Hi All,
My first topic here, I own a Banana Pi M1 and I have just switched from bananian.
Everything looks great in armbian and most of the things are just working, I just miss zsh from bananian but that was easy to fix.
However I use my server for backups using ecryptfs (so I can encrypt/decrypt folders on demand) and I'm unable to mount any ecryptfs directory.
My configuration: Banana PI M1 running Debian Wheezy mainline kernel 4.4.3 (just installed)
Things I've done:
Install ecryptfs-utils (installs ok and tools are available)
Try to mount a ecryptfs directory: I get the message "unknown filesystem type ecryptfs"
Try to load as a module (just in case): modprobe ecryptfs = FATAL, module ecryptfs not found
cat /boot/config-4.4.3-sunxi I can't find anything related to ecryptfs
Also had a look at /proc/filesystems and ecryptfs is not there (should be automatically supported by kernel)
lsmod reports sun4i_ss and fuse loaded (I thought it could be a problem related to sun4i_ss -security system cryptographic accelerator- I've read in the forums that ss is buggy)
Any ideas? Anybody using ecryptfs?
Thank you!
I was driving crazy looking for that.
Totally agree with blacklisting SS, specially when the maintainer is still looking for the cause behind data corruption
Just quick comment here: I am with latest armbian (5.23) and sun4i_ss seems to work correctly (seems, I need futher testing). So problems with encryption (ecryptfs, ssh, etc) should be gone
