hdmi.sh ?
Will someone help me by telling me the parameters of hdmi.sh ?
I use Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180729.img.xz
my box is KM8P (S912)
  On 2/25/2019 at 10:45 AM, temps said:
hdmi.sh ?
Expand
Please attach hdmi.sh to your post and tell us what is the resolution of the monitor or TV you are using.
#!/bin/sh
bpp=16
mode=1080p60hz
#mode=720p60hz
for x in $(cat /proc/cmdline); do
        case ${x} in
                m_bpp=*) export bpp=${x#*=} ;;
                hdmimode=*) export mode=${x#*=} ;;
        esac
done
HPD_STATE=/sys/class/amhdmitx/amhdmitx0/hpd_state
DISP_CAP=/sys/class/amhdmitx/amhdmitx0/disp_cap
DISP_MODE=/sys/class/display/mode
echo $mode > $DISP_MODE
common_display_setup() {
        M="0 0 $(($X - 1)) $(($Y - 1))"
        Y_VIRT=$(($Y * 2))
        fbset -fb /dev/fb0 -g $X $Y $X $Y_VIRT $bpp
        echo $mode > /sys/class/display/mode
        echo 0 > /sys/class/graphics/fb0/free_scale
        echo 1 > /sys/class/graphics/fb0/freescale_mode
        echo $M > /sys/class/graphics/fb0/free_scale_axis
        echo $M > /sys/class/graphics/fb0/window_axis
        echo 0 > /sys/class/graphics/fb1/free_scale
        echo 1 > /sys/class/graphics/fb1/freescale_mode
case $mode in
                720p*)
                        export X=1024
                        export Y=768
                1080p*)
                        export X=1920
                        export Y=1080
esac
# Enable framebuffer device
echo 0 > /sys/class/graphics/fb0/blank
# Blank fb1 to prevent static noise
echo 1 > /sys/class/graphics/fb1/blank
echo 0 > /sys/devices/virtual/graphics/fbcon/cursor_blink
exit 0
  On 2/27/2019 at 7:26 AM, temps said:
#!/bin/sh
exit 0
Expand
hdmi.sh reads the mode parameter in the command line and sets up the framebuffer accordingly.  The default is 1080p.
Please run the following command:
cat /proc/cmdline
and report the result here. Also please indicate what resolution(s) your monitor or TV is capable of.
cat /proc/cmdline
root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=${mac}
19EL933G toshiba TV HD, but I have many TV toshiba, samsung, philips ... and I have the same problem with the display ( 1366x768  50Hz for the first toshiba)
If I do :
                720p*)
                        export X=1360
                        export Y=768
I have a very beautiful image, but it is deported on the left, and I miss all the beginning of the lines of codes
Either you try a proper HD TV or monitor capable of 1920x1080p, or you have to play around a little bit with the fbset command to try to find some setting that will work on your TV's.
Thanks, when I do
fbset --info
mode "1360x768"
    geometry 1360 768 1360 768 32
    timings 0 0 0 0 0 0 0
    rgba 8/16,8/8,8/0,8/24
endmode
Frame buffer device information:
    Address     : 0x3a200000
    Type        : PACKED PIXELS
    Visual      : TRUECOLOR
    XPanStep    : 1
    YPanStep    : 1
    YWrapStep   : 0
    LineLength  : 5440
    Accelerator : No
But when I do
fbset -left 50
this do nothing
Thanks for the answers.
I found a solution, by changing television.
The problem of the first TV is that there is no "native" mode in its settings. Taking another TV always a 19-inch toshiba, at first I had the same problem because it was in cinema mode. I corrected. I tested samsung which was no problem with the latest hdmi.sh
  • Werner locked this topic
