köksal Posted February 7, 2019 Posted February 7, 2019 "Language Support Setting" not exist on Menu of Debian(Armbian_5.69_Orangepipcplus_Debian_stretch_next_4.19.13)
JMCC Posted February 7, 2019 Posted February 7, 2019 What do you mean, the "Language support" menu entry in the Xfce graphical menu? That is a Ubuntu specific app, you won't find it in any Debian. For changing the language, use "armbian-config" instead.
manuti Posted February 8, 2019 Posted February 8, 2019 Check this post: Maybe is that you are looking for. 1
JMCC Posted February 8, 2019 Posted February 8, 2019 2 hours ago, manuti said: Check this post: Maybe is that you are looking for. I think that process is not necessary anymore, armbian-config should be enough to take care of configuring the locales. @köksal please confirm if it worked for you. 1
köksal Posted February 12, 2019 Author Posted February 12, 2019 Quote On 2/8/2019 at 3:41 PM, JMCC said: I think that process is not necessary anymore, armbian-config should be enough to take care of configuring the locales. @köksal please confirm if it worked for you. İt works. Thanks you. But when i set only with armbian-config, it didn't enough. i used "sudo locale-gen tr_TR.UTF-8 " too. Thank you @manuti.
