I had it and lost it: u-boot with I2C. I did not write down how I did it (was heavy) :(
Tried to build yourself again: does not work.
u-boot-mizi.bin does not want to boot.
For 2 days I try to find the solution. Google has already blocked me ;)
Can somebody help? I need i2c directly, after power on, to read FRAM and set relays.
Programming in Linux is enjoyable but system administration is horrible.
Thanks
What am I doing:
git clone https://github.com/hsdenx/u-boot-i2c.git
u-boot/make orangepi_zero_defconfig
u-boot/make
u-boot/export card=/dev/mmcblk0
u-boot/export p=p
u-boot/dd if=u-boot-sunxi-with-spl.bin of=${card} bs=1024 seek=8
reboot = not booting
I'm tried this  with git://git.denx.de/u-boot.git: not working.
What am I doing wrong?
Thanks
There is no I2C node in DT :  https://github.com/hsdenx/u-boot-i2c/blob/master/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts
Also, you probably need to add CONFIG_DM_I2C in this file : https://github.com/hsdenx/u-boot-i2c/blob/master/configs/orangepi_zero_defconfig
... and maybe more, such as porting i2c-sun6i-p2wi.c from Kernel into U-Boot ...
Maybe you can try to use software bitbanging using CONFIG_DM_I2C_GPIO ...
Thanks martinayotte,
I2C was working (in u-boot-mizi.bin not in u-boot-i2c!!!) but SD Card can not boot with Armbian after replacing U-Boot.
I2C was working ( in any .bin - I tied so many) but SD Card can not boot with Armbian after replacing U-Boot.
I'm not sure to understand you : do you mean that this "hsdenx" u-boot-i2c is incompatible with Armbian ?
Maybe you should try the Armbian build process and tweak it to met your I2C requirement ...
Sorry martinayotte,
u-boot-i2c  is working but w/o i2c!?
u-boot-mizi.bin has i2c working but not compatible with Armbian (OpenWrt)...
Soft i2c in u-boot, is it possible?
I've build u-boot with .dts and board.c changes and didn't note how - so stupid.
Of course, with CONFIG_DM_I2C_GPIO, although I've never tried myself ...
https://github.com/hsdenx/u-boot-i2c/blob/master/drivers/i2c/Kconfig#L66
But, then, the i2C DT node would be a bit different since you need to define the GPIO pins been used :
https://github.com/hsdenx/u-boot-i2c/blob/master/doc/device-tree-bindings/i2c/i2c-gpio.txt
