naseeb Posted December 17, 2018 Posted December 17, 2018 Hi All, Below command works well on my other boards(Intel with Fedora and Ubuntu) $ compton -b --backend xrender This command make windows background transparent so it doesn't hide lower window completely. But same command doesn't work on RK3288/RK3399 board. Any idea what should be done to achieve same. Does anyone have idea if anything customized in x-server related to this?
c0rnelius Posted January 11, 2019 Posted January 11, 2019 Hey I use Compton with Openbox on all my boards worth having a small DE on. Here's what I place in the autostart: compton -b -d :0 & Here's my ~/.config/compton.conf shadow = true; no-dnd-shadow = true; no-dock-shadow = true; clear-shadow = true; shadow-radius = 3; shadow-offset-x = -3; shadow-offset-y = -3; shadow-opacity = 0.55; shadow-red = 0.0; shadow-green = 0.0; shadow-blue = 0.0; shadow-exclude = [ "name = 'Notification'", "class_g = 'Conky'", "class_g ?= 'Notify-osd'", "class_g = 'Cairo-clock'" ]; shadow-ignore-shaped = false; menu-opacity = 0.94; inactive-opacity = 0.85; active-opacity = 1.0; frame-opacity = 1.0; inactive-opacity-override = false; alpha-step = 0.06; inactive-dim = 0.0; blur-kern = "3x3box"; blur-background-exclude = [ "window_type = 'dock'", "window_type = 'desktop'" ]; fading = true; fade-in-step = 0.03; fade-out-step = 0.03; fade-exclude = [ ]; backend = "xrender"; mark-wmwin-focused = true; mark-ovredir-focused = true; detect-rounded-corners = true; detect-client-opacity = true; refresh-rate = 0; vsync = "none"; dbe = false; paint-on-overlay = true; focus-exclude = [ "class_g = 'Cairo-clock'" ]; detect-transient = true; detect-client-leader = true; invert-color-include = [ ]; glx-copy-from-front = false; glx-swap-method = "undefined"; wintypes : { tooltip : { fade = true; shadow = false; opacity = 0.75; focus = true; }; }; fade-delta = 4; Pulled this from my RK3399
