deveric Posted December 11, 2018 Posted December 11, 2018 I just recently bought a sim5320a GSM/GPS cape for my Tinkerboard S and it requires the use of ttyS3; however, by default Armbian uses this port for console... so I'm unable to use it w/ the cape. What do I need to do to disable the console on this port to free it up? EDIT: Nvm... after reading more, this isn't my issue (although I did find the answer above, which is to edit the /boot/armbianEnv.txt file). It's (the GSM cape) connected to the GPIO, and I need to enable the UART serial on here. Posted below is the product I'm using, and the last picture shows the GPIO PIN mappings that it uses.https://vietnamese.alibaba.com/product-detail/sim5320a-5-9v-2a-3g-gsm-gprs-gps-expansion-board-wcdma-hsdpa-for-raspberry-pi-60634340686.html#!
martinayotte Posted December 11, 2018 Posted December 11, 2018 1 hour ago, deveric said: I need to enable the UART serial on here. Do you mean UART3 ? Could be UART1 or UART2 ? Did you got chance to get schematic of this hat ? Did you check what is in the DT ?
deveric Posted December 12, 2018 Author Posted December 12, 2018 I'm not sure... I thought it was UART3. I've tried communicating with it w/ the default Armbian settings using /dev/ttyS0 - /dev/ttyS3 without success. I've attached what documentation I can find on the board. SIM5320A-EVB-V1.0.pdf SIM5320_Hardware_Design_V1.05.pdf SIMCOM_SIM5320_ATC_EN_V1.31.pdf
deveric Posted December 12, 2018 Author Posted December 12, 2018 Also, FWIW... you can connect this device via USB also, which I've been able to communicate with that route; however, I've been unsuccessful in getting it to work when connected to the GPIO. It powers up, etc. Just can't get the communication to work. I'm sure it's 100% my lack of knowledge. Pretty new to the SBC thing, as well as any hardware that connects to them. I'm tinkering... not winning... but still trying.
martinayotte Posted December 12, 2018 Posted December 12, 2018 13 hours ago, deveric said: you can connect this device via USB also, which I've been able to communicate with that route; however, I've been unsuccessful in getting it to work when connected to the GPIO Glad to ear that you can at least use it via USB ... According to schematic you've provided, it seem connected to UART1, but there several other GPIOs that probably need to be setup properly to get this device running, such RST, 5320_ON/OFF and PWREN. Since I don't own a Tinkerboard-S, I'm not aware of the default states of those GPIOs...
deveric Posted December 12, 2018 Author Posted December 12, 2018 7 hours ago, martinayotte said: Glad to ear that you can at least use it via USB ... According to schematic you've provided, it seem connected to UART1, but there several other GPIOs that probably need to be setup properly to get this device running, such RST, 5320_ON/OFF and PWREN. Since I don't own a Tinkerboard-S, I'm not aware of the default states of those GPIOs... EDIT: Actually, finally got it working...
TonyMac32 Posted December 12, 2018 Posted December 12, 2018 4 hours ago, deveric said: Actually, finally got it working... Edited 11 minutes ago by deveric Do tell, others might be interested. And perhaps adjust the title to reflect the actual issue/fix? Thanks!
martinayotte Posted December 13, 2018 Posted December 13, 2018 22 hours ago, deveric said: EDIT: Actually, finally got it working... Good ! Can you share what you did to make it work ?
deveric Posted December 14, 2018 Author Posted December 14, 2018 Sorry for the delayed response... actually it worked out-of-the-box. It ended up being the tool I was using to communicate w/ the serial port with. Not sure why it wasn't working. I ended up coding my own in Go (golang), connected to the UART1 (/dev/ttyS1) 115200,8N1 and it worked beautifully. 1
