christopher Posted December 29, 2018 Posted December 29, 2018 I am wanting to do bare programming of the A20. Does anyone have a memory map of the A20? I understand there are three types of memory used in the A20, including onboard non changeable memory. Does anyone have a quick description of the memory banks available - location, programmability, access? Christopher
Solution martinayotte Posted December 29, 2018 Solution Posted December 29, 2018 9 hours ago, christopher said: I am wanting to do bare programming of the A20. Starting to do Bare Metal programming isn't a easy task ... You will need to learn a tons of things, you need to start here : http://linux-sunxi.org/A20 Then here : http://linux-sunxi.org/EGON and http://linux-sunxi.org/BROM Good luck !
christopher Posted December 29, 2018 Author Posted December 29, 2018 Thanks Martin. It is the paucity of information that is the hardest! I'll follow these up and thanks again Christopher.
