If someone is interested I found the way to have BT working on orange pi Prime.
Unfortunately default kernel config is missing the following options and need to be manually recompiled:
CONFIG_SERIAL_DEV_BUS=m
CONFIG_BT_HCIUART_SERDEV=y
CONFIG_BT_HCIUART_3WIRE=y
With these changes and adding "uart1" to the overlays in armbianEnv.txt  it's possible to use the driver in:
https://github.com/lwfinger/rtl8723bs_bt.git
and start manually with:
./rtk_hciattach -n -s 115200 /dev/ttyS1 rtk_h5
to have bluetooth working.
Alternatively it's possible to use a modified driver and some startup scripts originally developed by NextThings C.H.I.P.  that i have modified to run on Orange pi Prime board.
https://www.dropbox.com/s/swv2ylw6lnhljxk/rtl8723bs_bt.tar.gz?dl=0
 What about to add these kernel options to default next sunxi64  kernel config ?
If you look at the configuration of the Tinker board it should be possible implement exactly the same thing using the correct pinout
I does not seem to work.
I'll try again with HCIUART_SERDEV=y and HCIUART_3WIRE=y instead of modules and see how it goes.
Or my ttyS1 is not the good one.
Probably you are missing the first one:
without this option the other two are ignored.
Rebuild this morning and it now works !
Thanks a lot to you two for that. I'll give a look to what's done for Tinkerboard to see if we can have a proper service doing that.
@Raffa
As I said your method works fine on my Pine64 but only after the first poweron -> if I reboot (typing reboot on the console) then rtk_hciattach fail after 99 tries.
Do you have the same problem with your Orange Pi Prime ?
Expand
For the Tinker Board myself, @Myy, and someone else on GitHub (bad memory) worked out a user-space solution to toggle the reset line on the module.  This is the issue you are experiencing, if I had to guess, that the Bluetooth is not reset on boot.
  On 12/15/2018 at 2:15 PM, martinayotte said:
The script doesn't match the schematic : script is using gpio149 while PL4 should be gpio356
The script is for the tinker board, I referenced it as an example, the gpio's have to be adjusted for the Pine. (I don't have one or I'd just do it)
@Raffa
Expand
Yes as I said on the first post I use the scripts originally developed for C.H.I.P. board with the reset pin changed:
#!/bin/sh
BT_RST_N=80
failed () {
        status=$2
        echo ${1}
        echo ${BT_RST_N} > /sys/class/gpio/unexport
        exit ${status}
# Make sure this is a Crumb
[ "$(cat /proc/device-tree/model)" = "Xunlong Orange Pi Prime" -o \
  "$(cat /proc/device-tree/model)" = "Xunlong Orange Pi Prime" ] || \
        failed "This is not a Crumb ... exiting" $?
# Make the BT_RST_N GPIO available to userspace
if [ ! -e /sys/class/gpio/gpio${BT_RST_N} ]; then
        echo ${BT_RST_N} > /sys/class/gpio/export || \
                failed "Failed to export BT_RST_N" $?
fi
# Set BT_RST_N to be an output
echo out > /sys/class/gpio/gpio${BT_RST_N}/direction || \
        failed "Failed to set BT_RST_N direction = out" $?
# Toggle BT_RST_N to reset Bluetooth
        echo 1 > /sys/class/gpio/gpio${BT_RST_N}/value;
        sleep 0.1;
        echo 0 > /sys/class/gpio/gpio${BT_RST_N}/value;
        sleep 0.1;
} || failed "Failed to toggle Bluetooth reset" $?
# Cleanup BT_RST_N direction and unexport it
echo in > /sys/class/gpio/gpio${BT_RST_N}/direction || \
        failed "Failed to set BT_RST_N direction = in" $?
echo ${BT_RST_N} > /sys/class/gpio/unexport || \
        failed "Failed to unexport BT_RST_N" $?
echo "Bluetooth reset successfully!"
Expand
The script use GPIO to generate a reset pulse on the line and it is necessary if you try to reconfigure the bluetooth module after each initial configuration.
Expand
Thanks all, indeed I was not clear at all.
I'll update the script to use gpio356 and try to provide a patch soon
I can confirm that running theses lines make bluetooth work even after a reboot :
root@pine64:~# echo 356 > /sys/class/gpio/export
root@pine64:~# echo high > /sys/class/gpio/gpio356/direction
root@pine64:~# echo 0 > /sys/class/gpio/gpio356/value && sleep 1
root@pine64:~# echo 1 > /sys/class/gpio/gpio356/value
I'll clean that up and do a PR
