SecureXperts Posted February 28, 2019 Share Posted February 28, 2019 Hello Currently my SixFab 4G hat is not working with the 4.4.x Kernel but with the latest 4.19.y Is there any chance that you port media script to the new Kernel build? Many Thanks Roman Link to comment Share on other sites More sharing options...
Myy Posted February 28, 2019 Share Posted February 28, 2019 If you need Video Decoding support, you'll have to wait until the whole thing is ported and stable. If you need GPU support, then you can just grab the mali drivers from Rockchip and use them with recent kernels. The Debian package for the rockchip drivers is here : https://github.com/rockchip-linux/rk-rootfs-build/blob/master/packages/armhf/libmali/libmali-rk-midgard-t76x-r14p0-r0p0_1.6-1_armhf.deb Or, you could do something like this, if you don't want play too much with random Debian packages : mkdir -p ~/.local/lib cd ~/.local/lib wget https://github.com/rockchip-linux/libmali/raw/29mirror/lib/arm-linux-gnueabihf/libmali-midgard-t76x-r14p0-r0p0-wayland.so -O libmali.so for file_to_link in libGLESv1_CM.so{,.1,.1.0.0} libGLESv2.so{,.2,.2.0.0} libEGL.so{,.1,.1.0.0} libgbm.so{,.1,.1.0.0} libOpenCL.so{,.1,.1.0.0} libwayland-egl.so{,.1,.1.0.0}; do ln -s libmali.so "$PWD/$file_to_link"; done echo "alias mali_launch=LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:`echo ~/.local/lib`" >> ~/.bashrc Link to comment Share on other sites More sharing options...
TonyMac32 Posted March 1, 2019 Share Posted March 1, 2019 15 hours ago, SecureXperts said: SixFab 4G hat is not working with the 4.4.x Kernel Here is by far the simplest solution I think: on your 4.19 kernel type lsusb and figure out what your usb 4G modem looks like. that device is obviously supported in the mainline kernel config, it might be available in 4.4 but simply not enabled. Link to comment Share on other sites More sharing options...
