  • 0
rebuild rtl8189es from GIT for OPI+
y52
Question
The built-in WIFI module doesn't switch to monitor mode. This makes me looking for rebuilding the module from the Git repository: https://github.com/rdm-dev/rtl8189ES_linux/tree/52ee6388111fbaf990ec60e93b086cafa6cc373a
I am stuck with the following error: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'. What is necessary to rebuild and replace the module with a new one?
Here is what was done so far:
root@orangepiplus:/usr/src/rtl8189ES_linux# uname -a Linux orangepiplus 3.4.110-sun8i #18 SMP PREEMPT Tue Mar 8 20:03:32 CET 2016 armv7l GNU/Linux
root@orangepiplus:/usr/src/rtl8189ES_linux# dmesg |grep 8189 [ 3.923104] RTL871X: rtl8189es v4.3.0.4_11916.20140724_COB [ 3.923090] RTL871X: module init start [ 3.923104] RTL871X: rtl8189es v4.3.0.4_11916.20140724_COB [ 3.923112] RTL871X: build time: Mar 8 2016 20:02:27 root@orangepiplus:~# lsmod Module Size Used by 8189es 896688 0
root@orangepiplus:~# rmmod 8189es
root@orangepiplus:/usr/src/rtl8189ES_linux# ls -al /lib/modules/`uname -r`/ lrwxrwxrwx 1 root root 36 Mar 8 20:03 build -> /usr/src/linux-headers-3.4.110-sun8i
root@orangepiplus:/usr/src# svn ls https://github.com/rdm-dev/rtl8189ES_linux/trunk
Kconfig
Makefile
clean
core/
hal/
ifcfg-wlan0
import-update.sh
include/
os_dep/
platform/
runwpa
wlan0dhcp
root@orangepiplus:/usr/src# svn export https://github.com/rdm-dev/rtl8189ES_linux/trunk
A trunk A trunk/Kconfig A trunk/Makefile A trunk/clean A trunk/core A trunk/core/efuse A trunk/core/efuse/rtw_efuse.c A trunk/core/rtw_ap.c A trunk/hal/efuse A trunk/hal/efuse/efuse_mask.h A trunk/hal/efuse/rtl8188e A trunk/hal/efuse/rtl8188e/HalEfuseMask8188E_PCIE.c A trunk/hal/efuse/rtl8188e/HalEfuseMask8188E_PCIE.h A trunk/hal/phydm/rtl8188e/hal8188ereg.h A trunk/runwpa A trunk/wlan0dhcp Exported revision 6.
root@orangepiplus:/usr/src# mv trunk rtl8189ES_linux
root@orangepiplus:/usr/src# ls -al rtl8189ES_linux
total 112 drwxr-xr-x 7 root root 4096 Apr 2 19:28 . drwxr-xr-x 11 root root 4096 Apr 2 19:30 .. -rw-r--r-- 1 root root 64 Oct 6 21:21 clean drwxr-xr-x 3 root root 4096 Apr 2 19:28 core drwxr-xr-x 8 root root 4096 Apr 2 19:28 hal -rw-r--r-- 1 root root 54 Oct 6 21:21 ifcfg-wlan0 -rwxr-xr-x 1 root root 496 Oct 6 21:21 import-update.sh drwxr-xr-x 4 root root 12288 Apr 2 19:28 include -rw-r--r-- 1 root root 110 Oct 6 21:21 Kconfig -rwxr-xr-x 1 root root 51507 Oct 6 21:21 Makefile drwxr-xr-x 3 root root 4096 Apr 2 19:28 os_dep drwxr-xr-x 2 root root 4096 Apr 2 19:28 platform -rw-r--r-- 1 root root 423 Oct 6 21:21 runwpa -rw-r--r-- 1 root root 294 Oct 6 21:21 wlan0dhcp
cd /usr/src/rtl8189ES_linux
root@orangepiplus:/usr/src/rtl8189ES_linux# make -C /lib/modules/`uname -r`/build
make: Entering directory '/usr/src/linux-headers-3.4.110-sun8i'
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf --silentoldconfig Kconfig
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
  UPD     include/generated/utsrelease.h
make[1]: *** No rule to make target 'arch/arm/tools/gen-mach-types', needed by 'include/generated/mach-types.h'.  Stop.
/usr/src/linux-headers-3.4.110-sun8i/arch/arm/Makefile:278: recipe for target 'archprepare' failed
make: *** [archprepare] Error 2
make: Leaving directory '/usr/src/linux-headers-3.4.110-sun8i'
Link to comment
Share on other sites
  • 0
I have a question to Igor Pecovnik on which sources have he built his v4.3.10.1_13373.20150129 driver from?
I wrote where I took source but I made changes to a code, since it's not working out of the box, and provide a patch against kernel. Since I was in a hurry I did not made any optimizations or else. It's build into kernel and it's working. Good enough? We will see.
Link to comment
Donate your old hardware to community. Start a giveaway Raffle!
  • 0
It is getting more clear, that the driver source code has been provided by Amlogic openlinux. I opened their Makefile, which still shows the setting for a different IC, namely :  CONFIG_RTL8188E = y
Do you have an idea of how the 8189 chip is recognized ?
I approached the developer of the source I've mentioned. What we told is:
> I have no clue where an official maintained project maintaining public part of rtl8189 driver.
> The repository you mentioned (https://github.com/rdm-dev/rtl8189ES_linux/) has the only goal to make the BSP for the HomePilot device compilable by external developers.
> Best regards,
> Jens
As I understand it, the Realtek themselves don't care much about the generic driver for their equipment. Is that the same approach with the OrangePI ?
Link to comment
  • 0
Thanks Igor, this is encouraging. Could you switch the
CONFIG_WIFI_MONITOR =
to yes ?
The only thing, which troubles me until I see the result, is that jernejsk has a 8188 adapter (USB), which, I believe, is different from 8189 SDIO
How could the patch be applied as mentioned on the link ?
https://github.com/jernejsk/OpenELEC-OPi2/blob/openelec-7.0/packages/linux-drivers/RTL8189ES/patches/RTL8189ES-000-change-build-settings.patch
Link to comment
  • 0
I've installed and it works fine so far. About 2% rx dropped on 2GB download, so not that bad. We'll see yet...
After few days of low activity, rx dropped packages rises to ca 12%.
Link to comment
  • 0
How  could the iperf be used for testing the speed ?
Jernejsk has kindly helped me building the new driver from
BTW: Another approach:
https://github.com/i...508183372d3c990
The driver is building without errors:
root@orangepiplus:/usr/src/rtl8189ES_linux# make ARCH=arm KSRC=/usr/src/linux-headers-$(uname -r) CROSS_COMPILE=
make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-headers-3.4.110-sun8i M=/usr/src/rtl8189ES_linux  modules
make[1]: Entering directory '/usr/src/linux-headers-3.4.110-sun8i'
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_cmd.o
  CC [M]  /usr/src/rtl8189ES_linux/core/rtw_security.o
I switched
CONFIG_WIFI_MONITOR = y
The module loads without problem :
root@orangepiplus:/usr/src/rtl8189ES_linux# insmod 8189es.ko
root@orangepiplus:/usr/src/rtl8189ES_linux# lsmod
Module                  Size  Used by
8189es               1082364  0
May  2 21:34:07 localhost kernel: [ 1382.566732] *******************Try sdio*******************
May  2 21:34:07 localhost kernel: [ 1382.578184] mmc1: new high speed SDIO card at address 0001
May  2 21:34:07 localhost kernel: [ 1382.578505] *******************sdio init ok*******************
root@orangepiplus:/usr/src/rtl8189ES_linux# iw list
        Supported interface modes:
                 * IBSS
                 * managed   <<-- appeared now
                 * AP
                 * monitor
                 * P2P-client
                 * P2P-GO
Another improvement could be observed as the previous driver always showed two wlan's. Now a single one is present:
root@orangepiplus:/usr/src/rtl8189ES_linux# iwconfig
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
The major deception comes from the ultimate goal to make the Monitor mode working with RTL8189, but it still doesn't :
[+] scanning for wireless devices...
[!] no wireless interfaces were found.
[!] you need to plug in a wifi device or install drivers.
I believe the Monitor mode has not just been implemented into the driver.
I had trouble installing it:
root@orangepiplus:/usr/src/rtl8189ES_linux# make install
install -p -m 644 8189es.ko
install: missing destination file operand after ‘8189es.ko’
Try 'install --help' for more information.
Makefile:1640: recipe for target 'install' failed
make: *** [install] Error 1
How could the driver be properly installed to the running system?
Link to comment
  • 0
Igor,
What do you mean by recipe ? Is it a step by step procedure or anything else?
The only difficulty I have is installing the driver with make:
Link to comment
  • 0
yes, recipe = step by step.
"install" want's to have a destination.
install -p -m 644 8189es.ko destination
That's a problem here, but don't bother since I will try to put it into kernel.
Link to comment
  • 0
Based on my 5.05 release experience, I was trying to reproduce the driver building on your new image
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# uname -a
Linux orangepiplus 3.4.112-sun8i #30 SMP PREEMPT Sat Apr 30 19:49:10 CEST 2016 armv7l GNU/Linux
It not building on this new build. I 1st tried without "make scripts" as I read in the release history that scripts are rebuilt on initial boot: "installing headers autocompile scripts"
But the driver build needs the scripts anyway :
make ARCH=arm CROSS_COMPILE= -C /usr/src/linux-headers-3.4.112-sun8i M=/usr/src/rtl8189ES_linux  modules
make[1]: Entering directory '/usr/src/linux-headers-3.4.112-sun8i'
/bin/sh: 1: /usr/src/linux-headers-3.4.112-sun8i/scripts/recordmcount: not found
scripts/Makefile.build:307: recipe for target '/usr/src/rtl8189ES_linux/core/rtw_cmd.o' failed
make[2]: *** [/usr/src/rtl8189ES_linux/core/rtw_cmd.o] Error 127
Makefile:1368: recipe for target '_module_/usr/src/rtl8189ES_linux' failed
make[1]: *** [_module_/usr/src/rtl8189ES_linux] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-3.4.112-sun8i'
Makefile:1634: recipe for target 'modules' failed
make: *** [modules] Error 2
Then I tried to "make scripts" but in vain :
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# cd /usr/src/linux-headers-$(uname -r)
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# make scripts
fs/Kconfig:287: can't open file "fs/fs_compat.kconfig"
/usr/src/linux-headers-3.4.112-sun8i/scripts/kconfig/Makefile:33: recipe for target 'silentoldconfig' failed
make[2]: *** [silentoldconfig] Error 1
/usr/src/linux-headers-3.4.112-sun8i/Makefile:493: recipe for target 'silentoldconfig' failed
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'scripts'.  Stop.
The driver build end up in an error :
root@orangepiplus:/usr/src/linux-headers-3.4.112-sun8i# cd /usr/src/rtl8189ES_linux/
Could you figure out, why the scripts are not
By the way, the Armbian's 5.10 wifi driver is outdated and doesn't correct the duplicated wlan:
root@orangepiplus:~# modinfo /lib/modules/3.4.112-
sun8i/kernel/drivers/net/wireless/rtl8189es/8189es.ko
version:        v4.3.10.1_13373.20150129
root@orangepiplus:~# iwconfig
wlan1     unassociated  Nickname:"<WIFI@REALTEK>"
Another remark for the 5.10 release is that boots significantly slower and the 1st phase of booting is not indicated by any LED (all off). It is very confusing, as one may think, that the boot doesn't run.
Link to comment
  • 0
Unfortunately, I have no possibility to rebuild the kernel at that stage. Could the scripts compilation fix be posted or a minor release be published?
Link to comment
  • 0
This would be great to complete at least this task ... find other bugs ;)
We are still in the fixing phase and small things can be done withing this release.
Link to comment
  • 0
Thanks to the Armbian team for the headers scripts generation bug fixing and the minor version 5.11 release.
I was able upgrading the 5.10 image to 5.11 and building the 5 october .
Here is a recipe :
root@orangepiplus:~# apt-get update && apt-get upgrade
root@orangepiplus:~# cd /usr/src/linux-headers-$(uname -r)
root@orangepiplus:/usr/src# git clone https://github.com/jwrdegoede/rtl8189ES_linux/
root@orangepiplus:/usr/src# cd rtl8189ES_linux
root@orangepiplus:/usr/src/rtl8189ES_linux# git checkout 080f2aaf6bc8e08eeb3b51f0b8c377eae1ea7ed7
wget https://raw.githubusercontent.com/jernejsk/OpenELEC-OPi2/openelec-7.0/packages/linux-drivers/RTL8189ES/patches/RTL8189ES-000-change-build-settings.patch
root@orangepiplus:/usr/src/rtl8189ES_linux# patch -p1 < RTL8189ES-000-change-build-settings.patch
The "make install" doesn't run. I copied it manually :
cp -a 8189es.ko /lib/modules/3.4.112-sun8i/kernel/drivers/net/wireless/rtl8189es/
root@orangepiplus:/usr/src/rtl8189ES_linux# modinfo 8189es.ko
filename:       /usr/src/rtl8189ES_linux/8189es.ko
version:        v4.3.18.1_15373.20151005 <== 5 october 2015
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     AD6BE9C509ECC03E70462BA
alias:          sdio:c*v024Cd8179*
depends:
vermagic:       3.4.112-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
I enabled the Monitor mode in the Make file.
It even shows up in the module capabilities:
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP (00-0f-ac:4)
        Available Antennas: TX 0 RX 0
                 * IBSS
                 * managed
                 * AP
                 * monitor   <----
                 * P2P-client
                 * P2P-GO
        software interface modes (can always be added):
                 * monitor
Unfortunately, the switch to monitor mode doesn't run :
"iwconfig wlan0 mode monitor"
oot@orangepiplus:/usr/src/rtl8189ES_linux# iwconfig wlan0 mode monitor
Error for wireless request "Set Mode" (8B06) :
    SET failed on device wlan0 ; Operation not permitted.
Despite this, the positive bug fix for this driver is that the wlan interface shows up correctly in the single instance and is not duplicated:
lo        no wireless extensions.
tunl0     no wireless extensions.
I haven't tested the driver performance and the packets drop rate.
I believe it is worth integrating in the new release.
Link to comment
  • 0
This is easy to check. Here is a log :
root@orangepiplus:~# date
Thu May 26 23:20:49 CEST 2016
root@orangepiplus:~# ifconfig wlan0 down
The wlan0 still present :
root@orangepiplus:~# iwconfig wlan0 mode monitor
root@orangepiplus:~# ifconfig wlan0 up
Link to comment
  • 0
I checked source code and monitor mode seems to be supported. Maybe you can try this:
sudo iw phy phy0 interface add wlan1 type monitor
where wlan1 is some unused interface. If that doesn't work, try to play with ifconfig up/down before.
At the end, you will have two interfaces, linked to same physical device. You can remove unneeded one with:
sudo iw <interface> del
where <interface> is the name of the interface you want to delete.
Link to comment
  • 0
It seems this method fails as well on the rtl8189 driver build.
" iw phy phy0 interface add mon0 type monitor "
creates a somewhat nonfunctional interface, which does nothing, and is not capable monitoring network activities.
I have another dongle WiFi. It switches to monitor mode natively:
root@bananapipro:~# lsmod
Module                  Size  Used by
rt2800usb              17661  0
rt2800lib              71334  1 rt2800usb
root@bananapipro:~#  iwconfig
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
root@bananapipro:~# iwconfig wlan0 mode monitor
wlan0     IEEE 802.11bgn  Mode:Monitor  Tx-Power=0 dBm
          Encryption key:off
Another method works as well:
root@bananapipro:~# iw phy phy0 interface add mon0 type monitor
          Encryption key:off
mon0      IEEE 802.11bgn  Mode:Monitor  Tx-Power=0 dBm
The mon0 works with rt2800usb but fails with rtl8189
Link to comment
  • 0
To reproduce your scenario :
Sun May 29 23:20:01 CEST 2016
Module                  Size  Used by
8189es               1082364  0
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
root@orangepiplus:~# iw phy phy0 interface add mon0 type monitor
mon0      IEEE 802.11bg  Mode:Monitor  Tx-Power=12 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Sensitivity:0/0
          Encryption key:off
root@orangepiplus:~# iw wlan0 del
          Power Management:on
root@orangepiplus:~# airodump-ng mon0
 CH 11 ][ Elapsed: 20 s ][ 2016-05-29 23:23
 BSSID              PWR  Beacons    #Data, #/s  CH  MB   ENC  CIPHER AUTH ESSID
Doesn't find any wireless network.
Link to comment
  • 0
@y52,
just for fun I tried to use monitor mode on OPi2 using my OpenELEC system. I installed wireless tools and tcpdump from repo and to my amazement, it worked. So I think some service on Armbian is preventing wifi to work correctly. Maybe you will have more luck now that Igor included latest driver in regular builds.
Link to comment
  • 0
@jernej
Have you made changes to your
https://raw.githubusercontent.com/jernejsk/OpenELEC-OPi2/openelec-7.0/packages/linux-drivers/RTL8189ES/patches/RTL8189ES-000-change-build-settings.patch   ?
This patch doesn't enable Monitor mode and needs to be manually correctly to enable it.
Probably it would be necessary submitting a revised one to Igor, so that he includes the monitor capability to regular builds, despite that I was unable to produce this mode working on the Armbian system.
@xwalter
I haven't yet tried the AP mode. It is on the list, but other priorities prevent from testing it.
Link to comment
