Get this error when trying to install rtl8812au-dkms on a armbian ubuntu 18.04 desktop for rockpro64.
oot@rockpro64:/home/steini# dkms status
rtl8812au, 4.3.8.12175.20140902+dfsg: added
root@rockpro64:/home/steini# dkms autoinstall
Error! Your kernel headers for kernel 4.4.166-rockchip64 cannot be found.
Please install the linux-headers-4.4.166-rockchip64 package,
or use the --kernelsourcedir option to tell DKMS where it's located
root@rockpro64:/home/steini# uname -a
Linux rockpro64 4.4.166-rockchip64 #17 SMP Mon Dec 3 16:25:27 CET 2018 aarch64 aarch64 aarch64 GNU/Linux
Then when searching in aptitude for kernel-headers-4.4.166 then they are not available.    It is also impossible to compile because of the missing kernels headers.
It is not so simple.   It seems to me that the kernel headers and kernel source are not available for kernel 4.4.166.
root@rockpro64:/home/steini# ls /usr/src
linux-headers-4.4.156-rk3399      linux-rockchip64-default_4.4.156_5.60_config
linux-headers-4.4.156-rockchip64  linux-source-4.4.156-rockchip64.tar
Solved it.
Somehow the builds got messed up for rk3399.     What I did to resolve it was in Armbian-Config I switched to nightly builds.  When I did, the correct kernel headers were installed.
Ok, this is getting somewhere.
uname -a
Linux rockpro64 4.18.0-rc8-rk3399 #8 SMP Mon Aug 13 03:04:15 CEST 2018 aarch64 aarch64 aarch64 GNU/Linux
But there is no display connection.   So just connecting from firefly rk3399 to rockpro64 through minicom /dev/ttsyUSB0 and serial debug device, and ssh and trying to figure out why there is no display connection through hdmi with kernel 4.18.0.    Do you have any ideas?
This is what is in /etc/X11/xorg.conf.d/01-armbian-defaults.conf
Section "Monitor"
        Identifier              "Monitor0"
        Option                  "DPMS" "false"
EndSection
Section "ServerFlags"
        Option                  "BlankTime" "0"
        Option                  "StandbyTime" "0"
        Option                  "SuspendTime" "0"
        Option                  "OffTime" "0"
EndSection
Did armbian-config through ssh and did system and nightly development build.  Now the display is back with kernel 4.19.0 .
steini@firefly:~$ ssh 192.168.1.8
steini@192.168.1.8's password:
 ____            _    ____               __   _  _
|  _ \ ___   ___| | _|  _ \ _ __ ___    / /_ | || |
| |_) / _ \ / __| |/ / |_) | '__/ _ \  | '_ \| || |_
|  _ < (_) | (__|   <|  __/| | | (_) | | (_) |__   _|
|_| \_\___/ \___|_|\_\_|   |_|  \___/   \___/   |_|
Welcome to ARMBIAN 5.67.181213 nightly Ubuntu 18.04.1 LTS 4.19.0-rc4-rockchip64
System load:   1.27 0.53 0.19      Up time:       1 min
Memory usage:  8 % of 3886MB     IP:            192.168.1.8
CPU temp:      40°C
Usage of /:    10% of 56G
[ General system configuration (beta): armbian-config ]
New to Armbian? Check the documentation first: https://docs.armbian.com
Last login: Sat Dec 15 18:46:01 2018
steini@rockpro64:~$ uname -a
Linux rockpro64 4.19.0-rc4-rockchip64 #5 SMP Fri Dec 14 01:01:49 CET 2018 aarch64 aarch64 aarch64 GNU/Linux
steini@rockpro64:~$
Now when development kernel 4.19.0-rk3399 is running on both firefly rk3399 and rockpro64, On the first day I have notices 3 issues:  #1. Serial debugging through minicom is not possible, there is no /dev/ttyUSB0 (ls /dev/ttyUSB*).  tail -f /var/log/syslog
failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/platform/fe3c0000.usb/usb2/2-1/2-1.1 2 6': No such file or directory
  #2. It is not possible to install rtl8812au driver for my usb wifi dongle on rockpro64.    But this is a work in progress.
  #3. Bluetooth missing.  "This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started.
Being a stubborn person, I am still trying to get a rtl8811cu for usb wifi dongle vendor 0bda and product c811 up and running.   The main hurdle have been a this error messages when doing make scripts from /usr/src/linux-headers-4.4.166-rockchip64/
root@rockpro64:/usr/src/linux-headers-4.4.166-rockchip64# make scripts
  CHK     scripts/mod/devicetable-offsets.h
  HOSTCC  scripts/selinux/genheaders/genheaders
scripts/selinux/genheaders/genheaders.c:13:10: fatal error: classmap.h: No such file or directory
 #include "classmap.h"
compilation terminated.
scripts/Makefile.host:91: recipe for target 'scripts/selinux/genheaders/genheaders' failed
