Evgeny Dmitrichenko Posted December 5, 2018 Posted December 5, 2018 Hello I use compile.sh and customize-image.sh to make my own custom image and every think is all right and work great. This is my command line to compile: sudo ./compile.sh KERNEL_CONFIGURE="no" KERNEL_ONLY="no" BOARD="orangepipc2" BRANCH="next" RELEASE="xenial" BUILD_DESKTOP="yes" After burned my image and lounch Armbian I have to do two steps: 1) go to armbian config and set taggle hardware config "i2c0" option to "true" (like on picture 1.png) 2) go to armbian config and set time zone = Europe/Moscow I tried to set KERNEL_CONFIGURE="yes" and try to find this options in configmenu = I did not find I tried to add option TZDATA="Europe/Moscow" to command line = dose not work What can I do to do this steps automaticaly in compile.sh or customize-image.sh?
Igor Posted December 5, 2018 Posted December 5, 2018 40 minutes ago, Evgeny Dmitrichenko said: go to armbian config and set taggle hardware config "i2c0" option to "true" (like on picture 1.png) Observe the difference in the /boot/armbianEnv.txt That you need to change in the build time if you want to have an image ready with those things applied. 40 minutes ago, Evgeny Dmitrichenko said: go to armbian config and set time zone = Europe/Moscow Use Google and search hot to set time zone in a script for Debian or Ubuntu. Xenial in your case as I can see. This is not an question for Armbian. 41 minutes ago, Evgeny Dmitrichenko said: KERNEL_CONFIGURE="yes" and try to find this options in configmenu Those are kernel features. Timezone is userspace feature which must be set with "customzite-image.sh" script.
