after unsuccessful experiences with bananian I found armbian - due to the active forum and answers to questions it looks like the better choice.
I try to install fhem on bpr-r1. Combine a access point with homeautomation server (the router ifunction is handled by another device).
After some work with Debian Jessie (lot´s of issues with hostapd and gpio) - Ubuntu with 4.4.1 kernel works stable.
Only issue which keeps me from going into operation is following problem:
all directories /sys/devices/platform/gpio-sunxi/gpio/gpio* are recreated everytime fhem server starts.
The trick from Raspbian with chown -R root:gpio ys/devices/platform/gpio-sunxi/gpio/gpio* is not working, due to recreation.
The effect is, that attributes like "active_low" are not working, behaus fhem cannot modify them because of missing access rights. Running fhem as root is not an option.
I know for sure, this is not a fhem problem. Some device definition is working fine on 2 RaspberryPis.
Where is the place I can tell the system do recreate gpio-subdirectories with user:group = root:gpio as well as 775 as access rights?
Greetings
Harald
Why shouldn't that work if you put the line in /etc/rc.local so that it gets executed on every reboot?
BTW: Before you start wasting time trying to use the R1 as access point better search the forums before to get an idea what a waste of time and ressources this will be (in other words: it doesn't work as advertised and you better forget about it or replace the hardware)
Thanks tkaiser for the advice.
The AP is just a nice to have feature  and I will not waste more time on it. I already bought a USB Wifi stick as replacement.
Before writing in this forum I added "chmod and chown" commands into /etc/init.d/fhem before starting fhem - no help.
Just now I did a test again:
Log file of fhem:
016.03.26 13:22:00 1: OG.fz.RS.tuer_mot: entfernt
2016.03.26 13:22:00 1: OG.fz.RS.tuer_dir: entfernt
2016.03.26 13:22:00 1: Including fhem.cfg
2016.03.26 13:22:00 1: Including myGlobals.inc
2016.03.26 13:22:01 3: telnetPort: port 7072 opened
2016.03.26 13:22:01 3: WEB: port 8083 opened
2016.03.26 13:22:01 3: WEBphone: port 8084 opened
2016.03.26 13:22:01 3: WEBtablet: port 8085 opened
2016.03.26 13:22:01 2: eventTypes: loaded 56 events from ./log/eventTypes.txt
2016.03.26 13:22:01 1: Including /opt/fhem/haus.inc
2016.03.26 13:22:01 1: Including /opt/fhem/og.inc
/usr/local/bin/gpio: Warning: File not present: /sys/class/gpio/gpio4/edge
2016.03.26 13:22:01 1: Can't open file: OG.fz.RS.tuer_dir, active_low
2016.03.26 13:22:01 1: Can't open file: OG.fz.RS.tuer_mot, active_low
2016.03.26 13:22:01 1: Including /opt/fhem/myEvents.inc
2016.03.26 13:22:01 1: Including ./log/fhem.save
root@lamobo-r1:/opt/fhem# ll /sys/devices/platform/gpio-sunxi/gpio/
total 0
drwxrwxr-x 18 root gpio 0 Mar 26 13:22 ./
drwxr-xr-x  4 root gpio 0 Mar 26 06:58 ../
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio10/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio11/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio14/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio15/
drwxr-xr-x  3 root root 0 Mar 26 13:22 gpio17/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio18/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio22/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio23/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio24/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio25/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio27/
drwxr-xr-x  3 root root 0 Mar 26 13:22 gpio4/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio7/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio8/
drwxr-xr-x  3 root gpio 0 Mar 26 13:21 gpio9/
drwxrwxr-x  3 root gpio 0 Mar 26 06:58 gpiochip1/
root@lamobo-r1:/opt/fhem# gd !$
gd /sys/devices/platform/gpio-sunxi/gpio/
/sys/devices/platform/gpio-sunxi/gpio /opt/fhem ~
root@lamobo-r1:/sys/devices/platform/gpio-sunxi/gpio# ll gpio4
total 0
drwxr-xr-x  3 root root       0 Mar 26 13:22 ./
drwxrwxr-x 18 root gpio       0 Mar 26 13:22 ../
-rw-r--r--  1 root root    4096 Mar 26 13:22 active_low
lrwxrwxrwx  1 root root       0 Mar 26 13:23 device -> ../../../gpio-sunxi/
-rw-r--r--  1 root root    4096 Mar 26 13:22 direction
drwxr-xr-x  2 root root       0 Mar 26 13:23 power/
lrwxrwxrwx  1 root root       0 Mar 26 13:23 subsystem -> ../../../../../class/gpio/
-rw-r--r--  1 root root    4096 Mar 26 13:22 uevent
-rw-r--r--  1 fhem dialout 4096 Mar 26 13:22 value
GPIO pin 4 and 7 have been recreted by the start of fhem.
/usr/local/bin/gpio is right in place.
So I came to conclusion there are 2 ways
a) change file rights during creation   --> ask the forum
B) modify the fhem module RPB_GIO --> searching ins ongoing
Greetings
Harry99n
