1955sergey1955 Posted January 19, 2019 Posted January 19, 2019 Armbianmonitor: http://Fri%20Oct%2026%2019%3A51%3A50%20UTC%202018%20%7C%20Orange%20Pi%20Lite%20%7C%205.65%20%7C%20armhf%20%7C%20armv7l%20%7C%204.14.78-sunxi Good day! I can not auto-flush. The directory is created / deleted when installing / removing the flash. But the mount does not happen - error 1. /var/log/arbian-hardware-monitor.log Fri Oct 26 19:51:50 UTC 2018 | Orange Pi Lite | 5.65 | armhf | armv7l | 4.14.78-sunxi To autoload flash: /etc/udev/rules.d/20-automount_flash.rules ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/bin/mkdir -p /media/%k" ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/bin/mount uid=1000 /dev/%k /media/%k" ACTION=="remove" KERNEL=="sd[a-z][0-9]" RUN+="/bin/rmdir /media/%k" result in: /var/log/daemon.log Process '/bin/mount uid=1000 /dev/sda1 /media/sda1' failed with exit code 1. ---- error!! sudo mount /media/sda1 /media/sda1 # ok!!!!! Why error? Sergey
guidol Posted January 19, 2019 Posted January 19, 2019 why did you use uid=1000 in the mount-udev-rule and not on the sudo command?
1955sergey1955 Posted January 20, 2019 Author Posted January 20, 2019 Good day, Guidol! In the examples, uid=1000 is present everywhere (https://habr.com/post/58769/ uid=1000; http://zenux.ru/articles/40/ uid=1000). I enter under the root. Does not help and UID=0 (if at the entrance uid = 0). Since it is necessary to do the right thing for a single user with root or without root rights? Sergey
guidol Posted January 20, 2019 Posted January 20, 2019 2 hours ago, 1955sergey1955 said: Since it is necessary to do the right thing for a single user with root or without root rights? uid=1000 is only for unix-/linux-filesystem like ext4 and not for FAT/VFAT the mount command doesnt work from udev on my test system, but ther is another command: pmount - pmount - mount removable devices as normal user So install pmount: apt install pmount and then change your udev-file /etc/udev/rules.d/20-automount_flash.rules: ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/bin/mkdir -p /media/%k" ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/usr/bin/pmount /dev/%k /media/%k" ACTION=="remove" KERNEL=="sd[a-z][0-9]" RUN+="/bin/rmdir /media/%k" after that reload the udev-rules with: udevadm control --reload-rules BUT: be aware to securely umount your USB-Device (Stick?)
1955sergey1955 Posted January 20, 2019 Author Posted January 20, 2019 Good day, Guidol! Unfortunately the team did not help. The result is deplorable - the mount does not occur. In addition, the command rmdir does not work when extracting USB. Sergey
guidol Posted January 20, 2019 Posted January 20, 2019 19 minutes ago, 1955sergey1955 said: The result is deplorable - the mount does not occur. In addition, the command rmdir does not work when extracting USB. on my NanoPi Neo2 with armbian it did work with pmount. maybe you add a chmod 777 for the created directory the rmdir and umount only does work if you are not actively in the directory of the device, because when it is in use you cant rmdir/umount
1955sergey1955 Posted January 20, 2019 Author Posted January 20, 2019 Good day, Guidol! The create directory command mount did not affect the creation / deletion of a directory. ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/bin/mkdir -p /media/%k" #ACTION=="add" KERNEL=="sd[a-z][0-9]" RUN+="/usr/bin/pmount /dev/%k /media/%k" ACTION=="remove" KERNEL=="sd[a-z][0-9]" RUN+="/bin/rmdir /media/%k" Creating a directory always passes. When you exclude the pmount command, the directory is erased. terminal command: pmount /dev/sda1 /media/sda1 - mounting device - ok. Sergey
