MarkA007 Posted January 18, 2019 Share Posted January 18, 2019 Hello, Has anyone managed to get usb-redirector working? 4.14.70-rockchip and headers. with 'arm' It installs ok, and the driver loads... lsmod and dmesg confirms. Module Size Used by tusbd 126976 0 but when I try one the binaries, it just returns me back to the prompt.??? (i've tried other versions arm-eabi. armeb, that just returns file not found when using a binary) Many thanks. Mark Link to comment Share on other sites More sharing options...
martinayotte Posted January 18, 2019 Share Posted January 18, 2019 Did you tried to use USB/IP instead ? Link to comment Share on other sites More sharing options...
MarkA007 Posted January 26, 2019 Author Share Posted January 26, 2019 ho hum....... CONFIG_USBIP_CORE is not set Link to comment Share on other sites More sharing options...
martinayotte Posted January 26, 2019 Share Posted January 26, 2019 1 hour ago, MarkA007 said: ho hum....... CONFIG_USBIP_CORE is not set Added in this commit : https://github.com/armbian/build/commit/d1b4951d51fa041ad661c6e8065d0f92914a2946 Wait for new builds or build yourself an images : https://docs.armbian.com/Developer-Guide_Build-Preparation/ Link to comment Share on other sites More sharing options...
MarkA007 Posted January 27, 2019 Author Share Posted January 27, 2019 Many thanks for the commit, Rebuilding a Kernel is a bit beyond me at the moment for the TB. (will need to set up a dev enviroment somwhere to x-compile/learn when I get time.) In the meantime will await a nightly non-desktop build. Link to comment Share on other sites More sharing options...
MarkA007 Posted March 14, 2019 Author Share Posted March 14, 2019 Well, after a -lot- of mucking about, including rebuilding a kernel, we are almost there.. usb-redirector works on low bandwith stuff (up to around 8-10Mb/s) on the ethernet interface. I'm wondering if we can only 'do' USB1.1 CPU usage is nothing to get excited about.. One wonders if there are any reasons I can't/won't get any more through from the bridge that is set up between USB and eth0. I'm using an SDR play duo (single mode) in case you're wondering.. TD Link to comment Share on other sites More sharing options...
