I just picked up a USB-C hub, it has 3 USB 3.0 ports, 2 SD card slots (standard and micro), a DVI and a GbE ethernet.  Using it with my NanoPC T4, and a test with the Renegade Elite (not Armbian) both showed an odd behavior with the GbE, the driver loads, but then claims it doesn't recognize the device after reading it's firmware.  Does anyone else have an adapter based on this chip?  My cell phone recognized it and used it right away  :lol:
[ 2186.114873] r8152 7-1.4:1.0 (unnamed net_device) (uninitialized): Unknown version 0x6010
[ 2186.114896] r8152 7-1.4:1.0 (unnamed net_device) (uninitialized): Unknown Device
ok, found a rejected patch, so some digging should help
https://patchwork.ozlabs.org/patch/757827/
OK, that one-liner works.  From what I can tell the shift from vid:pid to this firware revision was to reduce source code overhead, and it broke the 0x6010 cards that worked beforehand.  I'll stick this in rockchip64 and rk3399 default kernels.
For reference, my test device is https://www.amazon.com/gp/product/B079GSMZ7G/
I didn't realize how tiny it was.  :lol:
@Igor I pushed this to the two 4.4 kernel 64-bit rockchips, I obviously can't see how it works against USB2 (where perhaps the firmware revision matters?)
It should be fine. 8153 seems to come only in a USB3 package anyway.
Well, in case anyone wanted to run in an RPi configuration...  :lol::ph34r:
