maruprez Posted April 3, 2016 Share Posted April 3, 2016 Hi, I've installed Armbian 5.0.4 Wheezy. I'm trying to configure the sound, but no success jme@cubieboard:~$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sun4icodec [sun4i-codec], device 0: CDC PCM Codec-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 jme@cubieboard:~$ cat /etc/asound.conf pcm.!default { type hw card 0 device 0 } ctl.!default { type hw card 0 } jme@cubieboard:~$ speaker-test -twav -c2 speaker-test 1.0.25 Playback device is default Stream parameters are 48000Hz, S16_LE, 2 channels WAV file(s) Rate set to 48000Hz (requested 48000Hz) Buffer size range from 128 to 131072 Period size range from 64 to 16384 Using max buffer size 131072 Periods = 4 was set period_size = 16384 was set buffer_size = 131072 0 - Front Left 1 - Front Right Write error: -5,Input/output error xrun_recovery failed: -5,Input/output error Transfer failed: Operation not permitted Any idea ? Thank's Regards Link to comment Share on other sites More sharing options...
Igor Posted April 3, 2016 Share Posted April 3, 2016 Audio might be muted, permission related - try playing audio under root. Link to comment Share on other sites More sharing options...
maruprez Posted April 4, 2016 Author Share Posted April 4, 2016 Hi Igor, Once again thank's a lot!! Unfortunately it's not the problem root@cubieboard:/home/jme# speaker-test -twav -c2 speaker-test 1.0.25 Playback device is default Stream parameters are 48000Hz, S16_LE, 2 channels WAV file(s) Rate set to 48000Hz (requested 48000Hz) Buffer size range from 128 to 131072 Period size range from 64 to 16384 Using max buffer size 131072 Periods = 4 was set period_size = 16384 was set buffer_size = 131072 0 - Front Left 1 - Front Right Write error: -5,Input/output error xrun_recovery failed: -5,Input/output error Transfer failed: Operation not permitted Regards Link to comment Share on other sites More sharing options...
Igor Posted April 4, 2016 Share Posted April 4, 2016 Then it might be broken in kernel. I'll do testing on new images / kernel builds ... soon. Link to comment Share on other sites More sharing options...
maruprez Posted April 4, 2016 Author Share Posted April 4, 2016 Thank's a lot!!! Link to comment Share on other sites More sharing options...
