Jim MacKenzie Posted February 24, 2019 Posted February 24, 2019 I've found a problem with Armbian on the NanoPi Neo 4 with USB 3.0. I have a RAID6 via four USB 3.0 external hard disks (I know, not optimum but it's been working fine for years off an older ARM box using USB 2.0). While the RAID works fine on the USB 2.0 port (established this was true afterward), when connected to the USB 3.0 port, the USB 3.0 hub I'm using disconnects after only a few seconds, disconnecting all the drives (of course). I initially used an unpowered USB 3.0 hub (I forget the manufacturer; I can check). I figured at first, this might be a power issue (even though the external drives are all self-powered). I found a 10-port powered Cable Matters USB 3.0 hub in my basement, and deployed it today, thinking that would solve my issues But it doesn't. Not a thing changes; the same problem recurs. I moved the hub's USB cable to the USB 2.0 port on the NanoPi and that cures the issue. So my RAID is slow, but it works. (And it's faster than it was on my old box, so it's good enough for now.) I'm not sure if this is a known issue, but thought I would report it.
Igor Posted February 24, 2019 Posted February 24, 2019 On 2/24/2019 at 12:10 AM, Jim MacKenzie said: I'm not sure if this is a known issue Expand I think this is related: So it looks like one of a known ones. If we had more ... this could be clear from quick forum scan. 1
Jim MacKenzie Posted February 24, 2019 Author Posted February 24, 2019 Thanks. I'll check out that thread. Not sure if it's significant, but I notice in /boot/armbianEnv.txt: usbstoragequirks=[snip],0x0bc2:0x331a:u,0x0bc2:0x3322:u And: jim@nobby:~$ lsusb | grep Seagate Bus 005 Device 009: ID 0bc2:3322 Seagate RSS LLC Bus 005 Device 008: ID 0bc2:331a Seagate RSS LLC Bus 005 Device 007: ID 0bc2:3322 Seagate RSS LLC Bus 005 Device 006: ID 0bc2:3322 Seagate RSS LLC I'm not sure what "usbstoragequirks" does, but perhaps it relates to this issue.
mhyon Posted May 3, 2019 Posted May 3, 2019 For USB 2.0, are you using a 4-pin header connector into GPIO2 (pins 1-4)?
Igor Posted May 3, 2019 Posted May 3, 2019 On 2/24/2019 at 3:09 PM, Jim MacKenzie said: I'm not sure what "usbstoragequirks" does, but perhaps it relates to this issue. Expand http://linux-sunxi.org/USB/UAS#Blacklisted_.2F_UAS_disabled
Jim MacKenzie Posted February 15, 2021 Author Posted February 15, 2021 On 5/3/2019 at 3:59 PM, mhyon said: For USB 2.0, are you using a 4-pin header connector into GPIO2 (pins 1-4)? Expand Somehow I missed answering this question. I'm just using the USB 2.0 port on the device. Mine has a pair of ports, one black (2.0) and one blue (3.0). Also, my system is still running kernel 4.4.192-rk3399 from October of 2019. Perhaps an upgrade to a mainline kernel might solve this issue, but I'm not sure which mainline kernel to use. (Debian Buster version of Armbian.)
mhyon Posted February 15, 2021 Posted February 15, 2021 On 2/15/2021 at 5:40 PM, Jim MacKenzie said: Somehow I missed answering this question. I'm just using the USB 2.0 port on the device. Mine has a pair of ports, one black (2.0) and one blue (3.0). Also, my system is still running kernel 4.4.192-rk3399 from October of 2019. Perhaps an upgrade to a mainline kernel might solve this issue, but I'm not sure which mainline kernel to use. (Debian Buster version of Armbian.) Expand Ah ok. Mine has 4 blue (3.0) ports.
Jim MacKenzie Posted February 15, 2021 Author Posted February 15, 2021 On 2/15/2021 at 6:18 PM, mhyon said: Ah ok. Mine has 4 blue (3.0) ports. Expand I was misremembering - I think mine has four ports, too. But at least one and possibly two are really USB 2.0. (This device lives away from here, so I can't look at it.)
