HansC Posted December 29, 2018 Posted December 29, 2018 I am lost, the soundcard used to work when I first started with this board but now I get a "aplay: device_list:270: no soundcards found..." error. When I tried to enable the analog codec using armbian-config I get an empty screen. This also used to work the first time. So I created a new SD card using Armbian Stretch this time but with exactly the same result. I am desperate! The diagnostic output is here http://ix.io/1x25 Kind regards, Hans C
HansC Posted December 29, 2018 Author Posted December 29, 2018 Ended up creating a new Armbian Bionic SD. This fixed the audio output and also the armbian-config issue.
