Setting armbianEnv.txt values at build?
What is the correct way to set armbianEnv.txt values when the distro is being built? Specifically I'd like to set kernel verbosity to a non-zero value? There does not seem to be a skeleton file so is all content generated dynamically?
TIA
No, basics stuff are coming from templates located in config/bootenv ...
For Serial Debug, change "console=both" to "console=serial" ...
