remsnet Posted June 20, 2015 Share Posted June 20, 2015 I am use igors lib to get an suffucently patches kernel source for bana Pi R1 and for test builds i use this script for my unattened kernel builds. This allows directly install an fresh kernel and make an backup of the old kernel. my custom kernel .config is then at $REL stored and used . usage path : run igors compile.sh , wait till the source download done , do an CRTL-C once the kernel wants to compile from his lib then i.e : fw1 /t/GIT/output/linux-mainline # cp .config /t/GIT/.test5fw1 /t/GIT/output/linux-mainline # /t/GIT/build.shUsage: /t/GIT/build.sh {build|timestamp|clean|install|install_uImage|install_dtbs|install_modules|install_uImage|install_headers|kversion|backup}fw1 /t/GIT/output/linux-mainline # /t/GIT/build.sh build --------------------code--------------------------------------------------------- #!/bin/bash# http://piprojects.net/de/banana-pi-kernel-3-18-rc-bauen/## debug#set -x##GIT=/t/GITOUT=$GIT/outputSOURCES=$OUT/linux-mainlineINST=/usr/bin/installREL=$GIT/.test5timestamp() { D=`date +"%Y%M%d_%H%M"`} cp_cfg() { cd $SOURCES test -f $REL && cp -p $REL .config}k_v() { # cd $SOURCES cp_cfg make oldconfig make modules_prepare kversion=$(make -s kernelrelease) echo $kversion}clean_kernel() { # cd $SOURCES # test -f .config && cp .config $GIT/.config-$kversion-$timestamp make clean make distclean}backup_boot() { test -d /boot.bak && rm -rf /boot.bak test -d /boot.bak || mkdir /boot.bak cd /boot cp -rp ./* /boot.bak cd}backup_dtb() { cp -rp /boot/dtb /boot.bak/ # test -f /boot/dtb && rm -rf /boot/dtb test -d /boot/dtb && rm -rf /boot/dtb test -d /boot/dtb || mkdir -p /boot/dtb}compile_uImage() { # cd $SOURCES clean_kernel k_v # # https://gcc.gnu.org/onlinedocs/gcc/ARM-Options.html CPPFLAGS="-Ofast" CFLAGS="-Ofast" # # make -j3 dtbs modules make -j3 LOADADDR=0x40008000 uImage # timestamp}compile_docs() { cd $SOURCES k_v # make mandocs # timestamp}install_modules() { cd $SOURCES # make modules_install INSTALL_MOD_PATH=/ # timestamp}install_dtbs() { # cd $SOURCES k_v # backup_dtb if [ -d /boot/dtb ] && [ -d /boot.bak/dtb ]; then test -d /boot/dtb || mkdir -p /boot/dtb cp -rp arch/arm/boot/dts/*.dtb /boot/dtb else test -d /boot/dtb || mkdir -p /boot/dtb cp -rp /boot/dtb /boot.bak/ # cp -rp arch/arm/boot/dts/*.dtb /boot fi}install_BPi_dtbs() { cd $SOURCES # backup_dtb # echo "Installing New sun7i-a20-bananapi.dtb " $INST -m 755 arch/arm/boot/dts/sun7i-a20-bananapi.dtb /boot/sun7i-a20-bananapi.dtb echo done ls -la /boot/sun7i-a20-bananapi.dtb}install_headers() { cd $SOURCES k_v make headers_install ARCH=armv7l INSTALL_HDR_PATH=/usr/include}install_docs() { cd $SOURCES k_v make installmandocs}install_BPi_uImage() { # cd $SOURCES # backup_boot # k_v # echo "Installing New uImage" $INST -m 755 arch/arm/boot/uImage /boot/uImage $INST -m 755 arch/arm/boot/Image /boot/kernel.img install_BPi_dtbs # echo "Installing New uImage" $INST -m 644 .config /boot/config-$kversion echo "Installing New symvers-$kversion " $INST -m 644 ./Module.symvers /boot/symvers-$kversion echo "" echo "done" ls -la /boot/symvers-$kversion /boot/kernel.img /boot/uImage /boot/config-$kversion /boot/sun7i-a20-bananapi.dtb echo ""}install_kernel() { # backup_boot # install_modules # install_BPi_dtbs # install_uImage # install_headers # install_docs}build_deb-pkg() { # # cd $SOURCES # backup_boot # k_v # #http://debian-handbook.info/browse/de-DE/stable/sect.kernel-compilation.html fakeroot-u make deb-pkg}build_targz-pkg() { # # cd $SOURCES # backup_boot # k_v # fakeroot-u make targz-pkg}case "$1" inbuild) echo "Kernel build" compile_uImage echo "Kernel build done" timestamp ;;clean) echo "Kernel cleanup" clean_kernel ;;install) echo "install all" install_kernel ;;install_uImage) echo "install install_uImage" install_BPi_uImage ;;install_dtbs) echo "install dtbs" install_BPi_dtbs ;;install_modules) install_modules ;;timestamp) timestamp echo "timestamp $D" ;;kversion) k_v ;;backup) backup_boot ;;*) echo "Usage: $0 {build|timestamp|clean|install|install_uImage|install_dtbs|install_modules|install_uImage|install_headers|kversion|backup}" ;;esacexit 0 1 Link to comment Share on other sites More sharing options...
