@jernej
Have you made changes to your
https://raw.githubusercontent.com/jernejsk/OpenELEC-OPi2/openelec-7.0/packages/linux-drivers/RTL8189ES/patches/RTL8189ES-000-change-build-settings.patch   ?
This patch doesn't enable Monitor mode and needs to be manually correctly to enable it.
Probably it would be necessary submitting a revised one to Igor, so that he includes the monitor capability to regular builds, despite that I was unable to produce this mode working on the Armbian system.
@xwalter
I haven't yet tried the AP mode. It is on the list, but other priorities prevent from testing it.
@jernej
Yes, I see the changes now:
https://github.com/jernejsk/OpenELEC-OPi2/blob/openelec-7.0/packages/linux-drivers/RTL8189ES/patches/RTL8189ES-000-change-build-settings.patch
-CONFIG_WIFI_MONITOR = n
+CONFIG_WIFI_MONITOR = y
I dumped the latest Armbian 5.14 to TF card and the new driver is already in:
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# lsmod
Module                  Size  Used by
8189es               1076034  0
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# modinfo 8189es
filename:       /lib/modules/3.4.112-sun8i/kernel/drivers/net/wireless/rtl8189ES_linux/8189es.ko
version:        v4.3.18.1_15373.20151005
and it reports capable of monitor mode:
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# iw list
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * monitor
                 * P2P-client
                 * P2P-GO
And I have found part of the puzzle of the reason it was unable to switch to monitor mode. It appears, that default installation doesn't bring up the wlan0. #ifconfig doesn't show it up.
So it gives:
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# iwconfig wlan0 mode monitor
Error for wireless request "Set Mode" (8B06) :
    SET failed on device wlan0 ; Operation not permitted.
Once it is brought up:
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# ip link set wlan0 up
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# ifconfig
shows the   wlan0     Link encap:Ethernet  HWaddr 58:63:
And it is possible now switching it to a different mode:
Anyway, it doesn't work correctly.
 [!] no wireless interfaces were found.
 [!] you need to plug in a wifi device or install drivers.
I created mon0 manually :
root@orangepiplus:~# iw phy phy0 interface add mon0 type monitor
but again, no wireless network could be found:
root@orangepiplus:~# airodump-ng mon0 start
 CH  9 ][ Elapsed: 28 s ][ 2016-06-05 21:58
 BSSID              PWR  Beacons    #Data, #/s  CH  MB   ENC  CIPHER AUTH ESSID
empty list
It doesn't run either with
root@orangepiplus:~#  ip link set mon0 up
