2 Nov 21  2018 mtdblock2
brw-r--r--    1 0        0          31,   3 Nov 21  2018 mtdblock3
brw-r--r--    1 0        0          31,   4 Nov 21  2018 mtdblock4
brw-r--r--    1 0        0          31,   5 Nov 21  2018 mtdblock5
crw-rw-rw-    1 1000     0           1,   3 Nov 21  2018 null
crw-rw-rw-    1 1000     0           5,   2 Nov 21  2018 ptmx
cr--r--r--    1 1000     0           1,   8 Nov 21  2018 random
brw-r--r--    1 0        0           8,   0 Jan  1 00:00 sda
brw-r--r--    1 0        0           8,   1 Jan  1 00:00 sda1
crw-rw-rw-    1 1000     0           5,   0 Nov 21  2018 tty
cr--r--r--    1 1000     0           1,   9 Nov 21  2018 urandom
crw-rw-rw-    1 1000     0           1,   5 Nov 21  2018 zero
I'm pretty new to working with flash, so I'll apologize in advance if I am overlooking something stupid
  On 11/23/2018 at 4:16 PM, pete11235 said:
I don't see that message in dmesg, heres the output from dmesg:
Expand
Your log still shows the following :
[    5.088391] m25p80 spi0.0: unrecognized JEDEC id bytes: c2, 25, 36
[    5.094727] m25p80: probe of spi0.0 failed with error -2
Oh I completely missed that! That's odd, I just confirmed that it is a Macronix chip, in fact the exact one they talk about in the referenced thread above (mx25u3235f - attached picture of it). I don't understand what I am doing wrong...
