pete11235 Posted November 26, 2018 Posted November 26, 2018 Hello! recently purchased the 2g espressobin and am not understanding why I cannot obtain gigabit speeds from lan to wan. I am able to do so from the OS out/in, but from a client machine to a machine attached to the wan I am getting 1/3 the speed of gigabit. Below is the iperf results along with my systemd/network settings. Does anyone have an idea why this is occurring? Client to machine in Ethernet attached to wan: Connecting to host 192.168.2.1, port 5001 [ 4] local 192.168.22.209 port 5859 connected to 192.168.2.1 port 5001 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 36.6 MBytes 307 Mbits/sec [ 4] 1.00-2.00 sec 42.4 MBytes 355 Mbits/sec [ 4] 2.00-3.00 sec 42.1 MBytes 354 Mbits/sec [ 4] 3.00-4.00 sec 42.0 MBytes 352 Mbits/sec [ 4] 4.00-5.00 sec 42.2 MBytes 355 Mbits/sec [ 4] 5.00-6.00 sec 42.4 MBytes 355 Mbits/sec [ 4] 6.00-7.00 sec 42.0 MBytes 353 Mbits/sec [ 4] 7.00-8.00 sec 42.5 MBytes 357 Mbits/sec [ 4] 8.00-9.00 sec 42.5 MBytes 356 Mbits/sec [ 4] 9.00-10.00 sec 42.0 MBytes 353 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth [ 4] 0.00-10.00 sec 417 MBytes 350 Mbits/sec sender [ 4] 0.00-10.00 sec 417 MBytes 349 Mbits/sec receiver iperf Done. From espressobin OS to wan connected machine: root@espressobin:~# iperf3 -c 192.168.2.1 -p 5001 Connecting to host 192.168.2.1, port 5001 [ 4] local 192.168.2.76 port 44154 connected to 192.168.2.1 port 5001 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 105 MBytes 879 Mbits/sec 0 708 KBytes [ 4] 1.00-2.00 sec 112 MBytes 938 Mbits/sec 0 708 KBytes [ 4] 2.00-3.00 sec 111 MBytes 934 Mbits/sec 0 708 KBytes [ 4] 3.00-4.00 sec 112 MBytes 939 Mbits/sec 0 708 KBytes [ 4] 4.00-5.00 sec 111 MBytes 933 Mbits/sec 0 708 KBytes [ 4] 5.00-6.00 sec 112 MBytes 939 Mbits/sec 0 708 KBytes [ 4] 6.00-7.00 sec 111 MBytes 934 Mbits/sec 0 708 KBytes [ 4] 7.00-8.00 sec 112 MBytes 939 Mbits/sec 0 708 KBytes [ 4] 8.00-9.00 sec 111 MBytes 933 Mbits/sec 0 708 KBytes [ 4] 9.00-10.00 sec 112 MBytes 939 Mbits/sec 0 708 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.08 GBytes 931 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.08 GBytes 931 Mbits/sec receiver systemd/network config: root@espressobin:~# cat /etc/systemd/network/* /etc/systemd/network/10-br0.netdev: [NetDev] Name=br0 Kind=bridge /etc/systemd/network/10-br0.network: [Match] Name=br0 [Network] Address=192.168.22.1/24 IPForward=ipv4 IPMasquerade=yes ConfigureWithoutCarrier=yes /etc/systemd/network/10-eth0.network: [Match] Name=eth0 [Network] DHCP=ipv4 /etc/systemd/network/10-lan0.network: [Match] Name=lan0 [Network] Bridge=br0 /etc/systemd/network/10-lan1.network: [Match] Name=lan1 [Network] Bridge=br0 /etc/systemd/network/10-wan.network: [Match] Name=wan [Network] DHCP=yes BindCarrier=eth0 IPForward=ipv4 root@espressobin:~# Linux espressobin 4.18.16-mvebu64 #402 SMP PREEMPT Fri Oct 26 17:23:18 CEST 2018 aarch64 GNU/Linux
ebin-dev Posted November 27, 2018 Posted November 27, 2018 14 hours ago, pete11235 said: IPMasquerade=yes You don`t use the default network configuration. Masquerading is expensive and reduces bandwidth. You could try to redistribute tasks among CPU cores and to offload networking as far as possible.
pete11235 Posted November 27, 2018 Author Posted November 27, 2018 @ebin-dev thanks for getting back to me! I removed it and re-ran the test. Results did not change. I thought this setup was pretty basic, however I understand where you are going with this, to pull as much off the CPU as possible. To make sure it wasnt anything I did, before making this post, I used a new SD card and did a fresh install, ensuring only to install dnsmasq. So this is basically a fresh install. I have attached the output of "ps aux": https://pastebin.com/6tRccgN9
pete11235 Posted November 27, 2018 Author Posted November 27, 2018 Also there is nearly no load when the espressobin is not being stressed. I have attached a screenshot to show that not many things are running. I cant imagine, based on what is running, that a basic network setup would consume enough resources to degrade from gigabit
ebin-dev Posted November 30, 2018 Posted November 30, 2018 On 11/27/2018 at 4:56 PM, pete11235 said: Also there is nearly no load when the espressobin is not being stressed. You need to have a look at the distribution of tasks while the EspressoBin is being stressed. Do you use the latest bootloader flash-image? If you do not use a 1000_800 image you need to adapt the settings of /etc/default/cpufrequtils to available values output by 'cpufreq-info'. Otherwise the ondemand governor does not ramp up correctly. Such an issue was described some time ago here.
pete11235 Posted November 30, 2018 Author Posted November 30, 2018 Mine came set with the max at 1000000 and would reach 1000MHz during load. I increased the default min from 250000 to 500000 as it was recommended in the link you provided me. No change, even after reboot and I have confirmed they are operating at their set default speeds: root@espressobin:~# cat /etc/default/cpufrequtils # WARNING: this file will be replaced on board support package (linux-root-...) upgrade ENABLE=true MIN_SPEED=500000 MAX_SPEED=1000000 GOVERNOR=ondemand root@espressobin:~# See attached screenshot. It will operate at 1000MHz the entire time the load is applied. In the attached screenshot, I hit CTRL-C half way through to show you that when it has no load, it drops back to 500MHz
pete11235 Posted November 30, 2018 Author Posted November 30, 2018 Also to add on to this, on a separate SD card, I installed Archlinux to rule out the OS, and I had the same issue on Arch, see my other post here:https://espressobin.net/forums/topic/espressobin-not-getting-gigabit-speeds-lan-to-wan/ So I think it may possibly be something in U-Boot? I am not sure, completely guessing here Also edit - U-Boot version: U-Boot 2017.03-armada-18.09.1-ga92bd86-armbian (Sep 05 2018 - 21:49:34 +0200)
chrisf Posted December 11, 2018 Posted December 11, 2018 To me that load log says one core is maxed out due to IRQ activity. You've got a single core doing all the network stuff and it can't handle any more load. Do you need IP masquerading? Is it possible to distribute network IRQ handling to both cores? If you can that may increase bandwidth, but may also slightly increase latency?
pete11235 Posted December 11, 2018 Author Posted December 11, 2018 I've attempted to play around with the IRQ in order to get both CPU's active, but with no avail, take a looks below: root@espressobin:~# cat /proc/irq/11/smp_affinity_list 0-1 root@espressobin:~# cat /proc/irq/11/smp_affinity 3 root@espressobin:~# And this is when I put a load on the network: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 9 root 20 0 0 0 0 R 89.4 0.0 0:31.32 ksoftirqd/0 1738 root 20 0 8028 3376 2828 R 0.7 0.2 0:00.11 top 18 root 20 0 0 0 0 I 0.3 0.0 0:00.31 kworker/1:+ 25 root 20 0 0 0 0 I 0.3 0.0 0:00.02 kworker/0:+ 1 root 20 0 10408 6664 4820 S 0.0 0.3 0:03.44 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp 5 root 20 0 0 0 0 I 0.0 0.0 0:00.08 kworker/0:+ 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:+ 7 root 20 0 0 0 0 I 0.0 0.0 0:00.79 kworker/u4+ 8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_+ 10 root 20 0 0 0 0 I 0.0 0.0 0:00.27 rcu_preempt 11 root 20 0 0 0 0 I 0.0 0.0 0:00.12 rcu_sched 12 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_bh 13 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/0 14 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 Am I looking in the wrong area?
chrisf Posted December 12, 2018 Posted December 12, 2018 Have you tried looking at /proc/interrupts to see which cores are actually handling the interrupts?
pete11235 Posted December 12, 2018 Author Posted December 12, 2018 I looked, but I am not sure, but I can see clearly something looks to be happening on both CPUs (7 & 8? - #11): root@espressobin:~# cat /proc/interrupts CPU0 CPU1 1: 0 0 GICv3 25 Level vgic 3: 20398 34130 GICv3 30 Level arch_timer 4: 0 0 GICv3 27 Level kvm guest timer 6: 0 0 GICv3 23 Level arm-pmu 7: 0 0 GICv3 32 Level d0010600.spi 9: 22472 0 GICv3 44 Level d0012000.serial 10: 125 0 GICv3 45 Level d0012000.serial 11: 8 7 GICv3 74 Level eth0 12: 0 0 GICv3 35 Level xhci-hcd:usb2 13: 0 0 GICv3 49 Level ehci_hcd:usb1 20: 8574 0 GICv3 57 Level mmc1 21: 52 0 GICv3 58 Level mmc0 22: 0 0 GICv3 59 Level ahci-mvebu[d00e0000.sata] 23: 0 0 GICv3 61 Level advk-pcie 41: 2 0 GICv3 79 Level d0060900.xor 42: 2 0 GICv3 80 Level d0060900.xor 43: 0 0 GPIO1 3 Edge d00d0000.sdhci cd 47: 0 0 mv88e6xxx-g1 3 Edge mv88e6xxx-g1-atu-prob 49: 0 0 mv88e6xxx-g1 5 Edge mv88e6xxx-g1-vtu-prob 51: 0 0 mv88e6xxx-g1 7 Edge mv88e6xxx-g2 54: 0 0 mv88e6xxx-g2 1 Edge !soc!internal-regs@d0000000!mdio@32004!switch0@1!mdio:11 55: 0 0 mv88e6xxx-g2 2 Edge !soc!internal-regs@d0000000!mdio@32004!switch0@1!mdio:12 56: 0 0 mv88e6xxx-g2 3 Edge !soc!internal-regs@d0000000!mdio@32004!switch0@1!mdio:13 68: 0 0 mv88e6xxx-g2 15 Edge mv88e6xxx-watchdog IPI0: 3966 6990 Rescheduling interrupts IPI1: 119 525 Function call interrupts IPI2: 0 0 CPU stop interrupts IPI3: 0 0 CPU stop (for crash dump) interrupts IPI4: 0 0 Timer broadcast interrupts IPI5: 872 646 IRQ work interrupts IPI6: 0 0 CPU wake-up interrupts Err: 0 root@espressobin:~# I was under the assumption that smp_affinity_list would handle the CPU's, but I usually don't have to dive this deep into issues... EDIT: This was not under load
