Jarek Posted February 2, 2019 Share Posted February 2, 2019 Armbianmonitor: http://ix.io/1zP0 Hello, I am new to Orange PI and Armbian. I try to configure orange pi to run chineese LCD 5 inch screen via HDMI. I managed to do that using lubuntu downloaded from orangepi server. I changed fex file to what I found on the internet: [clock] pll_video = 321 [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 3 screen0_output_mode = 2 screen1_output_type = 3 screen1_output_mode = 2 fb0_width = 720 fb0_height = 480 fb0_scaler_mode_enable = 1 fb0_pixel_sequence = 2 fb0_format = 4 fb0_framebuffer_num = 2 fb1_width = 720 fb1_height = 480 fb1_scaler_mode_enable = 1 fb1_pixel_sequence = 2 fb1_format = 4 fb1_framebuffer_num = 2 [hdmi_para] hdmi_used = 1 hdmi_x = 720 hdmi_y = 480 hdmi_power = "vcc-hdmi-18" hdmi_cts_compatibility = 1 After positve tests I wstiched to Armbian 5.72 kernel 4.18.17-sunxi. Generaly I could not find on the inter / googled/ searched thru armbian formu waht should I do to recofigure sam as in fex files. What I understad new kernels does not support fex files any more. Is there any way to change HDMI cofig simillar way as in fex files? Currently I try to recompile kernel (never did that before) I also changed orangepipcplus.fex file which i found in armbian git repository. I would appreciate any help or links. Thanks! Link to comment Share on other sites More sharing options...
0 jernej Posted February 4, 2019 Share Posted February 4, 2019 On 2/2/2019 at 4:28 PM, Jarek said: Is there any way to change HDMI cofig simillar way as in fex files? There is no need to do that on mainline based images (you posted 4.19, which qualifies for that). Display should be configured properly automatically. If not, then there is a bug either in the HDMI/display driver or in EDID data stored in your screen. That said, there was one HDMI bug which was fixed in 4.20. In short, some resolutions didn't work. Link to comment Share on other sites More sharing options...
0 Jarek Posted February 4, 2019 Author Share Posted February 4, 2019 Yes I found EDID data are corrupted. I tried to get proper EDID by your customized u-boot: https://github.com/jernejsk/u-boot Using uart debug I got: HDMI connected: EDID block 0: checksum error, retrying EDID block 0: checksum error, retrying EDID block 0: checksum error But I found a solution and will try to preapre patch. I am completly new to such thinkgs so it will take some time. Also my C++ is kind of basic-moderate... I also noticed that u-boot is switching to 1024x768 in sunxi_display.c: video_get_ctfb_res_modes(RES_MODE_1024x768, 24, &mode, &sunxi_display.depth, &options); so I changed 1024x768 to 800x600 - this resolution I used as guided here: https://www.instructables.com/id/Orange-PI-HowTo-Set-It-Up-to-Use-With-a-5-HDMI-TFT/ and corrected in videomodes.c : #ifndef CONFIG_VIDEO_STD_TIMINGS { 640, 480, 60, 39721, 25180, 40, 24, 32, 11, 96, 2, 0, FB_VMODE_NONINTERLACED}, { 800, 600, 60, 27778, 36000, 64, 24, 22, 1, 72, 2, 0, FB_VMODE_NONINTERLACED}, {1024, 768, 60, 15384, 65000, 168, 8, 29, 3, 144, 4, 0, FB_VMODE_NONINTERLACED}, { 960, 720, 80, 13100, 76335, 160, 40, 32, 8, 80, 4, 0, FB_VMODE_NONINTERLACED}, {1152, 864, 60, 12004, 83300, 200, 64, 32, 16, 80, 4, 0, FB_VMODE_NONINTERLACED}, {1280, 1024, 60, 9090, 110000, 200, 48, 26, 1, 184, 3, 0, FB_VMODE_NONINTERLACED}, line: { 800, 600, 60, 27778, 36000, 64, 24, 22, 1, 72, 2, 0, FB_VMODE_NONINTERLACED}, to { 800, 600, 60, 32100, 36000, 64, 24, 22, 1, 72, 2, 0, FB_VMODE_NONINTERLACED}, 27778 I figured out from the rest of u-boot code is my PLL so I changed to 32100 (321 is PLL from fex file) LCD started to work. I assume that good way is to prepare patch and recompile all and than install by dpkg. So if someone wants to patch just do or not. Let me know if this is good way. Thanks Jarek Link to comment Share on other sites More sharing options...
0 Jarek Posted February 7, 2019 Author Share Posted February 7, 2019 I tried to apply my changes to latest armbian build (https://github.com/armbian/build) No sucess... Patch content: diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 6dd9bec..7f84335 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -1091,7 +1091,7 @@ void *video_hw_init(void) memset(&sunxi_display, 0, sizeof(struct sunxi_display)); - video_get_ctfb_res_modes(RES_MODE_1024x768, 24, &mode, + video_get_ctfb_res_modes(RES_MODE_800x480, 24, &mode, &sunxi_display.depth, &options); #ifdef CONFIG_VIDEO_HDMI hpd = video_get_option_int(options, "hpd", 1); @@ -1121,12 +1121,12 @@ void *video_hw_init(void) ret = sunxi_hdmi_hpd_detect(hpd_delay); if (ret) { printf("HDMI connected: "); - if (edid && sunxi_hdmi_edid_get_mode(&custom) == 0) { - if ((custom.xres <= 1920) && (custom.yres <= 1080)) - mode = &custom; - else - mode = &res_mode_init[RES_MODE_1920x1080]; - } + if (edid && sunxi_hdmi_edid_get_mode(&custom) == 0) { + if ((custom.xres <= 1920) && (custom.yres <= 1080)) + mode = &custom; + else + mode = &res_mode_init[RES_MODE_800x480]; + } } else if (hpd) { sunxi_hdmi_shutdown(); sunxi_display.monitor = sunxi_get_default_mon(false); diff --git a/drivers/video/videomodes.c b/drivers/video/videomodes.c index 74bafff..6f494f7 100644 --- a/drivers/video/videomodes.c +++ b/drivers/video/videomodes.c @@ -83,6 +83,10 @@ const struct ctfb_vesa_modes vesa_modes[VESA_MODES_COUNT] = { {0x319, RES_MODE_1280x1024, 15}, {0x31A, RES_MODE_1280x1024, 16}, {0x31B, RES_MODE_1280x1024, 24}, + {0x303, RES_MODE_800x480, 8}, + {0x313, RES_MODE_800x480, 15}, + {0x314, RES_MODE_800x480, 16}, + {0x315, RES_MODE_800x480, 24}, }; const struct ctfb_res_modes res_mode_init[RES_MODES_COUNT] = { /* x y hz pixclk ps/kHz le ri up lo hs vs s vmode */ @@ -105,6 +109,7 @@ const struct ctfb_res_modes res_mode_init[RES_MODES_COUNT] = { {1360, 768, 60, 11696, 85500, 256, 64, 17, 3, 112, 7, 0, FB_VMODE_NONINTERLACED}, {1920, 1080, 60, 6734, 148500, 148, 88, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, FB_VMODE_NONINTERLACED}, {1920, 1200, 60, 6494, 154000, 80, 48, 26, 3, 32, 6, FB_SYNC_HOR_HIGH_ACT, FB_VMODE_NONINTERLACED}, + { 800, 480, 60, 32100, 36000, 64, 24, 22, 1, 72, 2, 0, FB_VMODE_NONINTERLACED}, }; /************************************************************************ diff --git a/drivers/video/videomodes.h b/drivers/video/videomodes.h index 29a3db4..bc22b1a 100644 --- a/drivers/video/videomodes.h +++ b/drivers/video/videomodes.h @@ -68,9 +68,10 @@ struct ctfb_vesa_modes { #define RES_MODE_1360x768 7 #define RES_MODE_1920x1080 8 #define RES_MODE_1920x1200 9 -#define RES_MODES_COUNT 10 +#define RES_MODE_800x480 10 +#define RES_MODES_COUNT 11 -#define VESA_MODES_COUNT 19 +#define VESA_MODES_COUNT 23 extern const struct ctfb_vesa_modes vesa_modes[]; extern const struct ctfb_res_modes res_mode_init[]; I put it into userpatches/u-boot/u-boot-sunxi It seems during compilation process it is applied but cannot see any changes after istalling deb packages. Also I can not see any output information considering HDMI via UART during boot. It seems to me that the code of sunxi_display.c (/divers/video/sunxi of u-boot) is not enabled and I do not know how to fix it. The code I mean is: ifdef CONFIG_VIDEO_HDMI /* If HDMI/DVI is selected do HPD & EDID, and handle fallback */ if (sunxi_display.monitor == sunxi_monitor_dvi || sunxi_display.monitor == sunxi_monitor_hdmi) { /* Always call hdp_detect, as it also enables clocks, etc. */ ret = sunxi_hdmi_hpd_detect(hpd_delay); if (ret) { printf("HDMI connected: "); if (edid && sunxi_hdmi_edid_get_mode(&custom) == 0) { if ((custom.xres <= 1920) && (custom.yres <= 1080)) mode = &custom; else mode = &res_mode_init[RES_MODE_800x480]; } } else if (hpd) { sunxi_hdmi_shutdown(); sunxi_display.monitor = sunxi_get_default_mon(false); } /* else continue with hdmi/dvi without a cable connected */ } #endif I do not know where shoud I put CONFIG_VIDEO_HDMI to enable code. The mass of codes kills me... Appreciate any help ... Thanks Jarek Link to comment Share on other sites More sharing options...
0 jernej Posted February 7, 2019 Share Posted February 7, 2019 Which kernel do you use? Link to comment Share on other sites More sharing options...
0 Jarek Posted February 7, 2019 Author Share Posted February 7, 2019 1 hour ago, jernej said: Which kernel do you use? Linux orangepipcplus 4.19.19-sunxi #5.74 SMP Thu Feb 7 21:30:44 CET 2019 armv7l armv7l armv7l GNU/Linux Link to comment Share on other sites More sharing options...
0 jernej Posted February 8, 2019 Share Posted February 8, 2019 Then U-Boot doesn't have anything to do with your Linux display issues. Linux driver re-initializes all peripherals responsible for video output. There are 2 possible solutions: 1. disable display driver in U-Boot (there are some handover issues, which might prevent Linux driver from working correctly) 2. backport clock patches from 4.20 or use 4.20 (there was a bug which prevented correct initialization for some resolutions) Possibly you have to do both... Link to comment Share on other sites More sharing options...
0 Jarek Posted February 10, 2019 Author Share Posted February 10, 2019 On 2/8/2019 at 7:19 AM, jernej said: Then U-Boot doesn't have anything to do with your Linux display issues. Linux driver re-initializes all peripherals responsible for video output. There are 2 possible solutions: 1. disable display driver in U-Boot (there are some handover issues, which might prevent Linux driver from working correctly) 2. backport clock patches from 4.20 or use 4.20 (there was a bug which prevented correct initialization for some resolutions) Possibly you have to do both... I switched to 4.20. I tried many different options with no luck. I also prepared new .bin file -> following /documentation/EDID with no luck. I just can't believe that it is so hard to change that pixelclock from 27000 to 32100 (screen is 800x480 and it works with 66Hz). It is just one number that worked good using fex files... I'm completly disappointed Link to comment Share on other sites More sharing options...
Question
Jarek
[clock]
pll_video = 321
[disp_init]
disp_mode = 0
fb0_width = 720
fb0_height = 480
fb0_format = 4
fb1_width = 720
fb1_height = 480
fb1_format = 4
[hdmi_para]
hdmi_used = 1
hdmi_x = 720
hdmi_y = 480
Thanks!
Link to comment
7 answers to this question
