Broken Chromium, can anyone confirm?
The last chromium update has broken chromium, can anyone confirm?
71.0.3639.110-1 It works without a problem
72.0.3626.96-1 It does not start
Firefox is still broken from what I see on the armv7 ... now chromium gets hiccups.
4.14.94 / 5.73
jshc1@ODROID-HC1:~$ chromium
Received signal 11 SEGV_MAPERR 000000000000
#0 0x0000022d9030 <unknown>
#1 0x000002267920 <unknown>
#2 0x0000022d937e <unknown>
#3 0x0000022d95ac <unknown>
#4 0x0000b2cf5fe0 <unknown>
#5 0x000000b0214c <unknown>
#6 0x0000025be95c <unknown>
#7 0x000002a8f91e <unknown>
#8 0x0000036afee0 <unknown>
#9 0x0000036b0512 <unknown>
#10 0x0000036b059c <unknown>
#11 0x0000036b05d2 <unknown>
#12 0x000002139a56 <unknown>
#13 0x000002139a92 <unknown>
#14 0x000001fba092 <unknown>
#15 0x000001fc5c2e <unknown>
#16 0x000001fc6130 <unknown>
#17 0x000001098de8 <unknown>
#18 0x000001356e64 <unknown>
#19 0x00000109a7f6 <unknown>
#20 0x00000109b422 <unknown>
#21 0x00000108f790 <unknown>
#22 0x000001f914bc <unknown>
#23 0x000001f91626 <unknown>
#24 0x000001f918a8 <unknown>
#25 0x000001f9880e <unknown>
#26 0x000001f90228 <unknown>
#27 0x00000097e510 ChromeMain
#28 0x0000b2ce74aa __libc_start_main
[end of stack trace]
Calling _exit(1). Core file will not be generated.
ATTENTION: default value of option force_s3tc_enable overridden by environment.
jshc1@ODROID-HC1:~$ [28554:28554:0221/212433.772966:ERROR:sandbox_linux.cc(364)] InitializeSandbox() called with multiple threads in process gpu-process.
jshc1@ODROID-HC1:~$ firefox
ExceptionHandler::GenerateDump cloned child 28758
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
On 2/23/2019 at 8:47 AM, Igor said:
Thank you for showing this.
So I installed chromium from sid 72.0.3626.109-1 and it works. But the amount of dependence probably will give me a lot of trouble and probably it will not be worth sacrificing.
Now only I will have to go and look what has stopped working through these dependencies .... :)
