ottuzzi Posted January 24, 2019 Share Posted January 24, 2019 Hi, toying around with Odroid C1 kernel compilation and trying new kernels (both 5.0-rc2 and the mainline amlogic kernel) there are some patches that do no apply correctly. Both general-packaging-4.17-next.patch and general-increasing_DMA_block_memory_allocation_to_2048.patch apply correctly if I remove the part of the patch referring arm64 architecture: is this fine? For sure Odroid C1 is a 32-bit SBC.. does anyone knows why there are references for arm64? If you agree I can create a pull request to remove those lines... Thanks **Bye Piero Link to comment Share on other sites More sharing options...
Igor Posted January 24, 2019 Share Posted January 24, 2019 48 minutes ago, ottuzzi said: Hi, toying around with Odroid C1 kernel compilation and trying new kernels (both 5.0-rc2 and the mainline amlogic kernel) there are some patches that do no apply correctly. Both general-packaging-4.17-next.patch and general-increasing_DMA_block_memory_allocation_to_2048.patch apply correctly if I remove the part of the patch referring arm64 architecture: is this fine? For sure Odroid C1 is a 32-bit SBC.. does anyone knows why there are references for arm64? If you agree I can create a pull request to remove those lines... Thanks **Bye Piero You can do that, while the best is to fix patch accordingly and rename to general-packaging-5.x-next.patch Someone has to be the 1st adjuster We will need it elsewhere sooner or later. Link to comment Share on other sites More sharing options...
Igor Posted January 25, 2019 Share Posted January 25, 2019 11 hours ago, ottuzzi said: toying around with Odroid C1 https://github.com/armbian/build/commit/5a0d83a316e19a3df6a6fd1f8bb536a88ca8e924 Link to comment Share on other sites More sharing options...
