Kwan Xian Posted December 4, 2018 Posted December 4, 2018 Hello guys! I'm beginner of Armbian. The problem is: Install Armbian Stretch mainline kernel 4.14.y on my device(Orange_Pi_PC),But I don't know how to enable UART1 . I tried to select UART1 & UART2 & UART3 on armbian-config,now i can see 'overlays=uart1 uart2 uart3' in /boot/armbianEnv.txt Connect serial device with P40(RX) P39(GND) P38(TX) . when i check serial device on ssh, i can see this info: uname -a Linux orangepipc 4.14.84-sunxi #3 SMP Sat Dec 1 07:18:41 CET 2018 armv7l GNU/Linux ls -l /dev/ttyS* crw--w---- 1 root tty 4, 64 Dec 4 20:24 /dev/ttyS0 crw-rw---- 1 root dialout 4, 65 Dec 4 20:36 /dev/ttyS1 crw-rw---- 1 root dialout 4, 66 Dec 4 21:08 /dev/ttyS2 crw-rw---- 1 root dialout 4, 67 Dec 4 20:33 /dev/ttyS3 crw-rw---- 1 root dialout 4, 68 Dec 4 20:24 /dev/ttyS4 crw-rw---- 1 root dialout 4, 69 Dec 4 20:24 /dev/ttyS5 crw-rw---- 1 root dialout 4, 70 Dec 4 20:24 /dev/ttyS6 crw-rw---- 1 root dialout 4, 71 Dec 4 20:24 /dev/ttyS7 dmesg | grep tty [ 0.000000] Kernel command line: root=UUID=3d863bb3-b616-4229-94e7-8c92ac95501a rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=c0dd9a77-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 0.000198] console [tty1] enabled [ 1.796248] console [ttyS0] disabled [ 1.816398] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 42, base_baud = 1500000) is a U6_16550A [ 1.816450] console [ttyS0] enabled [ 1.839525] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 43, base_baud = 1500000) is a U6_16550A [ 1.862474] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 44, base_baud = 1500000) is a U6_16550A [ 1.885408] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 45, base_baud = 1500000) is a U6_16550A [ 4.746240] systemd[1]: Created slice system-getty.slice. setserial -g /dev/ttyS* /dev/ttyS0: Permission denied /dev/ttyS1, UART: undefined, Port: 0x0000, IRQ: 43 /dev/ttyS2, UART: undefined, Port: 0x0000, IRQ: 44 /dev/ttyS3, UART: undefined, Port: 0x0000, IRQ: 45 /dev/ttyS4, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS5, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS6, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS7, UART: unknown, Port: 0x0000, IRQ: 0 When I saw this doc: https://docs.armbian.com/Hardware_Allwinner/ but there is no bin file in /boot: ls /boot armbianEnv.txt boot.scr initrd.img-4.14.84-sunxi vmlinuz-4.14.84-sunxi armbian_first_run.txt.template config-4.14.84-sunxi overlay-user zImage boot.bmp dtb System.map-4.14.84-sunxi boot.cmd dtb-4.14.84-sunxi uInitrd boot-desktop.png dtb.old uInitrd-4.14.84-sunxi I tried to use UART1 with Python3: #!/usr/bin/python #-*-coding:utf-8-*- import serial my_printer = serial.Serial('/dev/ttyS1',9600,timeout=1) if my_printer.isOpen(): pass else: my_printer.open() my_printer.write(b'\x1b\x40\x12\x54') but it doesn't work. BTW: serial device can work on Windows.
martinayotte Posted December 4, 2018 Posted December 4, 2018 1 hour ago, Kwan Xian said: [ 1.839525] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 43, base_baud = 1500000) is a U6_16550A [ 1.862474] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 44, base_baud = 1500000) is a U6_16550A [ 1.885408] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 45, base_baud = 1500000) is a U6_16550A It seems that overlays did their job ... Are you sure of your wiring ? Maybe you can check by doing a loopback wire between pins 38/40 and do "picocom -b 9600 /dev/ttyS1", then every thing you type will be echoed back.
Kwan Xian Posted December 4, 2018 Author Posted December 4, 2018 47 minutes ago, martinayotte said: It seems that overlays did their job ... Are you sure of your wiring ? Maybe you can check by doing a loopback wire between pins 38/40 and do "picocom -b 9600 /dev/ttyS1", then every thing you type will be echoed back. Thank you! It works. I need to check my code between windows & Linux.
Kwan Xian Posted December 4, 2018 Author Posted December 4, 2018 50 minutes ago, martinayotte said: It seems that overlays did their job ... Are you sure of your wiring ? Maybe you can check by doing a loopback wire between pins 38/40 and do "picocom -b 9600 /dev/ttyS1", then every thing you type will be echoed back. Is't the same way to enable SPI0?
martinayotte Posted December 4, 2018 Posted December 4, 2018 4 minutes ago, Kwan Xian said: Is't the same way to enable SPI0? A bit, yes ! look at the overlay doc : ### spi-spidev Activates SPIdev device node (/dev/spidevX.Y) for userspace SPI access, where X is the bus number and Y is the CS number SPI 0 pins (MOSI, MISO, SCK, CS): PC0, PC1, PC2, PC3 SPI 1 pins (MOSI, MISO, SCK, CS): PA15, PA16, PA14, PA13 Parameters: param_spidev_spi_bus (int) SPI bus to activate SPIdev support on Required Supported values: 0, 1 param_spidev_spi_cs (int) SPI chip select number Optional Default: 0 Supported values: 0, 1 Using chip select 1 requires using "spi-add-cs1" overlay param_spidev_max_freq (int) Maximum SPIdev frequency Optional Default: 1000000 Range: 3000 - 100000000
Kwan Xian Posted December 4, 2018 Author Posted December 4, 2018 4 minutes ago, martinayotte said: A bit, yes ! look at the overlay doc : ### spi-spidev Activates SPIdev device node (/dev/spidevX.Y) for userspace SPI access, where X is the bus number and Y is the CS number SPI 0 pins (MOSI, MISO, SCK, CS): PC0, PC1, PC2, PC3 SPI 1 pins (MOSI, MISO, SCK, CS): PA15, PA16, PA14, PA13 Parameters: param_spidev_spi_bus (int) SPI bus to activate SPIdev support on Required Supported values: 0, 1 param_spidev_spi_cs (int) SPI chip select number Optional Default: 0 Supported values: 0, 1 Using chip select 1 requires using "spi-add-cs1" overlay param_spidev_max_freq (int) Maximum SPIdev frequency Optional Default: 1000000 Range: 3000 - 100000000 Thank you sooooo much! That's verrrrrry help for me.
