madurani Posted December 26, 2018 Posted December 26, 2018 (edited) Hello All, I have configured OrangePiR1 as router. There are three network interfaces, two as wired and one wifi(hotspot). eth0 serve for access to internet(via ppp/adsl) and eth1+Wlan0 for internal network. Interfaces eth1 and wlan0 are in bridge br0. Problem is, that interface eth1 sometimes loses connection/link(cable and switch were checked ). Next nonstandard behavior of eth1 is, that only yellow led control is blinking, while green led control is not alight. Network interfaces were configured via file /etc/network/interfaces. However, when I checked network manager nmcli, I saw, that some connections are configured there too (there can be some conflict). Spoiler root@kraken:~# cat /etc/network/interfaces source /etc/network/interfaces.d/* # Network is managed by Network manager auto lo iface lo inet loopback auto eth0 allow-hotplug eth0 iface eth0 inet static address 192.168.100.2 netmask 255.255.255.0 auto dsl-provider iface dsl-provider inet ppp pre-up /bin/ip link set eth0 up # line maintained by pppoeconf provider dsl-provider auto eth1 allow-hotplug eth1 iface eth1 inet manual auto wlan0 allow-hotplug wlan0 iface wlan0 inet manual wireless-power off auto br0 iface br0 inet static bridge_ports eth1 wlan0 address 192.168.1.1 netmask 255.255.255.0 root@kraken:~# ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 02:42:d5:fc:e4:ba brd ff:ff:ff:ff:ff:ff inet 192.168.100.2/24 brd 192.168.100.255 scope global eth0 valid_lft forever preferred_lft forever inet6 fe80::42:d5ff:fefc:e4ba/64 scope link valid_lft forever preferred_lft forever 4: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000 link/ether c0:74:2b:ff:ed:69 brd ff:ff:ff:ff:ff:ff 5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000 link/ether 0c:8c:24:1d:6f:41 brd ff:ff:ff:ff:ff:ff inet 192.168.1.1/24 brd 192.168.1.255 scope global br0 valid_lft forever preferred_lft forever inet6 fe80::c274:2bff:feff:ed69/64 scope link valid_lft forever preferred_lft forever 7: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000 link/ether 0c:8c:24:1d:6f:41 brd ff:ff:ff:ff:ff:ff inet6 fe80::e8c:24ff:fe1d:6f41/64 scope link valid_lft forever preferred_lft forever 8: ppp0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc pfifo_fast state UNKNOWN group default qlen 3 link/ppp inet xxx.xxx.xxx.xx peer xxx.xxx.xxx.xxx/xxx scope global ppp0 valid_lft forever preferred_lft forever root@kraken:~# nmcli con show NAME UUID TYPE DEVICE Ifupdown (eth0) 681b428f-beaf-8932-dce4-687ed5bae28e 802-3-ethernet eth0 br0 4e181b48-4c61-4810-a9a3-c65db0678450 bridge br0 eth1 b807144d-c7ea-4145-8c64-33ce78601d22 802-3-ethernet eth1 Ifupdown (eth1) 7b635ed6-2640-7ad8-675d-744db12dd9fa 802-3-ethernet -- root@kraken:~# ethtool eth1 Settings for eth1: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Link partner advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 32 Transceiver: internal Auto-negotiation: on Supports Wake-on: pumbg Wake-on: g Current message level: 0x00007fff (32767) drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol Link detected: yes Edited December 26, 2018 by Tido added spoiler
Tido Posted December 26, 2018 Posted December 26, 2018 2 hours ago, madurani said: Problem is, please post the armbianmonitor -u output Look at the folder etc/network/ you find there several files. One is the master file. You can use armbian-config to make changes to your settings.
madurani Posted December 26, 2018 Author Posted December 26, 2018 Here is output with link for downloading: root@kraken:/etc/network# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/1wPj Main config file /etc/network/interfaces was edit manual, not via armbian-config, because there isn't possibility for raising of bridge.
Tido Posted December 26, 2018 Posted December 26, 2018 5 minutes ago, madurani said: there isn't possibility for raising of bridge. I haven't any armbian running right now, but IIRC there is an option in armbian-config to edit this file manually within armbian-config. Please check. 18 minutes ago, Tido said: Look at the folder /etc/network/ you find there several files. you might have a conflict because you have edited the 'wrong' one. So I recommend again above edit this file manually within armbian-config
madurani Posted December 26, 2018 Author Posted December 26, 2018 32 minutes ago, Tido said: I haven't any armbian running right now, but IIRC there is an option in armbian-config to edit this file manually within armbian-config. Please check. you might have a conflict because you have edited the 'wrong' one. So I recommend again above edit this file manually within armbian-config I don't known to find in "armbian-config" nothing similar as "IIRC'. When I start mentioned tool and set up network part and pick up eth1, so there isn't any options for "bridge". Yes it look on mishmash configuration, because AccessPoint was configured via "armbian-config" but bridge configuration were done via brctl and not via NM or armbian-config. Probably turn off MN can solve this issue?
Tido Posted December 26, 2018 Posted December 26, 2018 iirc = if I remember correctly look again in the networking section.
madurani Posted December 31, 2018 Author Posted December 31, 2018 Can somebody help me correctly configure two nodes bridge via network-manager or armbian-config? Node are wlan0 and eth1. Wlan0 is manages via hostapd and configured was via "armbian-config". Bridge were configure manually in /etc/network/interfaces: auto br0 iface br0 inet static bridge_ports eth1 wlan0 address 192.168.1.1 netmask 255.255.255.0 But network-manager sees only one node eth1. Wlan0 isn't active/managed via NM: root@kraken:~# nmcli con show NAME UUID TYPE DEVICE br0 ea0b5fc2-c262-47a2-a1f8-7b186860d3ea bridge br0 eth0 5df08611-abea-491c-af88-4733fba17e69 802-3-ethernet eth0 eth1 085af0b4-59e7-4a73-9498-2f363dec7398 802-3-ethernet eth1 Ifupdown (eth0) 681b428f-beaf-8932-dce4-687ed5bae28e 802-3-ethernet -- Ifupdown (eth1) 7b635ed6-2640-7ad8-675d-744db12dd9fa 802-3-ethernet -- bridge-slave-eth1 4d4c214f-ec45-4a23-b761-2437b4b9d9c8 802-3-ethernet -- bridge-slave-wlan0 0b158612-8aab-44bc-9cf8-691f8bbda227 802-11-wireless -- DEVICE TYPE STATE CONNECTION br0 bridge connected br0 eth0 ethernet connected eth0 eth1 ethernet connected eth1 lo loopback unmanaged -- ppp0 ppp unmanaged -- wlan0 wifi unmanaged -- Problem is, that eth1 sometimes loses link. Next issue is, that only yellow led control is blinking on eth1, while green led control is not alight(short time during booting green led light).
Tido Posted December 31, 2018 Posted December 31, 2018 I cannot help you from remote, but I would backup your config files and do fresh install of armbian. Go to armbian-config / manual network configuration and paste there your config files. Then do testing / checks. Each line represents a command (except the ones with text which explains how to read the status of the connection here in color, click me ) bridge vlan show bridge link show ss -tua Active Internet connections or netstat -tuap ip r ip link (successor of ifconfig). UP it is administratively, the LOWER_UP indicates the physical layer is working (i.e. there is a carrier), and the second UP confirms (in effect) the IP layer is up. Cable plugged in: 3: lan2@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP mode DEFAULT group default qlen 1000 Cable unplugged: 3: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br0 state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 ifconfig -a ifconfig eth0.101 brctl show brctl showmacs br0 less /var/log/syslog (type capital G to jump to last entry - q to exit) By the way, I got my know how from the Lamobo R1 that uses nowadays DSA (Distributed Switch Architecture) and if your commands are for the old-school Bridge, but your device is on DSA... then you will have to change your approach.
