October 25, 20233 yr "I'm new to using Linux on embedded systems and I've been trying to follow various examples in the forum to enable I2S, but I haven't had satisfactory results. I attempted to perform the steps described, enabling the PCM5102, but when I run 'arecord', I get the following error: 'arecord: main:830: audio open error: No such file or directory'. I'm running Armbian 23.8.1 with Linux Kernel 5.10.4 on a Banana Pi M2 Zero. I have a PCM1807, which I configure through SPI to send I2S data to GPIO PA20 on the BPI. After successfully capturing the audio, I would like to send it via I2S through GPIO PA21 to another stage. Could someone please guide me on how to configure these ports and the ADC?"
September 22, 20242 yr This starts to mess up on me when I try and install it. When I get to this command: dtc -I dts -O dtb /boot/dtb/sun8i-h3-nanopi-neo.dts -o /boot/dtb/sun8i-h3-nanopi-neo.dtb_I2S_okay It list lost of Warning (gpios_property) Don't want to paste all the lines in here so I will just do one. /boot/dtb/sun8i-h3-nanopi-neo.dts:1608.3-33: Warning (gpios_property): /gpio-regulator:gpios: cell 0 is not a phandle reference That's the last line out of like 100 or so. So I try and do the next command it just get this: root@nanopineo:~# copy sun8i-h3-I2S-out.dts --> /home/guido/ -bash: /home/guido/: Is a directory root@nanopineo:~# ls root@nanopineo:~# Here is a uname -a if that will help: root@nanopineo:~# uname -a Linux nanopineo 6.6.44-current-sunxi #1 SMP Sat Aug 3 06:54:42 UTC 2024 armv7l armv7l armv7l GNU/Linux root@nanopineo:~# I want to get this sound working. I had it working on a older one but it stop booting and that was over a year ago. To hard to fix so I though I start over. Hope some one can help.
