Fan KunPeng Posted February 18, 2019 Posted February 18, 2019 The u-boot I used is flash-image-1g-2cs-800_800.bin. It can boot linux from usb and in linux, it can detect my emmc. root@espressobin:~# dmesg|grep -i mmc [ 4.266090] mmc0: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA [ 4.308521] mmc0: new DDR MMC card at address 0001 [ 4.309517] mmcblk0: mmc0:0001 SEM04G 3.69 GiB [ 4.310228] mmcblk0boot0: mmc0:0001 SEM04G partition 1 2.00 MiB [ 4.310928] mmcblk0boot1: mmc0:0001 SEM04G partition 2 2.00 MiB [ 4.311176] mmcblk0rpmb: mmc0:0001 SEM04G partition 3 2.00 MiB, chardev (243:0) [ 4.311340] mmc1: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA [ 4.316565] mmcblk0: p1 But u-boot can't detect emmc and boot from it: U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Dec 26 2018 - 13:45:06 +0100) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 800 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>> mmc list sdhci@d0000: 0 Marvell>> mmc dev 0 Card did not respond to voltage select! Marvell>> mmc dev 1 MMC Device 1 not found no mmc device at slot 1 Looks mmc dev0 is sd card and dev1 is emmc. This is different with boot script.
ebin-dev Posted February 18, 2019 Posted February 18, 2019 The current u-boot can be found here. It includes DDR3 (V5 EspressoBins) or DDR4 (V7 EspressoBins) in the name. Please use the correct one and post the output and the details about your board.
kostap Posted February 18, 2019 Posted February 18, 2019 2 hours ago, Fan KunPeng said: The u-boot I used is flash-image-1g-2cs-800_800.bin. It can boot linux from usb and in linux, it can detect my emmc. root@espressobin:~# dmesg|grep -i mmc [ 4.266090] mmc0: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA [ 4.308521] mmc0: new DDR MMC card at address 0001 [ 4.309517] mmcblk0: mmc0:0001 SEM04G 3.69 GiB [ 4.310228] mmcblk0boot0: mmc0:0001 SEM04G partition 1 2.00 MiB [ 4.310928] mmcblk0boot1: mmc0:0001 SEM04G partition 2 2.00 MiB [ 4.311176] mmcblk0rpmb: mmc0:0001 SEM04G partition 3 2.00 MiB, chardev (243:0) [ 4.311340] mmc1: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA [ 4.316565] mmcblk0: p1 But u-boot can't detect emmc and boot from it: U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Dec 26 2018 - 13:45:06 +0100) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 800 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>> mmc list sdhci@d0000: 0 Marvell>> mmc dev 0 Card did not respond to voltage select! Marvell>> mmc dev 1 MMC Device 1 not found no mmc device at slot 1 Looks mmc dev0 is sd card and dev1 is emmc. This is different with boot script. Your u-boot DTB file does not have second controller enabled. Once both controllers are enabled in this DTB file, you will see them during uboot init phase TIM-1.0 WTMI-devel-18.12.0-a0a1cb8 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL1: Built : 18:37:55, Nov 29 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL2: Built : 18:37:56, Nov 29 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL31: Built : 18:3 U-Boot 2018.03-devel-18.12.2-00315-g1d4ab62367 (Nov 29 2018 - 18:34:51 +0200) Model: Marvell Armada 3720 Community Board ESPRESSOBin (eMMC) CPU @ 1000 [MHz] L2 @ 800 [MHz] TClock @ 200 [MHz] DDR @ 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from MMC... OK Model: Marvell Armada 3720 Community Board ESPRESSOBin (eMMC) Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>>
Fan KunPeng Posted February 19, 2019 Author Posted February 19, 2019 8 hours ago, ebin-dev said: The current u-boot can be found here. It includes DDR3 (V5 EspressoBins) or DDR4 (V7 EspressoBins) in the name. Please use the correct one and post the output and the details about your board. Yes, I used the u-boot from the link. flash-image-DDR3-1g-2cs-800_800.bin. It can't detect emmc. Bug? 7 hours ago, kostap said: Your u-boot DTB file does not have second controller enabled. Once both controllers are enabled in this DTB file, you will see them during uboot init phase TIM-1.0 WTMI-devel-18.12.0-a0a1cb8 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL1: Built : 18:37:55, Nov 29 2018 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL2: Built : 18:37:56, Nov 29 2018 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.0(release):v2.0-313-gea14b3d53 (Marvell-devel-18.12.0) NOTICE: BL31: Built : 18:3 U-Boot 2018.03-devel-18.12.2-00315-g1d4ab62367 (Nov 29 2018 - 18:34:51 +0200) Model: Marvell Armada 3720 Community Board ESPRESSOBin (eMMC) CPU @ 1000 [MHz] L2 @ 800 [MHz] TClock @ 200 [MHz] DDR @ 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from MMC... OK Model: Marvell Armada 3720 Community Board ESPRESSOBin (eMMC) Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>> Looks your u-boot version is older than mine. Where can I download it?
kostap Posted February 19, 2019 Posted February 19, 2019 7 hours ago, Fan KunPeng said: Yes, I used the u-boot from the link. flash-image-DDR3-1g-2cs-800_800.bin. It can't detect emmc. Bug? Looks your u-boot version is older than mine. Where can I download it? You cannot download it :-) This is my private build and I even do not remember saving it somewhere after burning to the board eMMC. This is not even "boot from SPI" case. I sent the DTS content required for enabling eMMC in u-boot to ebin-dev. If he decide, you may have such build in the official Armbian set. As an option, you may build the flash image by yourself enabling second SDHCI controller in DTS.
Fan KunPeng Posted February 19, 2019 Author Posted February 19, 2019 I directly use code https://github.com/MarvellEmbeddedProcessors/u-boot-marvell with blew modification: diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 2ab039c..5922da0 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -118,7 +118,8 @@ marvell,pad-type = "fixed-1-8v"; pinctrl-names = "default"; pinctrl-0 = <&mmc_pins>; - status = "disabled"; + #status = "disabled"; + status = "okay"; #address-cells = <1>; #size-cells = <0>; It works well. It would be a bug of armbian build script, since upstream has added support of emmc and dts code changed.
ebin-dev Posted February 20, 2019 Posted February 20, 2019 @kostap @Fan KunPeng I have manually enabled the second controller as suggested in u-boot/arch/arm/dts/armada-3720-espressobin.dts and rebuilt the images (see here). If you have time to test, please let me know if the mmc device is now detected by u-boot (I don't have an eMMC-EspressoBin for testing): Marvell>> mmc dev 1 Edit: Link changed to https://dl.armbian.com/espressobin/u-boot/
kostap Posted February 20, 2019 Posted February 20, 2019 47 minutes ago, ebin-dev said: @kostap @Fan KunPeng I have manually enabled the second controller as suggested in u-boot/arch/arm/dts/armada-3720-espressobin.dts and rebuilt the images (see here). If you have time to test, please let me know if the mmc device is now detected by u-boot (I don't have an eMMC-EspressoBin for testing): Marvell>> mmc dev 1 Will be glad to run this test, but my access to dropbox is blocked
kostap Posted February 20, 2019 Posted February 20, 2019 @ebin-dev - tested your last flash image and it was working on my board: TIM-1.0 WTMI-devel-18.12.0-a0a1cb8 WTMI: system early-init SVC REV: 4, CPU VDD voltage: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL1: Built : 09:50:21, Feb 20 2019 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL2: Built : 09:50:23, Feb 20 2019 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL31: Built : 09:5 U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Feb 20 2019 - 09:45:04 +0100) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 1000 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 Marvell>> mmcinfo Card did not respond to voltage select! Marvell>> mmc dev 1 switch to partitions #0, OK mmc1(part 0) is current device Marvell>> mmcinfo Device: sdhci@d8000 Manufacturer ID: 45 OEM: 100 Name: SEM08 Bus Speed: 52000000 Mode : MMC High Speed (52MHz) Rd Block Len: 512 MMC version 4.5 High Capacity: Yes Capacity: 7.3 GiB Bus Width: 8-bit Erase Group Size: 512 KiB HC WP Group Size: 16 MiB User Capacity: 7.3 GiB WRREL Boot Capacity: 2 MiB RPMB Capacity: 2 MiB Marvell>>
Fan KunPeng Posted March 4, 2019 Author Posted March 4, 2019 I just tested u-boot from https://dl.armbian.com/espressobin/u-boot/, looks new version working now. thanks! @ebin-dev
