bombobrudi Posted March 29, 2016 Posted March 29, 2016 Hi all. Strange thing happens. I've tried to run a fresh installation of the 4.4.3 kernel version of armbian 5.04. The first boot takes forever (I gave up after 2 hours; a few times). It started and hung up at updating packages. Every try; tried about 10 times. If I switched to 5.04 with kernel 3.4.110 - the first boot takes about 1minute and cubietruck rebooted once, so everything worked perfectly. Any idea what could happened? Some extra info: If I logged in during this "updating packages" period, the normal process of creating a new user worked as normal. After that I could restart the cubietruck normally. So my question: Do I get some problems if I log in while the "updating packages"-process and reboot after that? - normally at the first boot it should be restarted once, right? Many thnanks for your replies. bb
Igor Posted March 30, 2016 Posted March 30, 2016 If you can provide some boot log, we could say what is wrong.
bombobrudi Posted March 30, 2016 Author Posted March 30, 2016 Thnx for your reply Igor. Just want to be sure, the bootlog creation will start loggin AFTER I will activate it with armbianmonitor -b and after the reboot? Because If I reset while the preparing phase at the FIRST fresh boot, everything seems to work as normal... Does it make sense then? Thnx againg, bb
