On 3/24/2019 at 7:49 AM, dolphs said:
hi - thanks for that suggestion, going to try some of these.
Finally 1st board arrived and herewith my early ovpn testst ( 15 minutes tcp iperf dump ) running kernel 5.0.2 without heatsink and without fan running at 1,8GHZ:.
AFAIK openvpn only uses one core, not sure how this is on ARM, but at least on intel, it would mean that only one core is actually on a high frequency.
Hi, in terms of
I can concur, though all cores go to 1,8GHz if high speed is required ( measured +/-150Mbit, still tuning to do to get to 200 or up and also both ends need a H6 board ).
Mostly it does not exceed 720MHz :-), when streaming data from one side to the other ( as +/- 15-20Mbit is needed only ):
:~# cpufreq-info |grep stats
  cpufreq stats: 480 MHz:84.86%, 720 MHz:12.58%, 816 MHz:1.62%, 888 MHz:0.00%, 1.08 GHz:0.00%, 1.32 GHz:0.00%, 1.49 GHz:0.00%, 1.80 GHz:0.94%  (64750)
If I dump ( iperf3 ) TCP packets and increase it with multiple threads it hits 1.8GHZ and see my initial posts about that, resumee:
:~# cpufreq-info |grep current
  current policy: frequency should be within 480 MHz and 1.80 GHz.
  current CPU frequency is 1.80 GHz (asserted by call to hardware).
:~# paste <(cat /sys/class/thermal/thermal_zone*/type) <(cat /sys/class/thermal/thermal_zone*/temp) | column -s $'\t' -t | sed 's/\(.\)..$/.\1°C/'
cpu_thermal  55.4°C
gpu_thermal  49.9°C
Also thanks for the suggestion rgd. MAC address, I will try this out when I have time later this week, possibly today already :-).
Once that is stable, indeed the major remaining issue is the board still shuts down on a reboot - something to dig in - thanks so far!
42 minutes ago, dolphs said:
Hi, in terms of
If you have a connection from linux to linux, you could also consider wireguard. It performs much faster than openvpn.
https://www.wireguard.com/performance/
Hi all,
I am new here and have some Orange Pi boards. The last one is the One Plus. I know for this one is Armbian in development. So did it get a a new ipadress after every powercycle. Even when i added a static ip. But i got a update today and it looks al working fine now! :D Are there more One Plus users who also have this different? The reboot problem is just the same but i read its very difficult to fix. :)
