Since I upgraded my kernel to version 4.19 (`linux-image-next-cubox=5.73` when I tried I think) on my cubox-i4 pro, I lost HDMI :
root@cubox:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SPDIF [Integrated SPDIF], device 0: S/PDIF PCM snd-soc-dummy-dai-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Anyone experiencing this too ? Downgrading to `linux-image-next-cubox=5.60` solved it.
apt install linux-image-next-cubox=5.60
reboot
aplay -l
  Subdevices: 1/1
card 1: DWHDMI [DW-HDMI], device 0: DW HDMI [dw-hdmi-ahb-audio]
  Subdevices: 1/1
Thanks
Edited by jeekajoo
Yes, I donloaded the desktop image and that worked fine over hdmi after upgrade and update turned everything of and when turned on again a brief flash of startup and then black. no signal. Xrdp works though and ssh too.
Welcome to ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 4.19.20-cubox
olivier@cubox:~$ aplay -l
  Subdevices: 1/1
olivier@cubox:~$
update:
After flashing my sd card with the stretch image my hdmi is still not working, i see a flash of boot text and then the signal is lost. Luckily i dont need hdmi.
I also lost hdmi... After some searches I decided to try: "sudo insmod /lib/modules/4.19.20-cubox/kernel/drivers/gpu/drm/imx/imxdrm.ko" (If I understand correctly, this insert a kernel module that I did see on the previous kernel, but not on this one with lsmod). I instantly got output on my monitor.
I've also tried adding this module (imxdrm) to /etc/modules. This also helps, although you only get a picture on your monitor when the login is reached... so you don't see startup-messages.
Now lets hope that:
1. this also works for you, and
2. someone who is knowledgeable reads this and knows an easy fix (and shares it :) ).
Thanks for the pointers regarding rolling back to 5.60, I was able to get the HDMI output back.
I also attempted to use the steps provided by @InterAct for the newer kernel.  These steps did not work for me.
I noticed in 5.60 that both imxdrm and dw_hdmi_imx were loaded.  Executing insmod on imxdrm.ko seems to work.  However, if I attempt to execute insmod using the dw_hdmi-imx.ko file it fails with the following error:
    insmod: ERROR: could not insert module dw_hdmi-imx.ko: Unknown symbol in module
Looking at the output from dmesg I see:
    dw_hdmi_imx: Unknown symbol dw_hdmi_bind (err -2)
    dw_hdmi_imx: Unknown symbol dw_hdmi_unbind (err -2)
I'm guessing this is the cause of the issue.  Anyone else seeing the same or know how to correct the problem?
Just updated to 5.85 with 4.19-41-cubox kernel. I don't see the unknown symbol messages. I do lose the hdmi output though. If I add 'imxdrm' to 'etc/modules', my monitor turns on just like before (after a reboot).
I went back to the 4.19-41-cubox kernel, instead of attempting insmod I added 'imxdrm' to '/etc/modules' and it works for me.   thanks
