  • 0
rebuild rtl8189es from GIT for OPI+
y52
Question
The built-in WIFI module doesn't switch to monitor mode. This makes me looking for rebuilding the module from the Git repository: https://github.com/rdm-dev/rtl8189ES_linux/tree/52ee6388111fbaf990ec60e93b086cafa6cc373a
I am stuck with the following error: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'. What is necessary to rebuild and replace the module with a new one?
Here is what was done so far:
root@orangepiplus:/usr/src/rtl8189ES_linux# uname -a Linux orangepiplus 3.4.110-sun8i #18 SMP PREEMPT Tue Mar 8 20:03:32 CET 2016 armv7l GNU/Linux
root@orangepiplus:/usr/src/rtl8189ES_linux# dmesg |grep 8189 [ 3.923104] RTL871X: rtl8189es v4.3.0.4_11916.20140724_COB [ 3.923090] RTL871X: module init start [ 3.923104] RTL871X: rtl8189es v4.3.0.4_11916.20140724_COB [ 3.923112] RTL871X: build time: Mar 8 2016 20:02:27 root@orangepiplus:~# lsmod Module Size Used by 8189es 896688 0
root@orangepiplus:~# rmmod 8189es
root@orangepiplus:/usr/src/rtl8189ES_linux# ls -al /lib/modules/`uname -r`/ lrwxrwxrwx 1 root root 36 Mar 8 20:03 build -> /usr/src/linux-headers-3.4.110-sun8i
root@orangepiplus:/usr/src# svn ls https://github.com/rdm-dev/rtl8189ES_linux/trunk
Kconfig
Makefile
clean
core/
hal/
ifcfg-wlan0
import-update.sh
include/
os_dep/
platform/
runwpa
wlan0dhcp
root@orangepiplus:/usr/src# svn export https://github.com/rdm-dev/rtl8189ES_linux/trunk
A trunk A trunk/Kconfig A trunk/Makefile A trunk/clean A trunk/core A trunk/core/efuse A trunk/core/efuse/rtw_efuse.c A trunk/core/rtw_ap.c A trunk/hal/efuse A trunk/hal/efuse/efuse_mask.h A trunk/hal/efuse/rtl8188e A trunk/hal/efuse/rtl8188e/HalEfuseMask8188E_PCIE.c A trunk/hal/efuse/rtl8188e/HalEfuseMask8188E_PCIE.h A trunk/hal/phydm/rtl8188e/hal8188ereg.h A trunk/runwpa A trunk/wlan0dhcp Exported revision 6.
root@orangepiplus:/usr/src# mv trunk rtl8189ES_linux
root@orangepiplus:/usr/src# ls -al rtl8189ES_linux
total 112 drwxr-xr-x 7 root root 4096 Apr 2 19:28 . drwxr-xr-x 11 root root 4096 Apr 2 19:30 .. -rw-r--r-- 1 root root 64 Oct 6 21:21 clean drwxr-xr-x 3 root root 4096 Apr 2 19:28 core drwxr-xr-x 8 root root 4096 Apr 2 19:28 hal -rw-r--r-- 1 root root 54 Oct 6 21:21 ifcfg-wlan0 -rwxr-xr-x 1 root root 496 Oct 6 21:21 import-update.sh drwxr-xr-x 4 root root 12288 Apr 2 19:28 include -rw-r--r-- 1 root root 110 Oct 6 21:21 Kconfig -rwxr-xr-x 1 root root 51507 Oct 6 21:21 Makefile drwxr-xr-x 3 root root 4096 Apr 2 19:28 os_dep drwxr-xr-x 2 root root 4096 Apr 2 19:28 platform -rw-r--r-- 1 root root 423 Oct 6 21:21 runwpa -rw-r--r-- 1 root root 294 Oct 6 21:21 wlan0dhcp
cd /usr/src/rtl8189ES_linux
root@orangepiplus:/usr/src/rtl8189ES_linux# make -C /lib/modules/`uname -r`/build
make: Entering directory '/usr/src/linux-headers-3.4.110-sun8i'
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
make[1]: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'.  Stop.
/usr/src/linux-headers-3.4.110-sun8i/arch/arm/Makefile:278: recipe for target 'archprepare' failed
make: *** [archprepare] Error 2
make: Leaving directory '/usr/src/linux-headers-3.4.110-sun8i'
Link to comment
Share on other sites
Help us fund some #badass gear for our continuous integration build framework
  • 0
Probably, the question was not in general of how to build any driver, but the given one.
For that particular driver, the build doesn't advance with the make stage :
root@orangepiplus:/usr/src/rtl8189ES_linux-52ee# make ARCH=arm -C /lib/modules/`uname -r`/build
Link to comment
  • 0
The build is not clear yet, despite that some progress was made.
Which of the options is it necessary to enable in the Makefile?
CONFIG_80211W = y
CONFIG_WIFI_MONITOR = y
Which of the 3 platforms is valid for OPI + ?
###################### Platform Related #######################
ONFIG_PLATFORM_ARM_SUN7I = y
CONFIG_PLATFORM_ARM_SUN8I_W3P1 = n
CONFIG_PLATFORM_ARM_SUN8I_W5P1 = n
Will this option compile the driver as a module?
CONFIG_DRVEXT_MODULE = y
By the same occasion, which is the good option for OPI+  out of the following ?
choice[1-2?]: 1
Select the wafer with arch sun8i
> 1. Allwinner A3x SOCs(sun8iw1) (ARCH_SUN8IW1) (NEW)
  2. Allwinner A2x SOCs(sun8iw3) (ARCH_SUN8IW3) (NEW)
  3. Allwinner A33 SOCs(sun8iw5) (ARCH_SUN8IW5) (NEW)
  4. Allwinner A83 SOCs(sun8iw6) (ARCH_SUN8IW6) (NEW)
  5. Allwinner Axx SOCs(sun8w7) (ARCH_SUN8IW7) (NEW)
  6. Allwinner V3x SOCs(sun8iw8) (ARCH_SUN8IW8) (NEW)
  7. Allwinner Axx SOCs(sun8iw9) (ARCH_SUN8IW9) (NEW)
choice[1-7?]: 6
I was able to start the build configuration in a strange sequence of 2 commands:
1st run :
root@orangepiplus:/usr/src/rtl8189ES_linux# make ARCH=arm/mach-sunxi -C /lib/modules/`uname -r`/build
then run :
root@orangepiplus:/usr/src/rtl8189ES_linux-52ee# make -C /lib/modules/`uname -r`/build
The 1st command will raise an error:
# configuration written to .config
include/config/auto.conf:42:warning: symbol value 'cubic' invalid for DEFAULT_TCP_CONG
include/config/auto.conf:43:warning: symbol value '' invalid for UEVENT_HELPER_PATH
include/config/auto.conf:140:warning: symbol value '/lib/modules/$UNAME_RELEASE/.config' invalid for DEFCONFIG_LIST
include/config/auto.conf:232:warning: symbol value '(none)' invalid for DEFAULT_HOSTNAME
include/config/auto.conf:240:warning: symbol value '' invalid for EXTRA_FIRMWARE
include/config/auto.conf:374:warning: symbol value '' invalid for LOCALVERSION
include/config/auto.conf:378:warning: symbol value '' invalid for CMDLINE
include/config/auto.conf:442:warning: symbol value 'cfq' invalid for DEFAULT_IOSCHED
include/config/auto.conf:479:warning: symbol value '' invalid for DEFAULT_SECURITY
include/config/auto.conf:526:warning: symbol value '' invalid for CROSS_COMPILE
make[1]: *** No rule to make target 'sys_config.o', needed by 'built-in.o'.  Stop.
Makefile:987: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
The 2nd will start the build configuration with the long options list :
* Restart config...
* General setup
Prompt for development and/or incomplete code/drivers (EXPERIMENTAL) [N/y/?] (NEW)
which will finish with error anyway :
Still no luck. Probably other ideas ?
Link to comment
  • 0
To rebuild the rtl8189es driver with the necessary options the
platform_ARM_SUNnI_sdio.c
from Armbian should be used instead of the one in the rtl8189es sources.
The Armbian distribution doesn't contain it.
This one belongs to the rtl8189ES sources
root@orangepiplus:/usr/src/rtl8189ES_linux# find / -name platform_ARM_SUNnI_sdio.c
/usr/src/rtl8189ES_linux/platform/platform_ARM_SUNnI_sdio.c
The distribution headers have only :
root@orangepiplus:/usr/src/linux-headers-3.4.110-sun8i/drivers/net/wireless/rtl8189es# ls -al
total 56
drwxr-xr-x  2 root root  4096 Apr  7 23:56 .
drwxr-xr-x 28 root root  4096 Mar  8 20:10 ..
-rwxr-xr-x  1 root root   110 Feb 26 10:41 Kconfig
-rwxr-xr-x  1 root root 41465 Feb 26 10:41 Makefile
Where in the Armbian Git located and how to extract this only single file from it?
Would it be possible in the future versions enabling
########################## Features ###########################
in the driver's Makefile features section ?
Link to comment
  • 0
Jernej from the Orange PI forum helped me to almost rebuild the rtl8189ES driver on the Armbian :
http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=1091&page=3#pid11851
The initial setup was somewhat tricky, but finally compilation turned ALMOST successful :
root@orangepiplus:/usr/src/rtl8189ES_linux# make ARCH=arm KSRC=/usr/src/linux-headers-3.4.110-sun8i
make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-headers-3.4.110-sun8i M=/usr/src/rtl8189ES_linux  modules
make[1]: Entering directory '/usr/src/linux-headers-3.4.110-sun8i'
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_cmd.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_security.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_debug.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_io.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_ioctl_query.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_ioctl_set.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_ieee80211.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_mlme.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/halhwimg8188e_rf.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/halhwimg8188e_t_fw.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/halhwimg8188e_s_fw.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/halphyrf_8188e_ce.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/phydm_regconfig8188e.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/hal8188erateadaptive.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/phydm/rtl8188e/phydm_rtl8188e.o
  CC [M]  /usr/src/rtl8189ES_linux/platform/platform_ops.o
  CC [M]  /usr/src/rtl8189ES_linux/platform/platform_ARM_SUNnI_sdio.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_mp.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_mp_ioctl.o
  LD [M]  /usr/src/rtl8189ES_linux/8189es.o
  Building modules, stage 2.
  MODPOST 1 modules
/bin/sh: 1: scripts/mod/modpost: not found
/usr/src/linux-headers-3.4.110-sun8i/scripts/Makefile.modpost:91: recipe for target '__modpost' failed
make[2]: *** [__modpost] Error 127
Makefile:1370: recipe for target 'modules' failed
make[1]: *** [modules] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-3.4.110-sun8i'
Makefile:1635: recipe for target 'modules' failed
make: *** [modules] Error 2
This new obscure "makefile.modpost:91: recipe for target '__modpost' failed" keeps me even more frustrated.
We tried troubleshooting the the error, but failed.
Could you help completing the driver build ?
Link to comment
  • 0
Your tip almost made the magic, although the grain of salt is discovered after the drive is built.
Could the "kernel tainted" be resolved?
root@orangepiplus:~# cd /usr/src/linux-headers-$(uname -r)
root@orangepiplus:/usr/src/linux-headers-3.4.110-sun8i# make scripts
  CC      scripts/mod/empty.o
  HOSTCC  scripts/mod/mk_elfconfig
  MKELF   scripts/mod/elfconfig.h
  HOSTCC  scripts/mod/file2alias.o
  HOSTCC  scripts/mod/modpost.o
  HOSTCC  scripts/mod/sumversion.o
  HOSTLD  scripts/mod/modpost
  HOSTCC  scripts/kallsyms
  HOSTCC  scripts/conmakehash
root@orangepiplus:/usr/src/linux-headers-3.4.110-sun8i# cd /usr/src/rtl8189ES_linux/
sun8i
modules
  MODPOST 1 modules
  CC      /usr/src/rtl8189ES_linux/8189es.mod.o
  LD [M]  /usr/src/rtl8189ES_linux/8189es.ko
root@orangepiplus:/usr/src/rtl8189ES_linux# find / -regextype posix-egrep -regex ".*8189.*\.
(ko)$"
/lib/modules/3.4.110-sun8i/kernel/drivers/net/wireless/rtl8189es/8189es.ko
root@orangepiplus:/usr/src/rtl8189ES_linux# ls -al /usr/src/rtl8189ES_linux/8189es.ko /lib/modules/3.4.110-sun8i/kernel/drivers/net/wireless/rtl8189es/8189es.ko
-rw-r--r-- 1 root root 1210099 Mar  8 20:03 /lib/modules/3.4.110-sun8i/kernel/drivers/net/wireless/rtl8189es/8189es.ko
-rw-r--r-- 1 root root 1706532 Apr 13 22:14 /usr/src/rtl8189ES_linux/8189es.ko
root@orangepiplus:/usr/src/rtl8189ES_linux# lsmod
Module                  Size  Used by
8189es                896688  0
root@orangepiplus:/usr/src/rtl8189ES_linux# rmmod 8189es
Module                  Size  Used by
root@orangepiplus:/usr/src/rtl8189ES_linux# insmod 8189es.ko
insmod: ERROR: could not insert module 8189es.ko: Invalid module format
Apr 13 22:19:00 localhost kernel: [ 6997.745433] 8189es: module_layout: kernel tainted.
Apr 13 22:19:00 localhost kernel: [ 6997.745469] Disabling lock debugging due to kernel taint
#dmesg
[ 6997.745564] 8189es: version magic '3.4.110 mod_unload ARMv7 p2v8 ' should be '3.4.110-sun8i SMP preempt mod_unload modversions ARMv7 p2v8 '
Link to comment
  • 0
root@orangepiplus:~# cat /proc/sys/kernel/tainted
2
root@orangepiplus:/usr/src/rtl8189ES_linux# modinfo 8189es.ko
filename:       /usr/src/rtl8189ES_linux/8189es.ko
version:        v4.3.18.1_15373.20151005
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     C5DDC3DBBA8AB579D910935
alias:          sdio:c*v024Cd8179*
depends:
vermagic:       3.4.110 mod_unload ARMv7 p2v8
parm:           rtw_ips_mode:The default IPS mode (int)
parm:           rtw_usb_rxagg_mode:int
parm:           rtw_qos_opt_enable:int
parm:           ifname:The default name to allocate for first interface (charp)
parm:           if2name:The default name to allocate for second interface (charp)
parm:           rtw_initmac:charp
parm:           rtw_channel_plan:int
parm:           rtw_special_rf_path:int
parm:           rtw_chip_version:int
parm:           rtw_rfintfs:int
parm:           rtw_lbkmode:int
parm:           rtw_network_mode:int
parm:           rtw_channel:int
parm:           rtw_mp_mode:int
parm:           rtw_wmm_enable:int
parm:           rtw_vrtl_carrier_sense:int
parm:           rtw_vcs_type:int
parm:           rtw_busy_thresh:int
parm:           rtw_ht_enable:int
parm:           rtw_bw_mode:int
parm:           rtw_ampdu_enable:int
parm:           rtw_rx_stbc:int
parm:           rtw_ampdu_amsdu:int
parm:           rtw_lowrate_two_xmit:int
parm:           rtw_rf_config:int
parm:           rtw_power_mgnt:int
parm:           rtw_smart_ps:int
parm:           rtw_low_power:int
parm:           rtw_wifi_spec:int
parm:           rtw_antdiv_cfg:int
parm:           rtw_antdiv_type:int
parm:           rtw_switch_usb3:int
parm:           rtw_enusbss:int
parm:           rtw_hwpdn_mode:int
parm:           rtw_hwpwrp_detect:int
parm:           rtw_hw_wps_pbc:int
parm:           rtw_max_roaming_times:The max roaming times to try (uint)
parm:           rtw_fw_iol:FW IOL. 0:Disable, 1:enable, 2:by usb speed (int)
parm:           rtw_mc2u_disable:int
parm:           rtw_80211d:Enable 802.11d mechanism (int)
parm:           rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm:           rtw_hiq_filter:0:allow all, 1:allow special, 2:deny all (uint)
parm:           rtw_adaptivity_en:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_mode:0:normal, 1:carrier sense (uint)
parm:           rtw_adaptivity_dml:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_dc_backoff:DC backoff for Adaptivity (uint)
parm:           rtw_amplifier_type_2g:BIT3:2G ext-PA, BIT4:2G ext-LNA (uint)
parm:           rtw_amplifier_type_5g:BIT6:5G ext-PA, BIT7:5G ext-LNA (uint)
parm:           rtw_RFE_type:default init value:64 (uint)
parm:           rtw_GLNA_type:default init value:0 (uint)
parm:           rtw_TxBBSwing_2G:default init value:0xFF (uint)
parm:           rtw_TxBBSwing_5G:default init value:0xFF (uint)
parm:           rtw_OffEfuseMask:default open Efuse Mask vaule:0 (uint)
parm:           rtw_FileMaskEfuse:default drv Mask Efuse vaule:0 (uint)
parm:           rtw_pll_ref_clk_sel:force pll_ref_clk_sel, 0xF:use autoload value (uint)
parm:           rtw_tx_pwr_lmt_enable:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_tx_pwr_by_rate:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_phy_file_path:The path of phy parameter (charp)
parm:           rtw_load_phy_file:PHY File Bit Map (int)
parm:           rtw_decrypt_phy_file:Enable Decrypt PHY File (int)
Link to comment
  • 0
Strange issue. Why the newly built module with the Armbian distribution and the native headers reports the Invalid module format ?
I made another clean build disabling the default module in the
root@orangepiplus:/usr/src/rtl8189ES_linux# cat /etc/modules
#8189es
root@orangepiplus:/usr/src/rtl8189ES_linux# make clean
cd hal/phydm/ ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
rm -fr .tmp_versions
C [M]  /usr/src/rtl8189ES_linux/hal/led/hal_sdio_led.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/HalPwrSeqCmd.o
nothing special, except that it builds the 8188e tree:
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/Hal8188EPwrSeq.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_xmit.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_sreset.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_hal_init.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_phycfg.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_rf6052.o
  CC [M]  /usr/src/rtl8189ES_linux/hal/rtl8188e/rtl8188e_dm.o
  MODPOST 1 modules
license:        GPL
depends:
It still doesn't load:
[  682.251187] 8189es: module_layout: kernel tainted.
[  682.251207] Disabling lock debugging due to kernel taint
[  682.251255] 8189es: version magic '3.4.110 mod_unload ARMv7 p2v8 ' should be '3.4.110-sun8i SMP preempt mod_unload modversions ARMv7 p2v8 '
[ 1553.150477] 8189es: version magic '3.4.110 mod_unload ARMv7 p2v8 ' should be '3.4.110-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
Link to comment
  • 0
Jernej thinks, that inability to load the newly built module is related with the version magic.
This means that kernel thinks that module was compiled for different version, which is strange.
Neither of us knows much about this magic strings, but at least they should match in kernel version (3.4.110 vs 3.4.110-sun8i). Probably this is a result of crosscompiling.
Could you have a look again as I am building on Armbian directly, thus without cross compiling?
Jernej uses a kernels which have this check disabled.
Alternatively, could you build this module on your setup or let us the Git tree with some of the corrections, so that we could try building on our own?
Originally, I looked to rebuild the driver in order to enable the Monitor mode for the OPI+ wifi, which presumably is available in the driver's Makefile :
Link to comment
  • 0
The monitor mode is like the root access to your system. To make the full use of it, you ought to get the full access.
Besides, this practical experience will hopefully help building other drivers on the same system.
Link to comment
  • 0
Apparently, the magic version mismatch could be corrected with the setting
EXTRAVERSION =
http://linux.die.net/lkmpg/x380.html
I looked for that setting in the driver's tree, but unable to find it.
This setting exists in the
# /lib/modules/`uname -r`/build/Makefile
and it is empty.
As I understand it, this Makefile is the one used for the kernel building, not the module, hence it is not the one to correct.
Probably, it is not as complicated to resolve, provided finding out where the above setting is defined.
Does anybody could resolve it?
Link to comment
  • 0
You can try changing CONFIG_LOCALVERSION in /usr/src/linux-headers-3.4.110-sun8i/.config to see if it affects module version magic.
Edit:
is actually /usr/src/linux-headers-3.4.110-sun8i/Makefile, so try setting EXTRAVERSION there.
Edit 2:
Okay, I made some quick tests. You need to change either .config or Makefile, execute "make" in kernel headers directory (/usr/src/linux-headers-3.4.110-sun8i), it will return error, but it doesn't matter. After that newly compiled modules should have version "3.4.110-sun8i".
Link to comment
  • 0
This is almost it!
I editied the Makefile :
root@orangepiplus:/lib/modules/3.4.110-sun8i/build# vi Makefile
VERSION = 3
PATCHLEVEL = 4
SUBLEVEL = 110
#EXTRAVERSION =
EXTRAVERSION = -sun8i SMP preempt
root@orangepiplus:/lib/modules/3.4.110-sun8i/build# make
warning: (ARCH_SUN8I && ARCH_SUN9I && ARCH_TEGRA_2x_SOC && ARCH_TEGRA_3x_SOC && MACH_U300) selects PINCTRL which has unmet direct dependencies (EXPERIMENTAL)
Then I rebuilt the drive in a usual way:
Now
Gives the error:
[ 3785.304498] 8189es: version magic '3.4.110-sun8i SMP preempt mod_unload ARMv7 p2v8 ' should be '3.4.110-sun8i SMP preempt mod_unload modversions ARMv7 p2v8 '
So, the difference is minimal :
This time, I don't know which setting the word "modversions" comes from.
More efforts are necessary to resolving it. Pls assist.
Link to comment
  • 0
Please try removing kernel headers package, manually deleting /usr/src/linux-headers-3.4.110-sun8i/ directory and installing kernel headers package again.
I believe some of your compilation attempts with wrong commands overwrote supplied kernel configuration (in kernel headers directory), which caused all version magic mismatches.
If there will be compilation issues after that, go into kernel headers directory, execute "make M=scripts", change directory back and repeat your module compilation.
Link to comment
  • 0
http://openlinux.amlogic.com:8000/download/ARM/wifi/rtk8189es-2015-12-15-90ed86d42d.tar.gz
I succeed to port this driver to kernel.
Client and AP mode works.
Some speed tests, for stability ... we need to use it more.
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-10.1 sec  26.0 MBytes  21.6 Mbits/sec
[  3]  0.0-10.1 sec  23.1 MBytes  19.1 Mbits/sec
[  3]  0.0-10.3 sec  30.5 MBytes  24.9 Mbits/sec
Link to comment
  • 0
http://openlinux.aml...ed86d42d.tar.gz
I wrote an Armbian 5.05 to the new card,
Prepared the scripts:
Unzipped the sources above and tried building it :
root@orangepiplus:/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES# make ARCH=arm KSRC=/usr/src/linux-headers-$(uname -r)
make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- -C /usr/src/linux-headers-3.4.110-sun8i M=/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES  modules
make[1]: aarch64-linux-gnu-gcc: Command not found
  CC [M]  /usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES/core/rtw_cmd.o
/bin/sh: 1: aarch64-linux-gnu-gcc: not found
scripts/Makefile.build:307: recipe for target '/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES/core/rtw_cmd.o' failed
make[2]: *** [/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES/core/rtw_cmd.o] Error 127
Makefile:1367: recipe for target '_module_/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES' failed
make[1]: *** [_module_/usr/src/rtk8189es-2015-12-15-90ed86d42d/rtl8189ES] Error 2
Makefile:1507: recipe for target 'modules' failed
Is there special way deploying it ?
Link to comment
  • 0
Unfortunately the second driver, which have monitor mode,  I was not able to fix / adopt to kernel. My knowledge is also limited. Some drivers doesn't have simple hot-to-install and here is nothing I can do. The driver and kernel are too far away. Can't tell what to do.
If you want to test my build, download and install with su rights:
dpkg -i linux-image-sun8i_5.10_armhf.deb
Link to comment
  • 0
I also installed the linux-image-sun8i_5.10_armhf.deb package.
It also updated the kernel to
Linux orangepiplus 3.4.111-sun8i #26 SMP PREEMPT Wed Apr 27 19:50:35 CEST 2016 armv7l GNU/Linux
The downside for that package, is that the LED turns off after boot. There is no visual indicator for the SBC's working state.
Could it be corrected?
The wifi module is upgraded to
root@orangepiplus:/lib/modules/3.4.111-sun8i/kernel/drivers/net/wireless/rtl8189es# modinfo 8189es.ko
filename:       /lib/modules/3.4.111-sun8i/kernel/drivers/net/wireless/rtl8189es/8189es.ko
version:        v4.3.10.1_13373.20150129
but regretfully, the MONITOR MODE is not enabled.
How could a speed and stability be initiated to evaluate them?
Link to comment
  • 0
This driver does not have this option.
Stability with some longer usage, speed with iperf or similar.
Link to comment
  • 0
I was preparing to rebuild the '52ee6388111fbaf990ec60e93b086cafa6cc373a' commit
where the CONFIG_WIFI_MONITOR = y
on the linux-image-sun8i_5.10_armhf.deb package
It missed the headers:
root@orangepiplus:/usr/src/rtl8189ES_linux/platform# ls -al /usr/src/linux-headers-$(uname -r)
ls: cannot access /usr/src/linux-headers-3.4.111-sun8i: No such file or directory
Could you create the headers for your build and post the pakage?
Will you correct the LED issue?
Link to comment
  • 0
We exchanged the definition of both leds a while ago so that it matches with the way OpenELEC does (green == active, red reserved for 1st boot signaling or maybe in future for 'suspend to RAM'). So by choosing a new 5.10 image everything will be fine and by exchanging only some parts (u-boot, kernel, armhwinfo script) things will get messed up.
Link to comment
  • 0
I have been able rebuilding conveniently the 8189es driver on the regular Armbian 5.05 from the '52ee6388111fbaf990ec60e93b086cafa6cc373a' commit
The build went smoothly after replacing the platform_ARM_SUNnI_sdio.c in the driver's platform directory with the one from :
https://github.com/loboris/OrangePI-Kernel/blob/master/linux-3.4/drivers/net/wireless/rtl8189es/platform/platform_ARM_SUNnI_sdio.c
Then
root@orangepiplus:/usr/src/rtl8189ES_linux# make ARCH=arm KSRC=/usr/src/linux-headers-$(uname -r)
  MODPOST 1 modules
Looking at the info from :
root@orangepiplus:/usr/src/rtl8189ES_linux# lsmod 8189es.ko
Usage: lsmod
license:        GPL
srcversion:     374911DC5AF9842313AEAA0
depends:
vermagic:       3.4.110-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
This driver is more recent, than the one provided by Igor  Posted 27 April 2016 - 06:25 PM
Probably this is the reason, that the CONFIG_WIFI_MONITOR = y was not present in the v4.3.10.1_13373.20150129
Taken that knowledge, would it be possible porting the version: v4.3.18.1_15373.20151005 to the kernel.
The magic version matches the kernel well now and the module loads without errors:
The regular module with the Armbian 5.05:
Module                  Size  Used by
8189es                896688  0
Custom built module:
Module                  Size  Used by
8189es               1212556  0
How to replace the regular module with the custom one, so that to load it on the system boot up?
How the iperf could be used for testing the speed ?
Link to comment
  • 0
I have a question to Igor Pecovnik on which sources have he built his v4.3.10.1_13373.20150129 driver from?
The driver v4.3.18.1_15373.20151005, which was built from
https://github.com/rdm-dev/rtl8189ES_linux.git
doesn't recognize the SDIO RTL8189ETV module the OPI+ and wifi interface doesn't show up despite, that the module is loaded without errors:
the logs on the system boot up:
[    3.915685] RTL871X: module init start
[    3.915701] RTL871X: rtl8189es v4.3.18.1_15373.20151005
[    3.915710] RTL871X: build time: Apr 30 2016 21:01:55
[    3.915814] RTL871X: module init ret=0
Module                  Size  Used by
8189es               1212556  0
root@orangepiplus:~# iw list
root@orangepiplus:~# iwconfig
lo        no wireless extensions.
tunl0     no wireless extensions.
eth0      no wireless extensions.
My understanding is that the sources from
are not meant to work with the SDIO RTL8189ETV module the OPI+ is equipped with.
They are designed for the different WIFI IC, as listed in the Makefile below:
########################## WIFI IC ############################
CONFIG_MULTIDRV = n
CONFIG_RTL8188E = y
CONFIG_RTL8812A = n
CONFIG_RTL8821A = n
CONFIG_RTL8192E = n
CONFIG_RTL8723B = n
CONFIG_RTL8814A = n
CONFIG_RTL8703B = n
CONFIG_RTL8188F = n
How is the Makefile configured so that it recognizes the SDIO RTL8189ETV module in your build sources?
I knocked upon another explanations here :
http://www.spinics.net/lists/linux-wireless/msg140294.html
They are several ways possible:
1) to add support of the SDIO RTL8189ETV to the main tree here
2) rely on another driver
3) wait for the mainstream development.
4) forget the SDIO RTL8189ETV module.
Any solution would be helpful.
Link to comment
