jarmx Posted February 1, 2019 Posted February 1, 2019 (edited) Hi all, I have a OrangePi R1 and want to enable SPI in U-Boot to talk to connected leds. The leds are connected to SPI0 on the pins: 19 (MOSI), 4 (5v) and 6 (GND) . I enabled the CONFIG_SUN4I_SPI flag to enable the sunxi SPI driver. I also added the following lines to `arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts` to enable both SPI0 and SPI1. &spi0 { status = "okay"; flash@0 { compatible = "mxicy,mx25l12805d", "jedec,spi-nor"; }; }; &spi1 { status = "okay"; }; To control the leds I added a call to the following function inside the `board_init()` function inside: `/board/sunxi/board.c`. static int set_leds() { int bus = 0; int cs = 1; int mode = 0; struct spi_slave *slave; int ret = 0; printf("set_leds"); char name[30], *str; struct udevice *dev; snprintf(name, sizeof(name), "generic_%d:%d", bus, cs); str = strdup(name); if (!str) return -ENOMEM; ret = spi_get_bus_and_cs(bus, cs, 38095, mode, "spi_generic_drv",str, &dev, &slave); if (ret) return ret; ret = spi_claim_bus(slave); if (ret) goto done; uchar dout[2]; uchar din[2]; int bitlen = 16; ret = spi_xfer(slave, bitlen, dout, din, SPI_XFER_BEGIN | SPI_XFER_END); done: spi_release_bus(slave); spi_free_slave(slave); } (please note that I am not transferring the actual data needed by the leds in this sample code) When I flash the bootloader the leds wont respond (but I see the message printed in the console). I don''t have an oscilloscope so I am not able to see if the `spi_xfer` function actual sends the data. So my question is does this code look okey? Or is there something I am missing? Edited February 1, 2019 by jarmx
martinayotte Posted February 1, 2019 Posted February 1, 2019 2 hours ago, jarmx said: When I flash the bootloader the leds wont respond Which LEDs are you talking about ?
jarmx Posted February 1, 2019 Author Posted February 1, 2019 I am using 4 WS2812B leds. When booted in armbian I control them using this python library: https://github.com/joosteto/ws2812-spi.
martinayotte Posted February 1, 2019 Posted February 1, 2019 4 minutes ago, jarmx said: I am using 4 WS2812B leds. So, in this case, why you need u-boot to control them if you are using python in userspace ?
jarmx Posted February 1, 2019 Author Posted February 1, 2019 I want them to turn on immediately when you power the board, booting to userspace takes around 15 seconds. I have SPI sort of working now. I can send data to the leds but they only set the data when I disconnect and reconnect the MISO wire. Seems like a issue with the line not pulling up / down. Not sure how to fix this though.
jarmx Posted February 1, 2019 Author Posted February 1, 2019 It it possible that the SPI driver in uboot for sun4i only works for SPI0? I see lines like 'sunxi_gpio_set_cfgpin(pin, SUNXI_GPC_SPI0);' inside the driver. Is there any know driver that works for SPI1?
martinayotte Posted February 1, 2019 Posted February 1, 2019 1 hour ago, jarmx said: Is there any know driver that works for SPI1? I really don't know ... SPI in U-Boot is basically present for booting from SPIFlash, so maybe the code isn't there for such use-case ...
zador.blood.stained Posted February 1, 2019 Posted February 1, 2019 There is no SPI driver for H3 in the "main" u-boot (CONFIG_SUN4I_SPI is for older SoCs), but software SPI (CONFIG_SOFT_SPI) should work if configured correctly.
jarmx Posted February 4, 2019 Author Posted February 4, 2019 I am trying to get software SPI to work. But I have some difficulties to get the driver working. I have added `CONFIG_SOFT_SPI=y` to `configs/orangepi_r1_defconfig` and added the following lines to the file in `arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts` but for some reason the driver is not getting probed. Can you see why this is? (probably a stupid mistake ) soft_spi: soft-spi { compatible = "spi-gpio"; cs-gpios = <&pio 0 13 0>; gpio-sck = <&pio 0 14 0>; gpio-mosi = <&pio 0 15 0>; }; (lines added to: `arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts` after the `aliases` node) => dm tree Class index Probed Driver Name ----------------------------------------- root 0 [ + ] root_drive root_driver simple_bus 0 [ + ] generic_si |-- soc phy 0 [ + ] sun4i_usb_ | |-- phy@1c19400 usb 0 [ + ] ehci_sunxi | |-- usb@1c1a000 usb_hub 0 [ + ] usb_hub | | `-- usb_hub usb 1 [ + ] ohci_sunxi | |-- usb@1c1a400 usb 2 [ + ] ehci_sunxi | |-- usb@1c1b000 usb_hub 1 [ + ] usb_hub | | `-- usb_hub usb 3 [ + ] ehci_sunxi | |-- usb@1c1c000 usb_hub 2 [ + ] usb_hub | | `-- usb_hub usb 4 [ + ] ohci_sunxi | |-- usb@1c1c400 gpio 0 [ + ] gpio_sunxi | |-- pinctrl@1c20800 gpio 1 [ + ] gpio_sunxi | | |-- PA gpio 2 [ + ] gpio_sunxi | | |-- PB gpio 3 [ + ] gpio_sunxi | | |-- PC gpio 4 [ + ] gpio_sunxi | | |-- PD gpio 5 [ + ] gpio_sunxi | | |-- PE gpio 6 [ + ] gpio_sunxi | | |-- PF gpio 7 [ + ] gpio_sunxi | | |-- PG gpio 8 [ + ] gpio_sunxi | | |-- PH gpio 9 [ + ] gpio_sunxi | | `-- PI eth 0 [ + ] eth_sun8i_ | |-- ethernet@1c30000 serial 0 [ + ] ns16550_se | |-- serial@1c28000 gpio 10 [ + ] gpio_sunxi | `-- pinctrl@1f02c00 gpio 11 [ + ] gpio_sunxi | `-- PL spi 0 [ ] soft_spi `-- soft-spi (output from U-Boot when issuing the `dm tree` command)
zador.blood.stained Posted February 4, 2019 Posted February 4, 2019 I tested it on OPi Zero (basically the same device) with u-boot master branch and it passed the loopback test. defconfig changes: diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index e5a4c1d9fc..39528026a6 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -9,10 +9,19 @@ CONFIG_DRAM_ODT_EN=y CONFIG_SPL_SPI_SUNXI=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +# CONFIG_USE_BOOTCOMMAND is not set CONFIG_CONSOLE_MUX=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y CONFIG_SUN8I_EMAC=y -CONFIG_USB_OHCI_HCD=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SOFT_SPI=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y DT changes: diff --git a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts index 0bc031fe4c..40b078723d 100644 --- a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts +++ b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts @@ -59,6 +59,8 @@ /* ethernet0 is the H3 emac, defined in sun8i-h3.dtsi */ ethernet0 = &emac; ethernet1 = &xr819; + spi0 = &softspi0; + spi1 = &softspi1; }; chosen { @@ -89,6 +91,26 @@ gpio = <&pio 0 20 GPIO_ACTIVE_HIGH>; }; + softspi0: soft-spi0 { + compatible = "spi-gpio"; + status = "okay"; + gpio-sck = <&pio 2 2 0>; + gpio-mosi = <&pio 2 0 0>; + gpio-miso = <&pio 2 1 0>; + cs-gpios = <&pio 2 3 0>; + num-chipselects = <1>; + }; + + softspi1: soft-spi1 { + compatible = "spi-gpio"; + status = "okay"; + gpio-sck = <&pio 0 14 0>; + gpio-mosi = <&pio 0 15 0>; + gpio-miso = <&pio 0 16 0>; + cs-gpios = <&pio 0 13 0>; + num-chipselects = <1>; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; Partial console log: => echo loopback wire disconnected loopback wire disconnected => sspi 1:0 16 1234 0000 => echo loopback wire connected loopback wire connected => sspi 1:0 16 1234 1234 => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver simple_bus 0 [ + ] generic_simple_bus |-- soc mmc 0 [ + ] sunxi_mmc | |-- mmc@1c0f000 blk 0 [ ] mmc_blk | | `-- mmc@1c0f000.blk mmc 1 [ + ] sunxi_mmc | |-- mmc@1c10000 blk 1 [ ] mmc_blk | | `-- mmc@1c10000.blk phy 0 [ + ] sun4i_usb_phy | |-- phy@1c19400 usb 0 [ + ] ehci_generic | |-- usb@1c1a000 usb_hub 0 [ + ] usb_hub | | `-- usb_hub usb 1 [ + ] ohci_generic | |-- usb@1c1a400 usb_hub 1 [ + ] usb_hub | | `-- usb_hub usb 2 [ + ] ehci_generic | |-- usb@1c1b000 usb_hub 2 [ + ] usb_hub | | `-- usb_hub usb 3 [ + ] ohci_generic | |-- usb@1c1b400 usb_hub 3 [ + ] usb_hub | | `-- usb_hub clk 0 [ + ] sun8i_h3_ccu | |-- clock@1c20000 reset 0 [ + ] sunxi_reset | | `-- reset gpio 0 [ + ] gpio_sunxi | |-- pinctrl@1c20800 gpio 1 [ + ] gpio_sunxi | | |-- PA gpio 2 [ + ] gpio_sunxi | | |-- PB gpio 3 [ + ] gpio_sunxi | | |-- PC gpio 4 [ + ] gpio_sunxi | | |-- PD gpio 5 [ + ] gpio_sunxi | | |-- PE gpio 6 [ + ] gpio_sunxi | | |-- PF gpio 7 [ + ] gpio_sunxi | | |-- PG gpio 8 [ + ] gpio_sunxi | | |-- PH gpio 9 [ + ] gpio_sunxi | | `-- PI eth 0 [ + ] eth_sun8i_emac | |-- ethernet@1c30000 serial 0 [ + ] ns16550_serial | |-- serial@1c28000 gpio 10 [ + ] gpio_sunxi | `-- pinctrl@1f02c00 gpio 11 [ + ] gpio_sunxi | `-- PL spi 0 [ + ] soft_spi |-- soft-spi0 spi_generi 0 [ + ] spi_generic_drv | `-- generic_0:0 spi 1 [ + ] soft_spi |-- soft-spi1 spi_generi 1 [ + ] spi_generic_drv | `-- generic_1:0 clk 1 [ + ] fixed_rate_clock |-- osc24M_clk clk 2 [ + ] fixed_rate_clock |-- osc32k_clk clk 3 [ ] fixed_rate_clock `-- internal-osc-clk =>
jarmx Posted February 6, 2019 Author Posted February 6, 2019 @zador.blood.stained That worked, thank you very much
